starts when cranked twice only
Old Jan 23, 2007 | 11:06 PM
GreaseMonkeY's Avatar
Hi Guys,
I have a problem maybe you can help out.
10% of the time, my car start immediate when I turn the key.
90% of the time, it makes the usual noise, but the engine will not start. Then I stop and turn the key again, and then the engine starts and everything is fine.
Could this be a problem with the battery? It is relatively new so this is unlikely.
Could this be a problem with the starter? 97 with 150,000 miles.
Thanks,
James
Old Jan 23, 2007 | 11:17 PM
vqmaxman's Avatar
if you don't here any misfires when cranking then it should be the starter.
Old Jan 23, 2007 | 11:24 PM
gen4maxima536's Avatar
check to see if its throwing any codes
sounds like the starter has a very good possibility of going out soon
Old Jan 23, 2007 | 11:27 PM
MorpheusZero's Avatar
Do you mean that it cranks for a turn or two and you give up, cranks for a few seconds but won't start, or it won't turn over at all?
Old Jan 24, 2007 | 02:58 AM
dgeesaman's Avatar
Maintenance Monster
This is also dependent on the age of the engine and its compression.
Are you saying the car won't start on the first turn of the starter, or you need to try cranking twice to get it to start?
Dave
Old Jan 24, 2007 | 01:30 PM
clarification
To clearify:
I turn the key and the starter starts cranking. The engine does not turn on. I stop after 3 seconds. I crank again, and the engine turn on immediately.
Thanks for the feedback.
James
mvm062
Nov 30, 2020 09:00 AM
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 11, 2015 05:29 PM
conansriver
Sep 11, 2015 10:26 AM
