Stop Leak???
Old Jan 29, 2007 | 09:40 AM
dpg_rp23's Avatar
Stop Leak???
Quick question...I'm getting this little slow dribble from my car's radiator system and upon further inspection it looks like it's coming from my water pump...it's nothing bad so i was wondering can i use on of those radiator stop leak things. Thanks ahead of time for your input.
Old Jan 29, 2007 | 09:45 AM
MaximaSE96's Avatar
Maxima Owner
noooooooooooooooo.....in my past experience it killed a water pump within 2 days after i notice the leak and put it in...either way it wont help witht eh water pump
Old Jan 29, 2007 | 10:04 AM
dpg_rp23's Avatar
kewl thanks...then does the waterpump have like a seal or something that i can change...cuz i know my waterpump still works..it just started leaking and my car has been parked ever since it happened.
Old Jan 29, 2007 | 10:29 AM
Maxgig's Avatar
I wouldn't recommend using stop leak, from my experience with it (and I'm not a mechanic, this is just my personal experience) I would only use it on a much older car, with a much heavier radiator such as on a old school 1970 - 1990 vehicle. As for the Max, there is a weep hole on the water pump that once it starts leaking I think it indicates imminent failure. It may last a day, week, month or longer but it's on the way out. I'm not certain if there are seals that can be changed out or not but IMO if you have to remove it you might as well replace it and be done with it. Provided you can afford it. Good luck.
Old Jan 29, 2007 | 10:44 AM
heynow's Avatar
dpg_rp23, what's ur mileage?
Old Jan 29, 2007 | 12:04 PM
moogotzskillz2's Avatar
I had the same problem on my old 95 max.. i just leak'd slowly after i'd turn it off..
I just add'd water every 4-5 days and i was good. i last me for about 2months then i sold it...
but whatever u do, Dont use that STOP leak crap!!!
-moo
Old Jan 29, 2007 | 12:10 PM
2da mizzax's Avatar
use some black pepper. if you are too cheap to change the rad.
Old Jan 29, 2007 | 12:40 PM
DCP's Avatar
DCP
If you read the directions on that stop leak you will see that its a PITA to use. You cant just dump it in and go. Not to mention that it will probably clog your heater core. and potentially cause other problems.
Old Jan 29, 2007 | 01:48 PM
dpg_rp23's Avatar
heynow- the motors has about 130k..the car has 170k
2da mizzax- the car has a new radiator..and cheap i am not
everyone else..thanks for the input..i have the original motor at home just lying around so it's just a matter of taking off the pump and switching it (that pump is good)
Old Jan 30, 2007 | 04:34 PM
rjtiobol's Avatar
How much is a new water pump?
How long do the water pumps last.
Old Jan 30, 2007 | 05:48 PM
Infamous95's Avatar
i recently had a scare with a coolant leak.... at first sight, it looked like it was leaking from the area around the water pump. got a bad scare when a mechanic told me close to a grand to change da water pump. said it was attached to the timing belt? and to change dat alone would be a headache. luckily mine was the just a rad leak... but... good luck to u when u do da switch
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
