Oil Pressure Sending Unit Question
Old Mar 14, 2006 | 04:52 PM
cheeyo's Avatar
Hey, I'm about to replace my oil pressure sending unit....it's been leaky. Do you recommend putting some threadlock on the new sending unit? Is there a washer that goes on as well? Thanks!
Old Mar 14, 2006 | 04:55 PM
Kevlo911's Avatar
Kevlo for President
Just use some teflon tape.
Old Mar 14, 2006 | 05:01 PM
Jatan's Avatar
I also used tape http://www.motorvate.ca/mvp.php/514
No washer - you just screw it in
Old Mar 14, 2006 | 06:02 PM
maximaman10's Avatar
I used tape also
Old Mar 14, 2006 | 06:51 PM
ManualMaxima's Avatar
5th Gen till she dies!
yep i used tape......
Old Mar 14, 2006 | 09:17 PM
Fr33way™'s Avatar
Wild for Width
Does it screw in all the way until it is flush? I did this awhile back when I did not have the correct socket and it seemed tight but I remember still seeing thread.
Old Jun 7, 2009 | 04:21 PM
ThaMax's Avatar
I just replaced my oil pressure sender unit and I too noticed that thread was still showing. Is this normal?
I got it to the point were it would require a significant amount of force to turn it anymore (probably way over the 9-13 ft/lb recommended).
Old Jun 7, 2009 | 05:33 PM
pmohr's Avatar
No more Maximas...
As long as it's torqued down and doesn't leak, no worries.
Old Aug 29, 2009 | 03:01 PM
wirelessdude04's Avatar
just replaced mine.... But my light is still flickering when idle what else could be the problem? the sender was def leaking thats why i replaced it
Old Aug 29, 2009 | 03:53 PM
pmohr's Avatar
No more Maximas...
Does the connector fit tight on there? If you move it around or shake the harness, does the light flicker?
Old Aug 29, 2009 | 04:40 PM
the light flicker's randomly at idle sometimes it does and sometimes it doesn't.... i will check right now and see
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
scarletsosa
Aug 17, 2015 09:09 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
