belt squeel help
Old Feb 26, 2006 | 10:45 AM
GreenVQ30's Avatar
belt squeel help
my belt is squeeling i went to crappy tire they changed my ac and crank belt its still squeeling, wtf, starts squeling on start then whenever i give it gas its just gets louder, then when car worms up it stops,what other belts could be doing that??
Old Feb 26, 2006 | 11:00 AM
1996blackmax's Avatar
They may not have enough tension, or one of the pulleys is not happy.
Old Feb 26, 2006 | 01:41 PM
rhonster's Avatar
i was getting intermittent belt squeal at low rpms, low gear. spraying WD40 on the main bolt of the A/C idler pully assembly has totally resolved the matter. This is the adjustable belt tension unit located on the top loop of the outer, or main serpentine belt.
Old Feb 26, 2006 | 03:45 PM
BlackMaxdout's Avatar
that's actually not a bad idea, but temporary since WD40 doesn't last very long in terms of a lubricant. The tensioner pully has a crappy bearing in it, and mine even seized one night. The bearing retainer broke, all the bearings slammed into one another, and the belt slid around the pulley until it melted and snapped. Your best bet is to find a place that sells bearings and get a new one. They are cheap, and are easy to press back into the pulley. usually just a snap-ring holds them in.
Belt could also be loose like stated before.
Old Feb 26, 2006 | 04:07 PM
rhonster's Avatar
a brand new idler assembly is around $50, why fool around with bearings.
Old Feb 26, 2006 | 04:50 PM
MaximaSE96's Avatar
Maxima Owner
yea are idler pullys are garbage...but if u just had the belt replace it prolly streched out a lil since they put it on so u just got to tighten is up a little but with the tensioner....i think its a 15mm socket
Old Feb 26, 2006 | 05:33 PM
rhonster's Avatar
do you need to loosen the main pulley bolt or just turn the upper tightener?
Old Feb 26, 2006 | 06:52 PM
fisher01's Avatar
Loosen the main pulley nut. (14mm), then rotate the upper tensioner, retighten main pulley nut. Very easy to do from engine compartment, should just take a few minutes.
Old Feb 26, 2006 | 07:23 PM
...because I'm an engineer and like to take things apart to fix them. Plus it's either a $50 new idler that's not necessary...or an $8 sealed bearing that will last a long time.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
