ac compressor
Old May 6, 2006 | 04:30 PM
maximaintheface's Avatar
ac compressor
is there a way to get the pull off of the ac compressor? it just spins when you try to lossen it. i notice there are 3 holes around the bolt is there a tool that goes in those holes so u can hold the pully in place then get that bolt lose?
Old May 6, 2006 | 04:59 PM
RickRossTheBoss's Avatar
I don't know
Old May 6, 2006 | 05:22 PM
then dont post
Old May 6, 2006 | 05:23 PM
sorry man, i didn't know what i was doing
Old May 6, 2006 | 06:58 PM
z32drifter's Avatar
impact wrench will knock it right off.
Old May 6, 2006 | 08:50 PM
konak85's Avatar
I think your talking about the AC clutch. The whole compressor must be changed.don;t think theres any other way. i changed mine a couple months ago. You don't need anything else but basic sockets, extensions and a breaker bar is recommended. there are 4 very long mounting bolts and two bolts that hold the AC lines to the compressor(AC system must be depressurized). You may have to jiggle the compressor around to get it in the right postition to loosen it. I suggest you get a Haynes manual first.
Old May 6, 2006 | 08:55 PM
WhiteMaxima9600's Avatar
only a couple of bolts holding it on, but you have to replace the whole compressor. Did mine last year
Old May 6, 2006 | 10:22 PM
o. well i have taken it off before it works fine it just the pully makes a funny noise i was just going to lube it up.
Old May 11, 2006 | 11:20 PM
anyone else have thier compresser making sort of a clicking noise it sounds like an idler pully that has gone bad almost just not as loud. its just really annoying.
Old May 12, 2006 | 09:57 AM
konak85's Avatar
i had the same whining noise and replaced mine a few months ago. I've never heard of anyone just lubing the bearing. you must change the whole compressor.
Old May 12, 2006 | 12:46 PM
Ceasars Chariot's Avatar
Old Maxima Legend
Old May 12, 2006 | 12:52 PM
mine isnt whining its clunking almost. it works just fine and doesnt leak. ceasar did u just take all the ac stuff out for less restiction?
Old May 12, 2006 | 06:48 PM
Old Maxima Legend
yeah, i did it about a month ago, i moved to NZ and the climate is so mild and the gas prices so high, i never used it, so its gone.
Old May 12, 2006 | 11:59 PM
sweet. what does gas go for over there.
05' MaximaMan
Oct 8, 2017 06:36 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
