Unorthodox Flywheel Opinions?
Old Jul 24, 2006 | 06:50 PM
GTRBlkMax97's Avatar
About to order the unorthodox flywheel and the act street clutch with the extreme pressure plate. Anyone have this combo or just the flywheel, looking for opinions on power improvement and drivability and places to purchase from. Got a couple places in mind, found the flywheel for $429(auto accessory superstore) and the clutch for $431(nippon power).
Again thanks in advance guys!
Old Jul 24, 2006 | 07:26 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
why not fidanza its less expensive....im going with fidanza and exedy st1 i would of went with unorthodox but too expensive....
Old Jul 24, 2006 | 09:45 PM
well a buddy of mine had the fidanza and said it was **** so i went with the more expensive one so far
Old Jul 25, 2006 | 07:02 AM
Flava_24/7's Avatar
Boosted Panda
The Fidanza is actrually a really good flyhweel, the only difference is that its just a tad bit heavier then the UR flywheel.With the UR flywheel you will have to use your OEM outer ring gear...
I have the Stillen Flywheel which is the same as the UR flyhweel paired with an Exedy Stage 1.
Both are good flywheels, I would have gotten the Fidanza but I got a really good deal on the Stillen one so I bought it instead.
Old Jul 25, 2006 | 07:08 AM
C MAX's Avatar
stillen has a good aluminum flywheel and organic clutch thats what i had. the clutch felt like stock but it gripped real sweet and reacted with the lightest touch.
Old Jul 25, 2006 | 09:34 AM
i30ds's Avatar
Armed and Dangerous
With the stillen, you have to take apart your stock flywheel so you can mate the starter starter ring and timing ring to it.
Regardless of what your friend said, the fidanza is not ****... probably the best flywheel out there. No need to take your old flywheel apart either. Just unbolt the timing ring off the old one and bolt it to the fidanza and you're ready to roll.
Old Jul 25, 2006 | 09:42 AM
Flava_24/7's Avatar
Boosted Panda
Same deal with the UR Flywheel, which is what I stated earlier about the Fidanza not needing this to be done.
Old Jul 25, 2006 | 02:19 PM
how hard is it to take that starter ring off the factory flywheel looks like its 3 bolts am i correct?
Old Jul 25, 2006 | 07:42 PM
i30ds's Avatar
Armed and Dangerous
It is some what of a pain... at least the one I did.
Old Jul 26, 2006 | 06:48 AM
NAPhi_Shift's Avatar
the fidanza one is def not sh-t! sounds like a good combo, let us know how it is if you get it installed
Old Jul 26, 2006 | 08:23 AM
papasmurf's Avatar
Honda Convert!
Ok I am sort of going to throw my 2cents into the pot... Fidanza is nice, very easy install just like any other flywheel. You do have to switch over the timing ring..however it does weigh more than the Unorthodox even with the timing ring attached. So you will loose some performance, but we are talking maybe 1 HP and/or 1ftlb of torque. Its negligable. As far as the Unorthodox one, I have that one and its nice too. Switching the timing ring is easy, only takes like 5 minutes, especally with air tools. I have done a few of these and they are really easy.... any other questions please feel free to ask...
Old Jul 26, 2006 | 08:27 AM
4x4Max's Avatar
What is involved in the installation of a fidanza flywheel? I'm going to upgrade from stock..
Old Jul 26, 2006 | 08:50 AM
thanks for that, really and truely guys the only reason Im not leaning toward the Fidanza is that a friend of mine locally had it and he said that with the ACT Clutch there was part of it that didn't mount up correctly and he just flat out didn't like the way it drived so but i really appreciate all the info and help
Old Jul 26, 2006 | 09:20 AM
papasmurf's Avatar
Honda Convert!
yeah I have heard of a few guys in the subie and 350z world having issues with the fidanza, acutally one of the guys at stillen said he had three of them in the same car, and they are junk. He said its work the few bucks to just get the Unorthodox one.
um...
1. jack or lift car
2. take off wheels
3. remove castle nuts on end of axles..
4. remove bolts holding suspension to hub
5. drain tranny fluid
6. pull drive and passenger axle
7. pull starter and transmission
8. remove clutch and flywheel
9 replace with new parts
10 reasemble in opposite order
Old Jul 26, 2006 | 09:31 AM
i30ds's Avatar
Armed and Dangerous
Originally Posted by papasmurf
...You dont have to switch over the timing ring...
I had to switch the timing ring over on my fidanza.
Old Jul 26, 2006 | 09:50 AM
96mAx2fast's Avatar
Yeah, let us know. Im thinking of getting a Fidanza and an exedy stage 1. Clutch is slowing going w/ 114k miles on it!
Old Jul 26, 2006 | 11:16 AM
papasmurf's Avatar
Honda Convert!
oh really I thought you didnt have to, oh well then correction will be made to my previous post...thank you for that
Flava_24/7's Avatar
Boosted Panda
Was this guy at a Stillen meet or works at Stillen?
Old Jul 26, 2006 | 11:26 AM
Flava_24/7's Avatar
Boosted Panda
Same here, I had always heard it was a direct swap, since I have the Stillen one I didnt know about the Fidanza first hand.
Old Jul 26, 2006 | 11:53 AM
papasmurf's Avatar
Honda Convert!
yeah oh well learn something new every day
Old Jul 26, 2006 | 11:57 AM
papasmurf's Avatar
Honda Convert!
No one of the guys that works for stillen
Old Jul 26, 2006 | 12:23 PM
Flava_24/7's Avatar
Boosted Panda
Just curious, but why would he use the Fidanza over a Stillen since he works there and Im sure he could get one at a better cost?
Old Jul 27, 2006 | 05:32 AM
papasmurf's Avatar
Honda Convert!
dont really know, he said it was for his STI so I dont think stillen makes one for that car and hence why he used fidanza but he said he has the Unorthodox one now and loves it
Old Jul 27, 2006 | 09:39 AM
i30ds's Avatar
Armed and Dangerous
Timing ring must definately be added to the Fidanza. The Fidanza does come with its own starter ring though... maybe that is where some of the confusion is. There was a guy about a year ago that did a 5spd swap and used a Fidanza with out putting a timing ring on it and the car would not start. He had to take everything back apart just to add the timing ring.
Old Jul 28, 2006 | 05:45 AM
papasmurf's Avatar
Honda Convert!
oh ok that makes sense, and why people might be confused. Damn that sucks for that dud cause I know how much of a pain it is to have to take off al that crap just to get to the clutch and flywheel...
REDinLV
Aug 15, 2024 12:30 AM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
dvcamp
Sep 18, 2015 10:17 AM
ac max 92
Sep 17, 2015 07:35 AM
