Need HELP W/starter and throttle body
Old Oct 24, 2006 | 05:14 AM
maxihari77SE96's Avatar
Hello...
couple of days ago I started noticing very rough starts.
Untill sunday, when the car wouldn't start.
Battery was k.
I went and bought a Bosch started, installed it and cleaned throttle body.
Car wouldn't start.
Battery was dead.
So I went and bought a new battery. Still won't start.
I noticed there are two contacts for that black wire on the Bosch starter.
I used the one on the right... slightly upper one.
Is that k?
Please help. Car won't start.
Thx.
Old Oct 24, 2006 | 09:21 AM
nobody yet?
Old Oct 25, 2006 | 04:39 AM
still nothing?
Come on guys, I need some help here?
Anybody have experience with Bosch starter?
Similar problems? Cleaning throttle body?
Thx
Old Oct 25, 2006 | 05:00 AM
cardana24's Avatar
Blown
I read this but I do not know what you are asking. Is the starter turning over when you hit the key? The starter should have a hot wire going to it and then the ground. Those are the only two wires going to the starter. I think the ground is just a plug and the hot wire slips over the bolt then you screw it down with the nut. I'm really not sure what your question is but you can make sure you have the starter wired correctly. If I were you I would check the car for codes if you were having a hard time starting it...a crank sensor could have taken a dump on you.
Old Oct 25, 2006 | 05:01 AM
mikem29ss's Avatar
Are you referring to the small terminals or the large ones? Usually one will be labeled S or something like that and the other R (at least thats how it is on most GM starters), anyways you want the S terminal. Best thing to do is take a positive wire and touch the other post. You won't hurt anything, and if the starter engages you have it on the wrong post. If you have it on the right post and still have no engagement, check for power at that black wire. No power there is a result of a bad inhibitor switch or ignition switch. I have seen more ignition switches than inhibitor switches (neutral safety). Also check for some blown fuses. HTH
Old Oct 25, 2006 | 08:47 AM
Starter is turning over. It just that the car wont start. The starter has two terminals on it... whereas the OEM part only had one. It also has a little black wire with a connector, but that's a no brainer. The hot wire is the one I'm talking about.
I am afraid that sparkplugs might be flooded too, by now.
I also tried cleaning the throttlebody while I had my intake off. Could that be the cause of car not wanting to start?
There are no labels by the terminals. Starter does engage, it just wont start the car... It keeps turning and turning. What fuses do you suggest I check?
Thanks again for help.
Old Oct 25, 2006 | 10:10 AM
cardana24's Avatar
Blown
Did you un plug your MAF for any reason? I would recomend you check your codes on your ecu. If you do not have any then I would start looking for big air leaks between the MAF and TB.
Old Oct 25, 2006 | 10:48 AM
Yes, I did...
Took that opportunity to install a different intake setup.
Will check for leaks as wel...
thx
Old Oct 25, 2006 | 07:59 PM
mikem29ss's Avatar
There is a crank fuse, only a 5 amp or so located in the interior fuse panel. I had one which was missing (who knows why) and it would crank a while then finally start. but it took a while. Also, the starter does engage with the key? I guess I missread your initial post. Anyways, if that fuse is ok, check for codes and see if any are present. If you disconnected the MAF or another sensor, than it will show up in a code. Good luck
Old Oct 25, 2006 | 08:17 PM
mastercater7's Avatar
VQ35 FTW
How long did you run it off the new battery?
Old Oct 26, 2006 | 05:17 AM
I got it started last night...
Had an intake leak...
Thanks to all.
Old Oct 26, 2006 | 05:25 AM
cardana24's Avatar
Blown
do I get a prize?
glad you got it running
REDinLV
Aug 15, 2024 12:30 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
followthadollar
Sep 13, 2015 09:55 AM
