burn smell, maybe clutch??
Old Mar 11, 2006 | 07:57 PM
Krannick's Avatar
1996 maxima se 5 speed 260 000km
when i release the clutch at about 2500-3000 rpm my front wheels squeals.
when i shift from 1st to 2nd gear in hard accelerating , the front wheels squeal again....and even sometimes from 2nd to 3rd....so i "guess" my clutch is fine..
when i'm up to 75-80+mph (wot acceleration) i smell a burned rubber smell.....even when im careful not to lose traction.....the rpm mounts steadily..not like a burnt clutch.....
could it be the clutch anyway....and how would you describe the smell of a slipping clutch???
how may I verify if the clutch is good
Old Mar 11, 2006 | 10:15 PM
TLMNICK's Avatar
It doesnt sound to me like you have a clutch problem. Maybe your brakes?.....if you have a seized caliper.
Old Mar 12, 2006 | 05:55 AM
Krannick's Avatar
nope, brakes all fine....i let the car in a fery easy slope (my driveway), as soon as i release the handbrake, it starts rolling down....
Old Mar 12, 2006 | 05:56 AM
Mxrider52's Avatar
I support for what?
Are all your rotors smooth
Old Mar 12, 2006 | 07:33 AM
97Se5spd's Avatar
I have the same problem but mines a 98 auto SE. I also have a humming sound coming from the left front wheel. My brakes are fine also, but I get the burning smell after driving on the highway for more then 10 mins. What could this be?
Old Mar 12, 2006 | 09:41 AM
Dodd's Avatar
I have the same problem. Anyone know what it could be?
Old Mar 12, 2006 | 09:53 AM
Guinader's Avatar
after you drive for a few miles stop the car and put your hand close to the break pads (DON'T TOUCH THEM) just feel for the heat, if you think you could burn your fingers (or you can feel the heat from 5-10in away) then your breaks are sticking to the rotors.
a slipping clutch, would happen, if you had no squeal of the tires, meaning, you would step on the gas, and the car would not move forward as fast.
conclusion: the clutch is good (IMO from what you told us)
Do the breaks thing.
Old Mar 12, 2006 | 10:01 AM
clive's Avatar
100% chingon
Of course, the burning smell may not have anything to do with clutch or brakes. It could be a small oil leak dripping onto the exhaust.
Old Mar 12, 2006 | 06:52 PM
Krannick's Avatar
the oil spill might be right....but it it really like a burned rubber smell....
i changed the two belts recently...but they dont make any noise...might be that anyway ....
Old Mar 12, 2006 | 07:05 PM
whitegold's Avatar
I have a 95 auto and at higher speeds I can smell rubber burning.
Is there any way to test if brakes are the problem?
Old Mar 12, 2006 | 07:08 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
It might be your Rear Calipers. Next time you do 70-80, and you start smelling it. Pull your car over, and go to the rear caliper, and smell it from there.
Old Mar 12, 2006 | 08:52 PM
aspsmax's Avatar
now... im not one hundred percent sure... but u guys might wanna check ur cv boots... i got a ripped one my self (witch i still havent found the time to swap out the axel) but when im drivin, especialy with the windows down, u can smell it. tho most of the time it smells a little more like tranny fluid than rubber buts its definatly burning... and this is especial could be true for the guy with the humming sound... just check out ur CV boots for any rips... i could b wrong cuz i also have a clutch thats really goin now but the smell was there b4 the clutch prob.
Old May 17, 2006 | 03:51 AM
Krannick's Avatar
source of the smell found
http://forums.maxima.org/showthread.php?t=472714
its the oil leaking from the rear valve cover when i let the car run over 5000rpm (high oil pressure)
user 11122324
42
Jul 18, 2022 03:35 PM
mclasser
22
Nov 12, 2020 01:58 PM
Smackasmith
Feb 1, 2016 12:40 AM
homewrecker
Sep 24, 2015 07:01 PM
