braking issue - rotors?
Old 04-29-2006, 08:07 PM
goldtooth's Avatar
So, when Im braking from like 40-30mph with the pedal decently pressed in(not all the way), my car feels like there is another force applying more pressure to the brake system, and it is like bucking....
like the brakes are applied harder then softer, harder then softer, etc....
but i know that the pedal is applied gradually and Im not tapping the brake pedal(which is what the car feels like)
perhaps it is the rotors?
Im not sure....
help
goldtooth is offline
Old 04-29-2006, 08:29 PM
PAREDLINE's Avatar
Are you saying your pedal is "pulsating"?
PAREDLINE is offline
Old 04-29-2006, 08:55 PM
whitegold's Avatar
If the pedal isnt pulsating.. It might be a warper rotor(s) but I dont think it would have that kind of effect.
whitegold is offline
Old 04-29-2006, 09:18 PM
goldtooth's Avatar
the pedal is not pulsating but the car feels like it is
Old 04-29-2006, 09:29 PM
cleanmax's Avatar
i have a pair of brand new front rotors for 45 dollars. Just basic rotors nothing crazy
cleanmax is offline
crazy97's Avatar
I have this same issue. It feels like you are pushing on the pedal then letting off over and over..
crazy97 is offline
Old 04-29-2006, 09:58 PM
goldtooth's Avatar
yea, thats it, but the problem is that in fact I'm not...
Old 04-30-2006, 04:29 AM
Maintenance Monster
dgeesaman's Avatar
It sounds like you may have warped rotors. I recommend Brembo blank-style rotors.
When you get the new ones installed, I recommend using a torque wrench to loosen and re-tighten every lug nut to 80ft-lb, especially after the car has been serviced.
Dave
dgeesaman is offline
Old 04-30-2006, 09:07 AM
goldtooth's Avatar
can I visually examine the rotor and see if its wavy or is my eye not good enough to see that kind of wavy rotor?
Old 04-30-2006, 12:02 PM
ThurzNite's Avatar
If you look at my old rotors, you'll notice the alternating light and dark areas on the outter circumference. This happened when I switched to Hawk HP+ track pads. Yes, I knew this was gonna happen, it said right on the box it'll cause excessive rotor wear.
Jae
ThurzNite is offline
Old 04-30-2006, 12:33 PM
goldtooth's Avatar
I have Hawk HPS
but I think I'm just gunna get some Brembo blanks for all 4....
Old 04-30-2006, 01:24 PM
ThurzNite's Avatar
There's a group deal for rotors, I got the zinc plated slotted ones. They're flashy, but I want the HP+ again... Need more track days to wear the pads down.
Jae
Old 05-13-2006, 11:18 PM
crazy97's Avatar
I have solved my problem. I replaced the REAR rotors and pads and it brakes smooth for once!
crazy97 is offline
Old 05-14-2006, 12:10 AM
oem ftw!
CRiME's Avatar
did you have to bleed your brakes after you did this?
CRiME is offline
Old 05-14-2006, 09:27 AM
crazy97's Avatar
No, I didn't disconnect any brake lines. All I did was turn the caliper in with a tool I bought that attaches to a socket wrench. As I cranked in the caliper the brake fluid level in the master cylinder went up and I just sucked out some with a turkey baster and topped it off when the job was done. The first time you hit the brakes the fluid will go down a little and you should add more.
crazy97 is offline
Old 05-14-2006, 09:48 AM
oem ftw!
CRiME's Avatar
thanks!!!!!!
CRiME is offline
Old 05-15-2006, 03:48 AM
FishyMan's Avatar
bleeding doesn't hurt.
but can someone tell me the proportion in which the rear brakes?
FishyMan is offline
Old 05-15-2006, 08:16 AM
TimDawg's Avatar
Do you mean that you pushed the piston into the caliper, so the new pads would fit?
TimDawg is offline
Old 05-15-2006, 02:37 PM
crazy97's Avatar
Yes, but the rears require you to turn them in clockwise. You can't push them in like the fronts. I bought a rear caliper tool to do this. I've heard that you can use a needle nose pliers, but I'm glad I didn't try that.
crazy97 is offline
BkGreen97
04-02-2016 05:47 AM
bbsitum
09-11-2015 04:55 PM
beerman1378
09-08-2015 02:19 PM
crazyespn
09-03-2015 01:30 PM
A32goldylocks
09-02-2015 06:39 AM
Quick Reply: braking issue - rotors?
