Constant power supply in dash
I`m hooking up my Sirius in my Max, I want to hardwire in the power to something that stays on all of the time. What can I tie into, preferbaly somewhere easy to get at? Thanks.
Originally Posted by Sounbwoy
I use one of the fuses (cigarette lighter) for my radar.
Run a cable from the battery into the cabin, constant 12v w/o the key right there.
Another thing, Im not sure if the ignition switch has a live 12v wire from the battery. Check the FSM for the wiring diagram.
The straight red wires going into the ignition switch are constant +12v (it's either that, or they're red w/ a stripe, but they're fairly large gauge). Or, look at your fuse box, see what is battery powered, and tap into a wire coming from the backside of the fusebox.
Never wire directly to the battery...even if the device you're powering has a fuse built in.. Use the fuse block.
I made that mistake hooking my compressor clutch directly to the battery with a switch in my old Suburban.
