Is your wheel bearing bad... VID inside
Mine are shot so heres a video so that everybody can see what happens when they go bad.....
http://media.putfile.com/Wheel-Bearing-53
I just had mine replaced on Friday..... you could hear me coming about a mile away. I thought at first it was a warped rotor bc it was a metallic grinding sound proportional to the rotation of the wheel but apparently that was not the case. Mine could not be shaken like yours was however I have heard thats a good indication of whether or not the bearing is bad.
Originally Posted by nitromax
if you shake it from side to side as in the video, that usually will indicate a bad tierod. but grab the top & bottom and shake will normally show if the bearing is bad.
Correct IIRC...
BTW, although that looks like the stock suspension, the car is really jacked in the air. I thought I would throw that in for the n00bz.
Originally Posted by chillin014
Did Anyone See Those Massive Triceps
haha how hard is it to replace those thangs
Originally Posted by ThurzNite
Wow, by the time you get that much wiggle, I'm sure you woulda noticed a change in the braking too. All that "give" pushes the pads back. Have you checked the hub too?
honestly i the only noticable thing that occured was my steering wheel vibrating over bumps.. thats alll.. and i dont really see how the hub can go bad... i know that people have had to replace them but i dunno..
i guess i mean iv changed bearings so many times already and iv never seen a bad hub.. the race's are pressed in so much that it eliminates all movement... i guess the only way that i could go bad is when the bearing is so bad that it makes a race get dislodged from the hub...
londonflu
40
Sep 25, 2015 09:11 AM
^^^^^ damn u guys maybe i should show my gf this vid.... hahahaha
