engine cutting out past 3k
Old Sep 18, 2006 | 05:06 PM
bogeyman007's Avatar
I just picked up my car from getting a new clutch put in and now whenever I get past 3k rpms the motor starts cutting out and doens't want to climb smoothly, it will still get to high rpms but it's really choppy and super rough. It runs fine at lower rpms. Also when I got it it was missing some intake hardware and the intake was kinda loose. Any ideas on what this could be?
1995 maxima gxe 100,xxx miles, fresh oil, new filter, new fuel filter, new plugs
Old Sep 18, 2006 | 05:08 PM
NmexMAX's Avatar
dot dot dot ...
Check for intake leaks and CEL codes.
Old Sep 18, 2006 | 05:15 PM
no codes, by intake leaks, the seal isn't perfect is it, cause it's just like plastic meeting plastic, I don't understand how an intake leak would cause this.
Old Sep 18, 2006 | 05:27 PM
NmexMAX's Avatar
dot dot dot ...
If the air leak was after the MAF, then the MAF will not meter it and thus the car will be digesting unmetered air, and result in cutting out as you stated.
Old Sep 18, 2006 | 05:42 PM
nsnrider's Avatar
also check the maf sensor itself, wait...you said no cel? then whatever nmexmax said. I had to change two intake gaskets on cars with similar problems as yours, not maximas though; altimas.
Old Sep 18, 2006 | 05:44 PM
NmexMAX's Avatar
dot dot dot ...
My MAF was dying and cutting out every few days... w/ no code, until finally it sent the code after it nearly left my sorry asz twice.
Old Sep 18, 2006 | 05:48 PM
MaximaSE96's Avatar
Maxima Owner
bets on the MAF....make sure the shop pluged it in
Old Sep 18, 2006 | 05:54 PM
MaximaEvolution's Avatar
MAF
start the car, and leave it in neutral. Slowly raise the rpms, does it go up fine? then try raisin the RPMs quickly, it should only go up to ~3000 and have a fuel-cut sound. If it does than its definitely the MAF
Old Sep 18, 2006 | 06:07 PM
how much does a new MAF cost?
Old Sep 18, 2006 | 06:10 PM
NmexMAX's Avatar
dot dot dot ...
45$ from www.car-part.com
Old Sep 18, 2006 | 06:11 PM
MaximaSE96's Avatar
Maxima Owner
^^^^^^ car-part FTMFW
Old Sep 18, 2006 | 06:31 PM
Apparition's Avatar
Ichiban King
yeahz, car-part is a good friend to have..
Old Sep 19, 2006 | 06:10 AM
sdoherty_tjm's Avatar
its not the maf itself, you wouldnt make it past about 2k. its sounds like a ****ty revlimiter at about then when its that thing itself
Old Sep 19, 2006 | 06:24 AM
NmexMAX's Avatar
dot dot dot ...
... My MAF went out and it was able to pass 2k..Just sputtered and died often
A sh!tty revlimiter...
.. Don't post in here unless you know you're talking about.
Old Sep 19, 2006 | 09:34 AM
Apparition's Avatar
Ichiban King
yeah mis-information is the enemy of this board.
Old Sep 19, 2006 | 09:39 AM
MaximaSE96's Avatar
Maxima Owner
word...i accidently had my MAF unplugged and i got past 2k
captchaos
Mar 15, 2016 12:18 PM
guitarman
Sep 19, 2015 11:52 AM
wingnut2006
Sep 19, 2015 06:13 AM
seesole
Sep 14, 2015 12:38 PM
jfl330
Sep 4, 2015 01:44 PM
