Who has noise problems with d2 coilovers?
Originally Posted by Mxrider52
Maybe that my problem. I get a clunk noise when turning left in the driver side. It just clunks 2-3 times then stops. and then makes the noise when it comes back.
Possible your cv joint...
mine does it when I turn left as well... turning right is beautiful quiet..
also, I was trying to work a theory maybe when turning left, the exhaust system was hitting something... but the didn't work out
![gapteeth](https://maxima.org/forums/images/smilies/gapteeth.gif)
Ksport and D2 are made by the same company from what I've read. They actually make a number of different color anodized coilovers and sell them under different brand names.
Anyways I had noise problems with my Ksports when I first installed them too, springs hanging up and "pinging" when I turned the wheel, and also clunking/clacking over bumps and road undulations.
I jacked the car up in the air and cleaned the threads off so I could lower the spring perches way down, so as to get the springs "loose" on the coilover. I applied some high viscosity silicone grease to the upper perch, lower perch, and the rubber isolators on both the upper and lower perches. Made sure everything was nice and clean first, by spraying with brake parts cleaner directly or by spraying brake parts cleaner on a rag and wiping it clean. Then I set them back to the height I wanted them at. That got rid of the pinging noises when I turned the steering wheel back and forth.
The clacking/clunking over bumps I found to be a simple case of not having tightened the strut rod nut tight enough. I was tightening it from memory from the last time I'd done suspension on a max which was... oh... 5+ years ago... and I remembered the #s wrong. I only tightened it to like 20 ft-lb. the FSM says 48-56 ft-lb. Being as it's hard to tighten those things because the strut rod starts turning, I just set the impact gun to the second lightest impact level which is about 50 ft-lb with my dinky little air compressor, and I zapped em.
Lastly I put a drop of 3in1 oil in the top of the upper pillow ball mount, that shut those up nicely.
I wouldn't be suprised if I have to reapply the grease and or re-oil the upper pillow ball mount at some point, but for now, they are nice and silent. knock on wood.
Originally Posted by Apparition
^^^^^ yeah I heard that as well.. but from what I've seen the D2's seem to be a little different in design from the KS. were you happy with them after the noise was gone?
Well the noise has only been gone for like 3 days now, but so far I'm happy with them. I've only had the KS in for a month or so, and most of that month has seen the car being laid up because I was doing some things to it, so really I've probably got less than a week and a half of driving experience with them.
ballerchris510
09-11-2015 05:29 PM
