NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Nov 21, 2010 | 06:02 PM
  #6521
pmohr's Avatar
No more Maximas...
Originally Posted by noprobbob
1999 Se Misfire on #2 Cyl. Codes P0300-P0302-P1320. Replaced Coil pack 3 times, still misfire. Unplugged coil packs as car ran and no difference on idle on number 2 cyl. I took coil pack 6 and swapped with Cyl 2. Still #2 cyl is not firing. What could this be?
Injector, wiring, mechanical issue with that cylinder, ECU (in that order).
Here's where I would start:
  • Verify power/ground at the number 2 coil, and power at the injector.
  • Ohm out the injector (spec is 10-14 ohms)
  • Verify the ECU is (attempting to) trigger both the coil and injector. A noid light will help for this, or an analog multimeter. A digital one can work, but may not update quickly enough to see the signal.
  • If all of the above check out, do a compression test (can do just that one cylinder, but best to do all).
The P1320 can be thrown by not only bad coils, but also the condenser (have never seen this) or a CKPS REF issue (seen this once, I think).
Old Nov 21, 2010 | 07:13 PM
  #6522
jbeanz24's Avatar
Car dies while drive and battery light comes on.
Hey guys for about a week my car was shutting off on me while driving , the engine would shut off , and the battery and brake light would come on. I came to find out my alternator was bad and got it replaced with an oem nissan alternator. Lastnight after about a week with the new alternator it suddenly died on me again but i dont believe the brake light came on this time. Could it be the new alternator has gone bad on me already?. I put the car in park and had my gf gas it to see if the lights would dim out but they didnt. That was something that was definitely happening with the old alternator. The car started right back up again and i made it home no problem. Any idea of what can be going on? A friend of mine said my battery may be going out since i was driving around for about a week with a bad alternator previously, is that a possibility? Any help would be much appreciated. Also for what its worth my car is a 1997 SE
Old Nov 21, 2010 | 07:16 PM
  #6523
pmohr's Avatar
No more Maximas...
Have you had the alternator and battery load tested? Most auto parts stores will do it for free, or it's a relatively cheap procedure to have done at a shop.
Driving with a bad alternator can cause the battery to fail, and driving with a bad battery can cause havoc on the electrical system (including, but not limited to, killing the alternator, causing issues with the ECU, etc). It can (not commonly, but can) cause certain driveability issues as you're experiencing as well.
Any codes?
Old Nov 21, 2010 | 07:27 PM
  #6524
jbeanz24's Avatar
Im going to get the tests done tmm morning and I will follow up once i get home, hopefully its something simple.
Old Nov 22, 2010 | 10:13 AM
  #6525
elementalg20's Avatar
Hey guys, I had an issue with my new to me 97' hard starting, it'd crank forever without firing, and eventually it'd just decide to fire and run pretty well. I changed the CKPS ref sensor which I ohmed out to find out it was completely open. I changed it out, and disconnected the battery for quite a while. Now the car starts right off without any hesitation, but it starts and then immediately dies. If I throttle it a little it'll run, I can rev it 3-4 times up between 2k-3k rpm and it'll settle into an idle and seemingly run fine. Once the car is warm the issue doesnt seem to present its self any longer. I've got a post-cat o2 sensor that I know is bad, but I dont think this will cause my issue would it? Wondering what else it could be, also, I swapped out of MAF sensor for another used one and it seemingly made no difference what so ever. And my cel is apparently not working as i've never seen it light up in any situation, something else to address, hopefully just a bulb.....
Old Nov 22, 2010 | 02:53 PM
  #6526
serdnaclsg87's Avatar
CEL Code P0443
Hi, I have the p0443 code and have looked through most threads about things to check. I came across the ones to check the evap vent control valve and when I went to check it, there's nothing there. There are three hoses that go to the charcoal canister, two small ones and one fat one. One of the small ones goes through a small round plastic part (not sure what that is) that just has an inlet and outlet. Also, the fat hose goes to a y-shaped plastic piece and the other end of it doesn't have anything connected to it. Is this normal or did someone take parts off and just leave it like that? It's a '95. Any help is appreciated thanks.
Old Nov 22, 2010 | 05:36 PM
  #6527
noprobbob's Avatar
how do you disconnect fuel injector connecter
Old Nov 22, 2010 | 06:45 PM
  #6528
rckymtn I30's Avatar
Cruise control minor surging
Any ideas to why my cruise control makes me feel like it is not staying consistent? When driving 75 down the interstate, it keeps the speed fairly consistent, however, it feels like the gas pedal is constantly being depressed then let off. The RPM only vary by about 100 and the speed usually stays within +/- 1 to 2 mph. It almost feels like I am driving with a crazy person that can't decide how fast to drive. Is there a sensor or something that could cause this?
