does the catalytic converter effect the o2 sensor readings?
Old 07-15-2006, 12:27 AM
acidspit86's Avatar
10char
acidspit86 is offline
Old 07-15-2006, 04:49 AM
njmaxseltd's Avatar
Only effects the 02's after the cat.
njmaxseltd is offline
Old 07-15-2006, 12:54 PM
acidspit86's Avatar
so does that mean using a test pipe with our cars will actually hurt performance?
Old 07-15-2006, 01:12 PM
AlpineGt66's Avatar
nope, the front two oxygen sensors control performance, the02 after or in the cat makes sure the cat is working. So just get an 02 sim to put a test pipe in for a cat since it will throw a cel if you dont put the sim in. Also the 3rd o2 sensor ONLY starts controling the engine, or hurting performance if the both the front y pipe o2 sensors fail. So to answer your question shotly, NO.
AlpineGt66 is offline
Old 07-15-2006, 01:35 PM
acidspit86's Avatar
02 sim?
10char
Old 07-15-2006, 05:15 PM
AlpineGt66's Avatar
02 sim?
10char
yea an oxygen simulator, you use it for the oxygen sensor that monitors the cat. if you remove the cat it will read that its not working so you will have a cel. The 02 sim gets rid of the cel. just do some reasearch, and if you dont believe me all ihave to say is, trial and error my friend
Old 07-15-2006, 07:13 PM
nitromax's Avatar
techically, a bad cat can affect the upstream o2 sensors, voltage changes in response to low flow, less o2 in signal to ecu causing adjustments to fuel ratio. this a bad example, but here goes, normally you wouldn't say your a$$ affects your mouth, until you get constipated, then you change what goes in your mouth so the flow can be corrected. one difference is the sensor can go bad if problem isn't corrected soon.
nitromax is offline
Old 07-16-2006, 01:37 AM
Wild for Width
Fr33way™'s Avatar
^^^ Just wow.
Fr33way™ is offline
Old 07-16-2006, 06:50 AM
nad819's Avatar
had a question in a different thread with no reply, So I'll try this one:
Isn't it true that if the front 2 o2 sensors are working properly, the rear is only checked on ignition? Therefore an o2 simulator wouldn't provide any performance gains given that there is no CEL (4th gen with y pipe) Correct??
nad819 is offline
Old 07-16-2006, 07:27 AM
MDeezy's Avatar
Originally Posted by Fr33way
^^^ Just wow.
I second that.
MDeezy is offline
Old 07-16-2006, 12:38 PM
acidspit86's Avatar
can someone pick out one on ebay that will work for me, i question how legit some of these are..
Old 07-16-2006, 12:39 PM
acidspit86's Avatar
these cars arent obdII either are they?
Old 07-16-2006, 06:31 PM
nitromax's Avatar
yeah, they are, the connector on the 95 is located on the passenger side just behind the front edge of the console.
nitromax is offline
bbsitum
09-06-2019 07:31 PM
sdotcarter
09-02-2015 09:53 PM
Justin Kroll
09-02-2015 11:06 AM
Quick Reply: does the catalytic converter effect the o2 sensor readings?
