Sanded Headlights. Need Help
They didnt come out all that good. I followed this write up - http://forums.nycmaximas.org/showthread.php?t=6432
I started with 400, then 600, 800, 1000, and 1500. After that I used the Novus product from 3 to 1 and worked on them for a pretty long time. They didnt come up all that clear.
I have the 97+99 lights i bought off a .org member that are AE'd really nicely.
Any feedback from guys that have done it ??
-matt
-matt
i would finish with something finer. i used a 2000 as my final step and wished i had found 2500. i used quite a bit of plastx (plastic polish and cleaner) before i saw any real results. i also noticed it worked better when i applied the polish in the direction i used the sand paper and removed it in a circular fashion. i know that write up mentioned keeping the paper wet but i would keep a spray bottle of water to spray on the headlights.
Yea I thought about using something a little finer but I figured 2000 is like rubbing paper on the headlights. Seems a bit pointless to me. Once you get to the NOvus, thats like your polishing with the 2000....
I guess I can take them back out and do it again. Ill take one off and see if I can get it any better.
-matt
-matt
I had to do mine twice because I wasn't satisfied with 1500.
Just keep going with moderate pressure untill the sandpaper moves very easily across the lense and then move to the next step.
The 2nd time I went to 2000 grit and used Maguires plastiX or something like that.
I don't understand why you guys sand plastic lenses to get them clear. A buffer and some compound is all you need.
Matty, if you stop by my shop one day I'll buff them out clear for you in about 5 minutes.
Im gonna stop by during the week and take you up on that offer
-matt
DAMMIT. Which compound do you use?
lowpost99
10-20-2015 07:42 AM