Thank you for any input.
Old Nov 22, 2010 | 10:04 PM
  #6529
dersh.z's Avatar
Originally Posted by dersh.z
Noob here (can't wait for 15 replies)... I have a 98 Max with 124K miles, auto, no mods, no problems ever until 3 weeks ago...
One morning before work the car wouldn't start, it turned over, battery was good, but would not start. Figured I flooded it since I could smell gas out the tail pipe. (It had been a bit fussy starting before all of this, but always started) It wouldn't start the next day either, changed the plugs. No joy. (the original Nissan plugs looked pretty good actually)
Had a Camshaft Sensor pos code (0101), along with a knock sensor and 02 sensor, I changed the CMPS...The car started, seemed to run good!! On my way into work, it died at almost every stop light.
No codes... A mechanic suggested the crankshaft pos sensor or a throttle position sensor. Ordered both crankshaft pos sensors (left and right) and a TPS from Rock Auto... replaced all 3 - testing the car after each sensor replacement. (Aligned the TPS to 500 ohms when hot). I then changed the fuel pump (new) and fuel filter. The MAF is spotless as is the throttle body.
I cleaned all of the grounds I can find (sand paper, wire brush and alcohol), I added the transmission ground some, from maxima.org, have suggested might help (4ga wire). I also cleaned the battery posts.
Since I changed the CMPS and CKPS; The car will start without touching the gas pedal, it will run good (slight vibration at idle - almost imperceptible, but not there before these problems started), revs good, I can drive around with decent power (not quite normal tho), then it just dies - either while idling or while driving - no real pattern other than it takes 20 - 30 minutes before it starts acting up. When I restart the car, I can't get it to rev above 2500 RPM. Very rough when I try to rev it, acts like it's starving for gas. Leave the car sit for 30+ minutes... it starts, runs good, but again after 20-30 minutes of idling or driving the symptoms reappear.
I'm getting a CMPS and CKPS code again (0101 and 0905 - both sensors are new - the connectors are clean).
This car has no rust, burns no oil, did run great (30+mpg on the highway) and was my daily ride... I would hate to retire it, any help would be most appreciated.
Thanks,
dersh.
FYI... I finally had to take the car into a mechanic since I don't have 15 replies and didn't get much feedback from the above... (it was suggested I try the MAF and ECTS - didn't help)
After 2 weeks of fiddling with the car, the mechanic found a leaking upper intake gasket. Car runs great now except it's a bit fussy to start when it's cold outside, need to give it a bit of gas while cranking to get it going, then it runs all day long.
Old Nov 22, 2010 | 10:38 PM
  #6530
Pinch the tab really hard until it 'clicks'.
Old Nov 22, 2010 | 10:44 PM
  #6531
I suppose that the time it was taking it to act up was just a matter of waiting of different engine materials to heat up and expand just slightly differently? Definately not a typical problem you had there, thanks for sharing your solution though, always sucks when your researching problems and someone has the same issues and never comes back with a solution. From one newbie to another thank you, even though I dont believe that is my problem
Old Nov 23, 2010 | 08:13 AM
  #6532
RA021526's Avatar
I like to use pliers, since most clips are super hard to break loose. Sometime a screwdriver helps too.
Old Nov 23, 2010 | 03:31 PM
  #6533
jholley's Avatar
The EVAP Canister Purge Volume Control Solenoid Valve triggers that code and is not located next to the charcoal canister. It is located on top of the intake manifold. ECU code 807 (P0443) on post 4 of this thread describes how to check and replace that valve if needed:
http://forums.maxima.org/4th-generat...ere-first.html
Old Nov 23, 2010 | 07:31 PM
  #6534
kaine's Avatar
Thanks for the tip pmohr, will check out; my car does sound like a tank thought i needed a muffler.
Old Nov 23, 2010 | 08:17 PM
  #6535
kaine's Avatar
Hello guys having trouble with 98 maxima feels like im stuck in one gear "say i'm stoped at a light once i hit the gas its like im going nowhere, i slightly take my foot off the gas then back on agian,then every feels like its shifting in place. What could this be? thanks in advance.
Old Nov 24, 2010 | 03:15 PM
  #6536
centauri's Avatar
Misunderestimated
Hi folks, I have a '95 Maxima M/T with 135K, throwing ECU codes 0303 (front left heated O2 sensor) and 0308 (closed loop control). Two quick questions:
* Is the latter caused by the former?
* How are Bosch or Denso replacement O2 sensors? ($50 cheaper than Nissan label)
Thanks, and Happy Thanksgiving!
