maf cleaner + throttle body cleaner
Old Aug 6, 2006 | 09:20 AM
zeeman's Avatar
i just cleaned my throttle body and maf cleaner 3 days ago and i ve noticed that my rpm never dropped below 500 anymore. My rpm used to randomly drop below 500 rpm when driven like under 40 mph under braking.
I only clean my throttle body with the spray and didnt used any brush to throughtly clean it, so i think cleaning my maf element helped my idling.
Any one else notice their idle after cleaning their maf sensor?
Old Aug 6, 2006 | 09:53 AM
99grnmaxgxe's Avatar
Makes sense, a lot of people experience a little bit of a higher idle when they clean the throttle body.
Old Aug 6, 2006 | 01:05 PM
Jellyfishian's Avatar
Difficult is NOT impossible!
Mine did the same thing, I always thought it was weird that the car would drop that low in idle when im going 35MPH and let off the gas, but I only cleaned my throttle body.
Old Aug 6, 2006 | 01:10 PM
96blkonblkse's Avatar
did you guys notice it when your coming to a stop and the rpms dip under 500rpm then come back up to normal idle?
Old Aug 6, 2006 | 05:46 PM
Yep, mine will still do it every once in a while, but nowhere near as much as it did
Old Aug 6, 2006 | 06:33 PM
maxima92se's Avatar
Interesting!! I might actually do this procedure this week. My car idles at about 600rpms. I am a 5spd though and its only happens when the car is warm.
Old Aug 6, 2006 | 06:41 PM
yeah after i replaced my plugs i noticed it stopped doing it for awhile, now i notice it does it when clutch is in and coming to a stop or if i rev it up it dips just below the 500rpm mark then goes back up to around 650-700. Maybe ill give this a try on tuesday.
Old Feb 10, 2007 | 10:55 AM
qazplm1999's Avatar
I have a 97 auto. it idles low around 500, and stall occasionally. It may be caused by a dirty throttle body? I'll have it clean right away. When my car stalled, it won't startup right away though, I have to wait for 10 minutes before I can start it. Maybe it's more than just a TB clean? No codes shown.
Any suggestion?
Old Feb 10, 2007 | 11:27 AM
Cdg2125's Avatar
Probably more than a dirty tb but clean first and see what happens. Also, you guys might think you're idling at 500 but you're not. I thought the same thing a while back until I have a summit rpm switch. It shows digitally what rpm I'm at and it was higher than I thought. Almost looking like 500 rpms and about 650 for me. And that's actually not bad for idle. You're idling should be about 650 if I remember correctly.
Old Feb 11, 2007 | 04:50 AM
96MaximuzGXE's Avatar
What do you guys say would be the best thing to clean tb?
Old Feb 11, 2007 | 06:50 AM
Bobo's Avatar
Obviously, throttle body cleaner.
Go to an automotive parts store and tell them what you intend to do.
OTE=96MaximuzGXE]What do you guys say would be the best thing to clean tb?[/QUOTE]
TallTom
57
Oct 14, 2025 05:16 PM
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
