Question about the airbag light
Old Mar 7, 2007 | 02:09 PM
Luisjo's Avatar
So, my airbag light in the dash was blinking really fast then i did the "open the door, the nipple that tells the car the door is closed, push that 10 times in....." well i did it now is blinking but really slow is there anyway to stop it completly (other than disconecting the bulb
Old Mar 7, 2007 | 02:12 PM
99BlackMaxMS's Avatar
Try resetting the airbag light again, and make sure you did it properly. I think you only push it 7 times in 10 seconds....read the stickies and just double check .
Old Mar 7, 2007 | 02:21 PM
Luisjo's Avatar
i pushed it like 10 times i will try again thanks
Old Mar 7, 2007 | 02:24 PM
No problem. Whatever you do, don't take it to the dealership b/c they will charge you to diagnose the problem, just to tell you that its a bad sensor. Those will run you a few hundred at least. I know the owners manual says that the airbags should be replaced/checked after 10 years. So it wouldn't suprise me if it comes back that you have a bad airbag sensor.
Also, you only have the driver and passenger airbag? If your car is a 95 then you don't have to worry about the side airbags like the 98-99's do.
Old Mar 7, 2007 | 02:32 PM
Luisjo's Avatar
hi, thanks a lot i tried this time and pushed it 7 times exactly and the light is off now.
Old Mar 7, 2007 | 03:44 PM
Problem solved. Glad to help.
/thread.
ThomasofSodor
Mar 22, 2018 08:18 PM
doobadoo
Aug 15, 2015 06:43 PM
Flores94
Aug 13, 2015 01:17 PM
kirkhilles
Aug 8, 2015 10:53 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
