No reverse lights or A/C???????
Old 04-01-2006, 06:31 PM
Keatz's Avatar
Alright guys here is the story, my A/C doesnt work at all, basically the car doesnt rev up to about 1000rpm like its supposed to when the a/c turns on or when i put the front defrost on. I guess its the fan or whatever but any suggestions on what could be wrong would be great?????? I dont feel like paying 80 bucks just to find out whats wrong with my car and have absolutely nothing done
Another thing, my reverse lights havent worked since i put a different 5spd in, they worked in the beginning but they just dont work no more. I checked the bulbs and fuse, everything looks good, i dont know what else it could be, any suggestions????????
Im a newbie guys, so sorry in advance if your sick of answering these questions but any help is appreciated
Keatz is offline
Old 04-01-2006, 08:08 PM
No more Maximas...
pmohr's Avatar
The reverse lights are driven off of a sensor on the trans bellhousing, so check down there for loose connectors or exposed wiring.
As far as the AC, does the clutch on the front of the compressor engage when you press the AC button and turn the fan up?
pmohr is offline
Old 04-02-2006, 05:53 AM
njmaxseltd's Avatar
1) Your engine should not race when your A/C is turned on. Idle speed should remain constant regardless of load. Your A/C has probably lost it's refrigerant charge and the system will no longer engauge the compressor. Have it serviced by a qualified A/C mechanic. Mention to them that your engine races a bit when the a/c is running. Perhaps they can adjust your IACV to better control that.
2) Check the switch on the tranny that activates your reverse lights. Perhaps you forgot to put that plug back in, or the switch is bad.
njmaxseltd is offline
Old 04-02-2006, 06:48 AM
Keatz's Avatar
No the clutch doesnt engage when the ac button is pressed at all, so im totally clueless about that. Thanks for the reverse lights info, im gonna go work on the car this afternoon for that.
As for the engine racing, i dont mean that the idle goes nuts, its just when u hear the compressor the revs go up to just under 1000rpm, and my car doesnt do that at all, so im guessing its something with the compressor, but really i have no clue.
Keatz is offline
Old 04-02-2006, 06:54 AM
No more Maximas...
pmohr's Avatar
Then it's as njmaxseltd said, there isn't enough refrigerant in the system to allow the clutch to engage.
I'll assume it's similar to my mom's '98 Dakota - if there isn't enough pressure in the system, it won't engage, but you can bypass it to test. You can take off the harness that reads that pressure information and just jump two of the terminals on the connector to bypass the actual pressure sensor and it should engage from there.
How to test that on the Max, I'm not sure of the location or pinout of the connector for that.
pmohr is offline
Old 04-02-2006, 09:06 AM
I'm nutty for Nissans
JSutter's Avatar
your back up light/ neutral position switch is bad.
if the a/c system is low on refrigerant it wont engauge the clutch. go buy a refill kit with a gauge and check it out. if you have a leak refilling it may not help. also the idle will raise by a small amount when the a/c is on. there is a fast idle control solenoid on the IACV for the a/c and another for the power steering.
JSutter is offline
BkGreen97
04-02-2016 05:47 AM
fastcarny
10-06-2015 10:42 AM
rnb754
09-14-2015 11:39 PM
minsbang
09-11-2015 08:48 PM
Maxima30
09-07-2015 06:13 PM
Quick Reply: No reverse lights or A/C???????
