Performance issues need help
Old Sep 14, 2006 | 11:06 AM
max80228's Avatar
Hi everyone- I have a 95 SE 5-speed. I do not have any codes or a check engine light. Have kept excellent maintance on the car-have owned for 5 years now. The car has 122k and is very sluggish. It starts and idles perfectly- just has no get up and go no low end power- plus I get maybe 17 MPG. Is anyone else having this problem? I cant be the only one. ANy feedback would be greatly appreciated. Thanks in advance.
Old Sep 14, 2006 | 12:06 PM
supazn
try cleaning your throttle body or changing the fuel filter.
Old Sep 14, 2006 | 12:33 PM
max80228's Avatar
I have kept up on all these things and tuneing up as well. I havent changed my O2 sensors in the front yet havent had a code yet. I did change the rear when it went out though. I know it has to be something simple I just cant figure it out.
Old Sep 14, 2006 | 12:56 PM
MorpheusZero's Avatar
KS is the only thing I can think of, sounds exactly like the symptoms and a lot of times they get "ghost codes" so your CEL doesn't come on. But if you've checked already then I dunno what to tell you.
Old Sep 14, 2006 | 03:59 PM
MadMaxSE-L's Avatar
Doggah Bite...
again,probly ks...
Old Sep 14, 2006 | 04:08 PM
MaximaEvolution's Avatar
little bit of a PITA to replace but thats most likely your problem. Pull the codes as if there were codes showin up, see what comes up. 20 bucks says its a knock sensor code. I'm pretty sure theres a write-up around here somewhere just do a quick search.
-Mike
Old Sep 14, 2006 | 04:30 PM
Garrick's Avatar
Have you had any problems with the dredded KS? I had the same prob. and replacing it brought the "Beast" back to life.
Old Sep 15, 2006 | 06:51 AM
ihatemymax's Avatar
Not to be redundant, but I had same issues with my ks and it wouldn't show a code, I only knew it was bad b/c I checked the code.
Old Sep 15, 2006 | 09:07 AM
konak85's Avatar
After 122k i would change the KS anyway.
Old Sep 15, 2006 | 12:03 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
... agree with what everyone else has said so far ... I had the same issue 2 months ago ...
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
pktaske
Sep 4, 2015 08:40 AM
