How to install Polyurethane bushings?
Old Jun 13, 2001 | 07:55 PM
Screaminfast's Avatar
Hey,
Does anyone have a how2 on intalling the Energy Suspension FSB and endlink bushings? I just got them in, and I was reading the instructions and they were very vague.
Thanks.
Old Jun 13, 2001 | 10:21 PM
MaxedBandit's Avatar
Originally posted by Screaminfast
Hey,
Thanks.
The sway bar bushings are easy. You just pry out the old ones and put in the new ones (more specific information is available, if requested). The end-link bushings are a PITA. I brought them to my shop to be installed and the stock ones had to be burned out and such and took quite a while. I'll try and find the instructions if I can.
Old Jun 14, 2001 | 12:33 AM
teejnut's Avatar
how much of a difference when u install polyurethane bushings for the front end?
Old Jun 14, 2001 | 06:45 AM
Should I wait until I put my struts/shocks in, which will be in August, when the AGXs come out? Or is it an easy enough install, where it can be done quickly and easily?
Old Jun 17, 2001 | 11:52 PM
chiefthunder's Avatar
DONT DO IT MAN!!!!!!!
for God sakes man, i kid you not!!! the bushings squeak so loud my girlfriend made me take them out. and just so you know, the dealer has no way of selling you a stock bushing alone b/c it is attached to the control arm and they are $175 a side. i have my old one to prove it..... nate/ but they work okay i guess, hard to tell cuz i got them after the fstb, rstb, shocks, springs and rsw... nate
Old Jun 18, 2001 | 12:00 AM
jaxima's Avatar
sorry chiefthunder, but I must regretfully admit that the bushings need to be replaced. I replaced mine and for the first ~1000 miles the new bushings "squeaked" when I came to a stop or a go. The ride feelt a little tighter at first, but it seems to have stiffened more after time has passed. The squeaks have now dissipated and the ride is much better. Just jam really loud for a half a year & you won't notice anything but a better ride. Do it, no r3gr3ts
Old Jun 18, 2001 | 12:09 AM
i had it for a month or two only, maybe i should have waited... in that case.. anyone wanna buy my bushings/control arms.... i'll put em in for ya too!
Old Jun 18, 2001 | 01:34 AM
vmok's Avatar
How much difference is there between the Courtesy Nissan bushings and the Energy Bushings? I bought the Courtesy ones and never got around to installing them. Don't even know if I can find them anymore!!!
-V
Old Jun 18, 2001 | 04:24 AM
How much to have someone install them?
Also, anyone have instructions with pictures?
Thanks.
Old Jun 18, 2001 | 05:33 AM
95Max's Avatar
Energy Suspension are the ones that Courtesy sells. I have had the bushings on my car for over a year and not a sound. I would got to suspension.com they have better prices.
As for the install...jack car, support car, remove wheels. Remove the bolts on the brackets, remove brackets and old bushings. Clean the bar use the grease that came with the buishing a grease the sh*t out of the inside of the bushing AND the bar. If you need more grease or did not get any go to a marine supply and get water proof trailer grease. Put everything back together.....and enjoy.
Old Jun 18, 2001 | 08:04 AM
Dave B's Avatar
Not DAVEB the parts guy
Do you guys have the part numbers for the Energy Suspension parts or will they know which ones go on a 96 Max? I've got a $50 gift certificate and I want the endlinks and fsb bushings. Thanks.
Dave
Old Jun 18, 2001 | 08:21 AM
Dave
Front End Control Arm Bushing Set: 7-3111
Front Sway Bar Frame Bushing Set: 7-5118
These are from www.suspension.com
Old Jun 18, 2001 | 08:33 AM
Dave B's Avatar
Thanks. The Front End Control Arm Bushing set is the endlinks, right? I don't want the lower control arm bushing that require a press to get them in.
Dave
Old Jun 18, 2001 | 08:51 AM
Dave
I'm not exactly sure. Mine are sitting in the box in my living room. I think its the endlink ones, but they might come with all of them too. I didn't know a press would be required for some of them. Maybe someone else will help us out on that one.
Old Jun 18, 2001 | 11:21 AM
95Max's Avatar
Front End Control Arm Bushing Set: 7-3111 are not endlinks. They are for the control arm. Currently energy suspension has the endlinks, sway bar frame bushings and control arm bushing avail.
Hope this helps
Old Jun 18, 2001 | 02:53 PM
Hope this helps
The endlinks are separate?
Old Jun 19, 2001 | 07:12 AM
95Max's Avatar
Yes
Old Jun 19, 2001 | 09:00 AM
Yes
Why does it only say they offer two things for the Maxima on their website.
Check it out: http://www.suspension.com/nissancars.htm
Old Jun 19, 2001 | 09:52 AM
95Max's Avatar
I don't know why there is not a part number. I have them in my Max. Call suspension.com and tell them you want the endlinks. They are a "generic" part ie they will fit a Max, Honda, Mercedes,...
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
2kmaximel
Sep 16, 2015 03:19 PM
Bonka
Sep 14, 2015 11:18 PM
