Manual Tranny fix
Old 07-25-2006, 08:26 PM
MaximA VlaD's Avatar
Manual Tranny fix
my clutch pedal resistance point has been dropping pretty low to the floor from time to time. i have narrowed it down to bad hydraulics - master/slave cylinders. is there are sticky on how to R&R master/slave clutch cylinders? I couldnt find one.
-Thanks!
MaximA VlaD is offline
Old 07-26-2006, 08:30 AM
has anyone done master and slave clutch cylinder replacement?
i appreciate the help.
Old 07-26-2006, 09:12 AM
xxtavixx's Avatar
I've never done either on the Maxima, but I have on several other cars. There really isn't a good way to decide which of the two is malfunctioning. However, you might want to keep an eye on your fluid level.
If you are not losing fluid, you should should examine your clevis (the threaded block behind your clutch pedal. Make sure it is tight. And change the fluid. If the probably still persists, then change your master cylinder. One of the seals is bad and the fluid is being rececyled.
If you are losing fluid, try to find out where it is coming from. Master cylinders fail more often than slave cylinders do (on most cars), due to the simplicity of a slave cylinder compared to the master cylinder.
-Andrew
xxtavixx is offline
Old 07-26-2006, 09:51 AM
Armed and Dangerous
i30ds's Avatar
Did you even check the fluid level? you might just have a leak at the two lower rubber lines.
i30ds is offline
Old 07-26-2006, 08:45 PM
yeah, the level drops periodically. i add brake fluid, then usually, after a day or two the problem stops and the clutch feels normal. in a few weeks, the problem comes back. I am going to look at the lines when i am down there. i ordered both cylinders anyway, in case those are the problem.
thanks. i was looking for some info, since i have never done this
Old 07-27-2006, 08:39 AM
Maintenance Monster
dgeesaman's Avatar
New lines and cylinders is a wise choice. Never money wasted.
Dave
dgeesaman is offline
Old 07-27-2006, 09:24 AM
Armed and Dangerous
i30ds's Avatar
Installing new slave and master is pretty easy. You might want to pick up a set of flare nut wrenches for the lines.
i30ds is offline
Old 07-27-2006, 01:50 PM
Maintenance Monster
dgeesaman's Avatar
That's a really good point. Just because a tubing nut is 10 or 12mm, doesn't mean it will loosen properly with a regular 10mm wrench. Get the flare nut wrench, and don't risk the hell of rounding off the nuts.
Dave
Old 07-27-2006, 02:58 PM
YoU CaNt SeE mE
Maxima-4DSC's Avatar
the slave cyl comes out with 2 bolts
the master come out with two bolts in the engine bay and then you have to remove the pin from the clutch petal and it slides right out. dont forget to remove the cotter pin fron the clutch pin b4 trying to pull the clutch pin out.
Maxima-4DSC is offline
Old 07-27-2006, 03:01 PM
crazy97's Avatar
The clutch master cylinder is not too hard but you will need some patience for this job. Getting at the bolts is kind of tricky, you will have to remove that part right next to the master cylinder for more room to work with. I'm not sure what it's called but it is bolted through the wheel well with 2 10mm bolts I think.
crazy97 is offline
Old 07-31-2006, 05:00 AM
thanks guys. i picked up a self bleeder set, with a hand pump, from autozone.
thats a great idea. especially when running into some hard to twist/rusted bolts or line fittings.
03-12-2020 12:06 AM
iamute
09-20-2015 05:22 PM
Vequity
09-10-2015 05:26 AM
pktaske
09-04-2015 08:40 AM
Lowered_a33
09-01-2015 07:49 PM
Quick Reply: Manual Tranny fix
