Hood pins on a blk carbonefx hood? should i??
Old May 1, 2006 | 07:37 PM
my97maxi's Avatar
i need some help from the org. on this one. i cant seem to make up my mind. i have a blk carbonfiber hood from carbonefx;with the cf hood it is a b*tch to close with the stock latch, should i get hood pins to make it easier to close?? will it look right on the hood?? will it mess up the hood?? or should i just adjust the stock latch so it could be easier to close. any comments would help.
thnx
Old May 1, 2006 | 07:40 PM
Kevlo911's Avatar
Kevlo for President
Yes, get the hood pins.
Old May 1, 2006 | 07:44 PM
99grnmaxgxe's Avatar
Unless you want to have the risk of a shattered windshield, get the hood pins, ask MDeezy; he has some.
Old May 1, 2006 | 08:05 PM
Fr33way™'s Avatar
Wild for Width
You need hood pins so it doesn't fly up at speed.
Old May 1, 2006 | 08:33 PM
MaxxedOut624's Avatar
Hood pins are always recommended when getting a carbon fiber hood because the weight reduction is so great that there is the risk that the hood could fly up at high speeds. Get them.
Old May 1, 2006 | 08:54 PM
Flava_24/7's Avatar
Boosted Panda
Adjust your latch, the hood should close easily just like your OEM hood, and definately get hood pins. It doesnt take much for the latch to be ripped away from the fiberglass undersction.
Old May 2, 2006 | 06:36 AM
wetzelman1's Avatar
hood pins look badass
Old May 2, 2006 | 07:42 AM
my97maxi's Avatar
thanx for the post flava, but maybe im misunderstanding, ur sayn i should adjust the latch and get hood pins??
Old May 2, 2006 | 07:47 AM
Flava_24/7's Avatar
Boosted Panda
Yup, ive replied to your PM
Old May 2, 2006 | 08:55 AM
Maximus_95's Avatar
u need hoodpins! get it done
Old May 2, 2006 | 09:30 AM
chillin014's Avatar
I'm getting some, I'm just scared to drille into the hood and where to drill
Old May 2, 2006 | 10:00 AM
I did both as well.
Old May 2, 2006 | 10:03 AM
It's easy. Just take your time and it will come out ok. Screw the threaded posts into the car, put a piece of tape lightly on it (doubled over) and slower lower your hood. Tape will then stick to hood and mark where you have to drill. Use a dremel and go put it on a low speed. By trial and error, keep making hole bigger and bigger until posts go through. Piece of cake!
P.S. I like the smell of burning CF.
Old May 2, 2006 | 10:21 AM
Dexter's Avatar
I did both as well.
HOLY CRAP MAN THAT ENGINE LOOKS SICK!!! AND 319HP?!!! I was thinking of doing 3.5 upgrade but now I wanna supercharge my 3.0. Is that a Stillen supercharger?
PROPS TO YOU!
Old May 2, 2006 | 10:22 AM
Flava_24/7's Avatar
Boosted Panda
When I did mine, I installed the pins onto rad. support. Put some painters paint on the tip, then put a dab of white paint on tape that was on the pin, and slowly let the hood rest onto the pin. The paint left a white dot. I then put painters tape on the top surface of the hood to avoid cracking and chipping the clear coat when drilling.
I then drilled from the underside to the topof the hood with a real small bit.
Once the pilot hole was created a slowly enlarged it with a dremel from the top untill the pin fit through.
Old May 2, 2006 | 10:31 AM
aznsap's Avatar
do any kind of hoodpins (like off eBay) work? what kind does MDeezy sell?
Old May 2, 2006 | 10:36 AM
IMO, not all hoodpins will work. The fancy CF round hood pins look cool, but will be at an angle and not line up with the post. It MIGHT work, but based on my observations (yes, I bought some hoping they would work) I don't think they will work. I went with the classic Sparco ones.
PROPS TO YOU!
Thanks Dexter. Yes, that's a Stillen SC. Don't rule out doing a 3.5 swap. Why not do a 3.5 upgrade and then SC it? You'd be the man, and the second person to undertake such a project.
Old May 2, 2006 | 10:41 AM
Flava_24/7's Avatar
Boosted Panda
No, not all hoodpins will work. The fancy CF round hood pins look cool, but will be at an angle and not line up with the post. It MIGHT work, but based on my observations (yes, I bought some hoping they would work) I don't think they will work. I went with the classic Sparco ones.
Agreed, I also tried to use the locking type and they will not work.
They lock by a T type that fits into the post. With the angle of our hoods the T post would not line up with the cutout on the post.
Old May 2, 2006 | 10:42 AM
Yup. good write-up.
Old May 2, 2006 | 11:31 AM
Dexter's Avatar
I'm thinking of doing the swap at 200K (i got 120K right now so I got some time on my hands) I haven't ruled out putting a SC on a 3.5, but the thing is that if I go for 3.5 i'd like to put a NEW (or slightly used with less than 50K miles) engine in it which means $$$ plus I'd like to get a 6-spd tranny swap to go with it (more $$$), but i think a SC 3.5 would be way too much power for a FWD car (theres one that does 11 sec 1/4 mile on the track slip forum). I figure an engine swap would be cheaper than getting a new car so I might as well go for 3.5 (or back to 3.0 depends on price of gas at the time)
I think if I did try it i'd be the 3rd not the 2nd and by the time I do try it I think I'll be the 10th...
Old May 2, 2006 | 11:33 AM
my97maxi's Avatar
thnx everyone 4 their input
Old May 2, 2006 | 11:52 AM
Ceasars Chariot's Avatar
Old Maxima Legend
hood pins ! if for nothing else (safety) , latch could crumble
Old May 2, 2006 | 12:12 PM
Flava_24/7's Avatar
Boosted Panda
You say this like you speak from experience....
Old May 2, 2006 | 03:59 PM
RA030726's Avatar
I'm nutty for Nissans
I screwed the pins in, then dabbed some grease on the top. Then lowered the hood and the grease made the mark. then drill the holes, and mount the scuff plates. I used a step bit and had no issues.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
howardis
Dec 11, 2019 06:10 PM
Unclejunebug
Apr 2, 2016 05:42 AM
leatherneck
Sep 30, 2015 09:16 PM
