When Is Inner Tie Rod Replacement Necessary?
Old Dec 27, 2006 | 02:32 AM
Sloppy Snood's Avatar
I have searched the forums for a while and cannot find clear guidance on when the inner tie rods should be replaced.
Does anyone know what to inspect for this particular part?
I am trying to complete a suspension overhaul and am debating on whether to replace the inner tie rods when I replace the ball joints and outer tie rods. Most suspension parts resources consider a suspension overhaul to only include the outer tie rods and ball joints.
Advice and guidance requested. Thank you. -Sloppy
Old Dec 27, 2006 | 04:48 AM
njmaxseltd's Avatar
When it becomes very loose and you can feel play in the steering rod.
If it aint broke, leave it alone.
Old Dec 27, 2006 | 05:09 AM
I am assuming that I should check for inner tie rod play after I install the outer tie rods and ball joints? Or does it matter? It seems that I would need to know that the "outer" hardware is tight first, correct? Thanks.
Old Dec 27, 2006 | 05:17 AM
njmaxseltd's Avatar
No, if you must, disconnect the hub side and then grab the tie rod and push/pull twards the rack to feel for any play in the inner joint.
You should be able to feel and determin play from the outter or inner end without taking anything apart. Get the car up on a lift.
Old Dec 27, 2006 | 05:21 AM
Thanks njmaxseltd. I'll put it up on the lift tonight or tomorrow and check it as you have suggested. Thanks. -Sloppy
Old Dec 27, 2006 | 06:17 AM
dgeesaman's Avatar
Maintenance Monster
Another thing to consider:
When the play in the inner tie rod is small, it will be most noticeable because the amount of effort required to rotate the tie rod in its socket gets very small. A new tie rod requires a wrench to rotate it, IIRC.
Dave
Old Dec 27, 2006 | 07:00 AM
Dave
Will give that a try too Dave. Thank you. -Slopster
PH98I30
29
Feb 10, 2025 12:03 PM
6spd4dsc
Mar 4, 2016 05:19 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
