View Poll Results: Was this write up helpful?
Very Helpful
65.22%
Somewhat Helpful
8.70%
Not at all or already knew how to do it
30.43%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
How To: regrease Starter
Old Oct 11, 2006 | 08:44 PM
alleydawg6's Avatar
Livin dreams thru his Maxima
Links to pictures ..... they are in descending order ... last picture is linked first .... hopefully this helps you guys ... please let me know ... and don't forget to vote .... lol
http://i6.photobucket.com/albums/y24...gstarterin.jpg
http://i6.photobucket.com/albums/y24...reaserused.jpg
http://i6.photobucket.com/albums/y24...obeputback.jpg
http://i6.photobucket.com/albums/y24...dandcleane.jpg
http://i6.photobucket.com/albums/y24...asestillon.jpg
http://i6.photobucket.com/albums/y24...ovedtoopen.jpg
http://i6.photobucket.com/albums/y24...ofcarside2.jpg
http://i6.photobucket.com/albums/y24...eroutofcar.jpg
http://i6.photobucket.com/albums/y24...ecablewire.jpg
http://i6.photobucket.com/albums/y24...stillincar.jpg
http://i6.photobucket.com/albums/y24...starterout.jpg
http://i6.photobucket.com/albums/y24...rottlebody.jpg
http://i6.photobucket.com/albums/y24...rtsremoved.jpg
http://i6.photobucket.com/albums/y24...rthisscrew.jpg
http://i6.photobucket.com/albums/y24...dMafsensor.jpg
http://i6.photobucket.com/albums/y24...sesfromMAF.jpg
http://i6.photobucket.com/albums/y24...eckremoved.jpg
http://i6.photobucket.com/albums/y24...nneckthing.jpg
Old Oct 11, 2006 | 08:51 PM
NmexMAX's Avatar
dot dot dot ...
Invalid Private Message specified. If you followed a valid link, please notify the administrator
Old Oct 11, 2006 | 10:18 PM
NmexMAX's Avatar
dot dot dot ...
Am I being psychotic or do I remember an 18mm socket.. Not 17
Old Oct 11, 2006 | 10:58 PM
black97's Avatar
man it's so easy i did it month ago and very glad with the results it cranks very silent and fast now. spend like 1.5 hour to get the job done
Old Oct 12, 2006 | 02:58 AM
alleydawg6's Avatar
nah man it's 17mm ...
Old Oct 12, 2006 | 02:59 AM
alleydawg6's Avatar
yea it freaking took me 2 hours and 15 minutes ... but I got it done ... lol ...
Old Oct 12, 2006 | 05:48 AM
NmexMAX's Avatar
dot dot dot ...
Takes less time to change the starter.
Old Oct 12, 2006 | 08:21 AM
supaneko's Avatar
Would you mind PMing it to me, sir? Thanks!
Old Oct 12, 2006 | 09:00 AM
alleydawg6's Avatar
You've got PM ... let me know if it was helpful or not ... thanx
Ali
Old Oct 12, 2006 | 09:02 AM
alleydawg6's Avatar
Yea I guess ur right ... taking into consideration you don't have to take apart one clean it, wipe it down, degrease it, and grease it up again, and put it back together, and somehow get it back into the car ... lol ... yea changing the starter is a whole lot easier ....
Ali
Black Maxima
Putting the starter back together is a pain in the butt. I ended up just buying a new starter.
Old Oct 12, 2006 | 04:45 PM
adithius's Avatar
Can I get a PM write-up?
Old Oct 12, 2006 | 05:11 PM
alleydawg6's Avatar
You've got PM
Old Oct 12, 2006 | 05:31 PM
adithius's Avatar
Awesome write up. How do you know if you need to regrease? I've got 150 K, and never touched the started. It has had occasional longer starts, but not too bad.
Old Oct 12, 2006 | 05:34 PM
Fr33way™'s Avatar
Wild for Width
It will make a nasty sound, think of a gear spinning against a solid object.
Old Oct 12, 2006 | 05:42 PM
alleydawg6's Avatar
... mine was making a high pitched screeching sound
Old Oct 12, 2006 | 08:42 PM
shadyonedeath's Avatar
Pm please.
Old Oct 12, 2006 | 08:45 PM
sergofast's Avatar
pm please
Old Oct 12, 2006 | 08:51 PM
svojs's Avatar
That write up is not very detail. At least I have spent some time on two major points:
1) The write up did not mention how to remove the whole (stock) air duct. The example in the write up is not stock air intake. I spent some time to figure out how to disassemble the air duct.
