parts cost on tranny rebuild
Jan 31, 2007 | 08:09 PM
i am planning on rebuilding, having someone else rebuild, my tranny this spring... i have a set labor cost, but am wondering how much i should plan to spend on parts... i know it depends on what gets replaced, so if i could get a range from fewest parts needed all the way to a complete rebuild. thanks!
Feb 1, 2007 | 03:05 AM
The low end on parts should be $200.
Feb 1, 2007 | 10:10 AM
ok thanks... any other input?
Feb 1, 2007 | 02:14 PM
I assume you're talking about a manual tranny.
$200 is a low end price for just bearings and seals. Synchros, hard parts, etc just go up from there.
Dave
Feb 1, 2007 | 02:27 PM
i went to the dealer asking the same things, just for parts, 200 is cheap..
Feb 2, 2007 | 04:45 AM
how much are you spending in labor bud? i said forget it on my auto trans. bought a used one with half the miles , i'm changing the main seals out, and then putting it in. when all is said and done, i will have $550 in parts and labor.
Feb 2, 2007 | 04:53 AM
i spent about $600dollars on parts, when i brought the car, the input shaft bearing was grinding really bad....then my clutch fork was going out...if your going to rebuild you tranny, i would get a nice aftermarket clutch, ACT
Feb 2, 2007 | 05:19 AM
dgeesaman, yes it is manual
jltibbs, i have a buddy who will do labor for $225
VQ, wow $600, damn, hope i dont need to spend that much... unless thats including the new clutch, in which case i planned on doing b/c mine slips sometimes so its on its way out
Feb 2, 2007 | 01:42 PM
well there are 4 bearings that you need to replace, each is about $50-60 from the dealer unless you get discounted, then you need to buy the seals,oil channels, and some other things. Another thing there's two more bearings besides from the 4 bearing, one is about $160 and other one is about $80. I'm not really sure if you need to replace the two but just a heads up.
