Removing starter any comlications to deal with?
Old Sep 1, 2006 | 04:32 AM
black97's Avatar
I want to regrease starter before winter is here it makes griding noise in cold weather i know there is an article on motorvate.ca and it seems very easy.
Any problems to deal with?
Thanks.
Old Sep 1, 2006 | 05:12 AM
moogotzskillz2's Avatar
Nope not really, its pretty much staright forward.... The Only thing you need is patients and remember what screw you took out and where to put it back... GOOD step towards winter
Old Sep 1, 2006 | 06:41 AM
Curt's Avatar
Thanks.
And start by disconnecting your battery ground!
Old Sep 2, 2006 | 06:28 PM
Thorby's Avatar
I've had to take out two starters when they broke down. You need to remove the air filter cover to be able to access the starter. Do not forget to disconnect the battery first! Otherwise, you will get a nasty surprise when you ground the starter and cause huge sparks. Don't forget to reconnect all the wires that go into the air filter cover and be careful with the sensors that they connect to.
All it takes to remove the starter is a very modest mechanical agility.
D Mason
Jun 21, 2016 04:43 AM
maxima297
Sep 30, 2015 03:32 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
jaydot901
Sep 29, 2015 01:18 PM
