The new "ben's ecu mod"
Old Aug 20, 2002 | 06:26 PM
  #81
Sprint's Avatar
oh Ben.. i forgot to tell you.. i havn't lost my cruise control at all
Old Aug 20, 2002 | 08:03 PM
  #82
nismo2020's Avatar
Needs non-Maxima Friends
ben and sprint you guys are evil!
just did the mod a few days ago and im hooked. the first time after the mod when i got to 115 it sounded like it was about to cut out but that beyatch just keep pulling! i hit high 130s and ran out of room. just to think i was gonna spend like 100 bucks or more on an SE ecu. HA HA!.
total cost = $3.00 for a rocker switch from the shack.
this mod rivals the clear tailight mod for investment/satisfication return.
thanks ben and sprint. i have had my max for four years and this is the first time she has seen the other side of 118 mph.
oh yeah sprint your right its not all about doing 140, its about not getting left behind when the race starts at about 100.
thanx again bros.
Old Aug 21, 2002 | 11:17 PM
  #83
maxhead's Avatar
Originally posted by Ryan93SE
hope this one doesnt catch fire......just kidding Ben
good job...i wish i could think of these things
Ryan,
What size are you MM Evo's? Your homepage has different rims listed.
Old Sep 25, 2004 | 10:22 PM
  #84
kingrukus's Avatar
no more maxima...
Originally Posted by SprintMax
The link doesn't work anymore ...do you have the write-up with pics anywhere else?
Old Sep 25, 2004 | 10:43 PM
  #85
s0ber's Avatar
lol nice bump, this thread is like 3 years old
Old Nov 6, 2004 | 09:54 AM
  #86
Icudie's Avatar
Okay so after reading some of the FAQ's I stumbled on the ECU limiter...So last night I found out my car IS limited to 115 which is the cat's *****
What ECU options do I have now? Instead of going in and rewiring and dropping a toggle swtich (I have the mechanical knowhow of a 12year old girl).??
Can I just get an ECU out of some 96 SE, manual cause I am guessing the "computer controlled mount" on the auto would throw a light? Am I corect in assuming this? If so then what other options are there. I know in my G20 ECU could be sent to JWT to be fiddled on but what companies do that for Maxima, other then JWT?
Any advice is greatly appreciated.
Old Nov 6, 2004 | 10:04 AM
  #87
sagamax's Avatar
Give me a Bud Light Holmes
wow old thread
Old Nov 6, 2004 | 10:16 AM
  #88
sagamax's Avatar
here is a write up http://www.vqpower.com/v2/modules.ph...howpage&pid=15
Old Nov 6, 2004 | 12:07 PM
  #89
Otis_Speeding
Originally Posted by CharlieT
Gotta say great job well done
Luckily I got no speed limiter but I will try this on my friend MAx.
PS: I have passed 130 on my max already...Yeee Ha!!!
Yes sir, that's the beauty of having a 99...no speed limiter. Don't know if this was the only year without one..but as long as it's my year
Old Nov 6, 2004 | 12:19 PM
  #90
mzmtg's Avatar
Minister of Silly Walks
http://www.sprintmax.com/tails/bensecumod.htm
New link.
Old Nov 6, 2004 | 12:52 PM
  #91
1996blackmax's Avatar
I thought you had developed something else Ben. Then I clicked on the thread and I looked at the original post date .
Old Sep 15, 2006 | 03:43 PM
  #92
KCMaxima98's Avatar
Originally Posted by mzmtg
Gosh the things I do for you people. Ok, in no way do I condone breaking any laws. I figured out how to get rid of the speed limiter on the 4th gen. Cheston & Nick, would you mind putting this in your how-to sections??
Now for the write up:
________________________________
4th Gen Maxima Speed Limiter Removal
The ECU monitors the transmission mounted speed sensor to determine vehicle speed. When the vehicle speed limit is reached, the ECU cuts the fuel flow to the engine to slow the car.
The signal path for the vehicle speed sensor is as follows:
Sensor to Speedometer
Speedometer to ECU & Cruise Control
If the signal is interupted at the actual connection to the ECU, speedometer, odometer and cruise control functions are preserved. The ECU does not recieve a vehicle speed signal, therefore it will not limit the vehicle speed.
This modification is easy. But beware, it does include mutilation of the factory ECU wiring harness...not for the sqeamish.
1.Disconnect negative battery terminal.
2.remove ECU cover from passenger side footwell.
3.Loosen bolt in center of main ECU connector.
4.Unplug main ECU connector.
5.Remove snap-on plastic cover from ECU connector.
6.Locate PINK wire with BLUE stripe. (this wire is located on the right half of the connector when plugged in)
7.Cut PINK/BLUE wire.
8.Reassemble ECU connection.