2) If you try to disassemble the starter completely, you'd better write down or take pictures at every step. It's PITA to put every small parts back together. All I have is one sheet of diagram of starter from FSM. Fortunately, I got some common senses andsome luck to reassemble the starter and it worked fine.
Old Oct 13, 2006 | 01:21 AM
alleydawg6's Avatar
Sorry man I wasn't that detailed, being this was my first time doing this, I didn't know what I should write down or what I should leave to common sense ... also in my case I didn't take apart the complete starte like the person on Motorvate did, I didn't clean the so called "planetary gears" because I didn't want to get too far ahead of myself ... but if someone wants they can use the directions on motorvate in addition to mine ...
here's the link if anyone needs it .... http://www.motorvate.ca/mvp.php/516
Old Oct 13, 2006 | 01:25 AM
flynlr's Avatar
PM please ....
already used some of that lithium grease on my hand to do the KS lol
Old Oct 13, 2006 | 05:59 AM
alleydawg6's Avatar
Originally Posted by flynlr
PM please ....
You have PM ... yea man that Lithium grease is an all around good grease ... I substitute it for body lotion ....
Old Oct 13, 2006 | 10:28 AM
NerdManXdx's Avatar
Send me a copy please. I got the starter off once but never figured out how to disassemble it... Thanks!
Old Oct 13, 2006 | 10:32 AM
alleydawg6's Avatar
You got PM ... let me know if this write up was helpful or not ... thanx Ali
Old Oct 13, 2006 | 10:33 AM
hungurr's Avatar
would you please send me a PM? thanks.
Old Oct 13, 2006 | 11:59 AM
alleydawg6's Avatar
You got PM ... please let me know if this was helpful or not ... thanx
Ali
Old Oct 13, 2006 | 12:01 PM
alleydawg6's Avatar
hey man apparently you are not allowed to receive PMs .... most likely cause ur a newbie ... you have to have a certain amount of posts ... I can email it to you if u want ... this is the error I got:
hungurr has chosen not to receive private messages or may not be allowed to receive private messages. Therefore you may not send your message to him/her.
Old Oct 13, 2006 | 10:56 PM
alleydawg6's Avatar
Originally Posted by shadyonedeath
Pm please.
You've got PM ... let me know if it helped or not .... thanx
Ali
alleydawg6's Avatar
Originally Posted by sergofast
pm please
Ali
Old Oct 15, 2006 | 07:30 AM
Ka$hThaRipper's Avatar
pm me too plz; thanks in advance
Old Oct 15, 2006 | 07:50 PM
alleydawg6's Avatar
You got PM ... hopefully this helps you out man ... keep me updated ... thanx
Ali
Old Oct 16, 2006 | 01:09 PM
alleydawg6's Avatar
to the top ...
Old Oct 17, 2006 | 02:18 AM
aznxenon's Avatar
I think I'm gonna try regreasing my starter this weekend, can I get the PM? Thanks =)
Old Oct 17, 2006 | 06:45 AM
alleydawg6's Avatar
no problem man .... hopefully this write up helps ... keep me updated ... thanx
Ali
Old Oct 26, 2006 | 07:28 PM
alleydawg6's Avatar
and to the top it goes ...
Old Oct 29, 2006 | 05:20 PM
nitink's Avatar
How did you opened the 2 bolts which connect starter to Engine. In my car these bolts are stuck and no matter what I try they are not moving a miliMeter.
Old Oct 29, 2006 | 08:33 PM
alleydawg6's Avatar
those two bolts require a lot of torque ... so if you have a long breaker bar that should work ... the first time i tried taking the bolts off, i wasn't able to, I got frustrated and walked away ... came back later determined to open them, and I did, although I felt like my arms were gonna fall off ... but i did it ... so just make sure ur using the right size/type of socket and try spraying something like wd-40 on them to help you out ... good luck
Ali
Old Dec 1, 2006 | 07:56 PM
I re greased mine about 3 months ago and nots its starting to get a hard start. Its not the same noise it made because of the old-sticky grease. It sounds more like the engine is rev'ing right from the start as if i was holding in the gas.
Any idea?
Old Dec 2, 2006 | 07:28 PM
Xtr3m3X's Avatar
Reppin' the 216
Send me a copy too please! :-D
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
maxima297
Sep 30, 2015 03:32 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