9.Reconnect negative battery terminal.
10.Drive 140mph.
This modification will cause the "check engine" light to illuminate. If you check the codes, you will get 0104 (Vehicle speed sensor fault) and 0504 (A/T conrtrol unit fault). So far there have been no drivability problems
associated with this mod.
Enjoy.
::stands up to accept accolades from max drivers around the world::
I have a 98 GXE and the code that I got when I cut the speed limiter wire was 0203 (Closed Throttle Position Switch). This is obviously different from what is in the stickies. I installed a cheapo radioshack toggle switch and have driven hundreds of miles with the switch in the "off" position and have not gotten any more CEL's. With the toggle in the off position the speed limiter is still engaged (I tried it, it cut me off at 115 or so). I'm exhuming this ancient post to share my experience with this mod. The mod is easy. The toggle switch costs like three bucks. If you have a GXE, the wire that you need to find is easy to locate. It is the ONLY WIRE that is pink with a BLUE stripe. Get some butt connectors and a cheapo toggle switch and you can go as fast as the engine will take you with no CEL.
Old Dec 12, 2007 | 06:21 AM
  #93
secondtonone317's Avatar
nycnissans
dont kill me for bumping this........but I have a 2000 SE, got up to a little above 140 on it have not hit a speed limiter as of yet do I have one?
Old Dec 12, 2007 | 06:33 AM
  #94
NmexMAX's Avatar
dot dot dot ...
149 if it's an SE Read the thread before you bump it.
Old Dec 12, 2007 | 06:43 AM
  #95
Hammy
IBTL
Old Dec 12, 2007 | 06:53 AM
  #96
NmexMAX's Avatar
dot dot dot ...
I don't think anyone has ever got on a dyno and proved that an A32 SE has a speed limiter. So, I will assume 149, but I don't think it makes much of a difference. So yes,
Not only that, but a dynojet does not simulate load (drag), so who cares if you get to 155 on the dyno, Cd will probable be > you. But the A32 does have a good Cd, better than IIRC the A34 .
I will now:
Old Dec 12, 2007 | 08:18 AM
  #97
mowgli29's Avatar
Horizontally opposed.
Originally Posted by Ham1987
IBTL
= I Believe in The Lord?
that's a little OT...
Old Dec 12, 2007 | 08:34 AM
  #98
pmohr's Avatar
No more Maximas...
I will now:
I think even the xB has a better Cd than the A34
Old Dec 12, 2007 | 10:08 AM
  #99
Nealoc187's Avatar
SLOW
My a32 SE doesn't have a speed limiter, I'm using an auto ECU though so I'm not sure if there might be a difference there.
Old Dec 12, 2007 | 10:33 AM
  #100
wirelessdude04's Avatar
a few questions. The wire to splice into is the closest one to the bolt that holds the ecu into place correct? Second do i cut the pink/blue itself or splice a section in. Cause how would I wire a rocker switch into it? Like i have a wire coming from on/off how would I wire that to my ecu?? Thanks in advance for the help
Old Dec 12, 2007 | 01:16 PM
  #101
xlr8r's Avatar
Hey, just a thought but...
is the signal on this wire a voltage that is proportional to speed? If so then all you need is a voltage clamp like a zener diode then when you go over a certain speed, the voltage will stop climbing and the ECU thinks you've leveled off.
Pick a zener with a clamp voltage equal to, say, 75mph and you get the added benefit that if they ever pull the ECU to see how fast you were going, it'll never tell them more than 75!
oh, and everything else will work proper too.
Old Jan 14, 2008 | 07:00 PM
  #102
Grand_hustle17's Avatar
nice....... does anyone think the same procedure works on a 5th gen?
Old Jan 14, 2008 | 07:07 PM
  #103
MDeezy's Avatar
try driving that fast in your 5th and see if you run into that problem, if so find the wire via fsm cut it and try again.
Old Jan 14, 2008 | 07:17 PM
  #104
ok........... ten char.
Old Aug 2, 2011 | 01:47 PM
  #105
Jones99's Avatar
Wow old thread but works great
Old Aug 4, 2011 | 05:45 PM
  #106
highonfumes's Avatar
yea i got a 95max auto trans and i have went past 130 many times but like someone said wonder if there are any long term effects cause i dont wanna do it and lose a car three months later..... lol.... when u get involved with ecu it gets serious but i might try it, it sounds tempting
Old Aug 4, 2011 | 05:49 PM
  #107
and im sure OBD 1 and OBD 2 have alot to do with it too cause mines 95 and it is like beginnign of 95 so technically its 94 u really have to check wen it was made but i dont know figured maybe that would have to do with somethings to wether its throwing codes or not but im sure they didnt change the ecu wirings
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