Old Nov 24, 2010 | 10:01 PM
  #6537
malice9005's Avatar
Originally Posted by 95franklin
If you have had an alignment recently and haven't done anything to take it out of alignment (hit curb, small child, etc) then check your calipers, one may be seized. As for the pulling to the right, keep in mind the crown of the road and that most maximas just do it.
ill check the calipers but it happens only when accelerating not braking tho (i did hit that kid the other day jk) it was just aligned and its a very harsh pull so i doubt its the crown of the road
Old Nov 26, 2010 | 03:49 PM
  #6538
Replaced Fuel Pressure regulator - NOT
I posted a while back about my starting issue. I have done the grounds, cleaned the crank and cam positions sensors, and now replaced the fuel pressure regulator. My I30 sometimes requires me to press the gas pedal to get it to start. If it doesn't start normally, It always starts as soon as I give it gas. Could it be my TPS? Any other ideas? I have read it could also be the temperature sensor, but I just don't think that would be it as it seems to be fuel/throttle related, but who knows.
Old Nov 28, 2010 | 11:29 PM
  #6539
iiBabyface's Avatar
LED Corner lights
Hey, Noob here.. I had a question with LED lights.
Im installing them in the corner lights of my 99 maxima SE, as you know the bulb is an 1157 and also after reading up the site everyone loves is ( http://www.v-leds.com ).
Well the question i have is the 1157's on there site are 1) expensive (more then other sites) and 2) they say there dual color White & Amber for the blinker, now if i install them in the corner light will they work as white LED's? or are there single color 1157's that im too stupid to find
Heres the link to the Dual Color LED's ( http://www.v-leds.com/Exterior-LED/T...72058-1-2.html )
An answer would be appreciated :]
Thanks!
Old Dec 1, 2010 | 10:26 PM
  #6540
austinpnguyen's Avatar
I had a question about my tire size...I was wanting to put 245/30/20 on my 2004 nissan maxima but I have no idea if that would be alright or not.. I dont want to be rubbing or anything at all.
Old Dec 2, 2010 | 07:30 AM
  #6541
RA021526's Avatar
http://forums.maxima.org/6th-generat...-2004-2008-48/
Old Dec 2, 2010 | 01:36 PM
  #6542
4thGenTuner's Avatar
Tie rod question.
Whats up guys. I have a 96 gle and took it to get an alignment. My steering wheel was cocked to the left and the front tires were wearing funny (inside bald) indicating my wheels weren't aligned (toe in?). So the guy comes up and says I need two tires and two inner tie rods. The estimated cost was $465.72. I respectfully declined their offer to rape me and in return got an attitude from the front desk/manager guy. So I paid for the alignment and left.
When I got on the highway about a 1/8th mile away I gave it some gas on the ramp to get to roughly 70. As I sped up the whole front end started shaking and wobbling. Really pissed me off. So at about 68-70 mph this car develops a mean wobble. It didn’t seem like a good idea to push it any further to see if it stopped wobbling and shaking at say 85. It totally didn’t do that before the alignment....and it pulls worse than it did lol.
My question is: Will the tie rods make my steering wheel, dash, etc wobble and vibrate at 70 mph if they are in fact bad?
I plan on getting some tires and have an FSM as well as air tools so I am completely capable of swapping tie rods. Advance has Moog tie rods for $39.99 each. Nissan wants $47.43 for theirs and they have to order them.
Should I get the Nissan ones or the Advance ones?
Do I need to get another alignment after I replace the ones that are worn out?
Should I be looking at something else, like wheel bearing, LCA, etc?
Thanks for your time guys.
Old Dec 3, 2010 | 08:17 AM
  #6543
kefanman's Avatar
* Most likely. The front O2 sensors are what let the engine run in closed loop mode.
* I've had good luck with Denso O2 sensors. I've also tried NTK and Beck/Arnley sensors and for some reason they both died within a year, my Denso sensor has lasted 3 years so far though. No experience with Bosch sensors.
Old Dec 3, 2010 | 08:23 AM
  #6544
kefanman's Avatar
Definitely. But you can check them yourself to be sure -- get your front end off the ground and check for play in the tie rods.
Yes, you will need an alignment after replacing tie rods. Some alignment shops will give you a free one if you just bought one from them within 6 months.
Old Dec 3, 2010 | 11:30 AM
  #6545
Mr Yaaoowwa's Avatar
question about audio...
Hey guys, i'd really like some help on this.
I got an 03' Max GLE. Bose system, no navigation.
I've been searching around for an in-dash navigation unit.
Im just not sure if i have to stick with a flipout unit or can i go with an actual in dash unit?....
ive been searching around but havent found any real answers. i joined the forum because you guys seem to know everything about these things..hahaha
thanks
Old Dec 3, 2010 | 01:36 PM
  #6546
kefanman's Avatar
thanks
Try the 5th gen forum.
I imagine anything DIN would fit. See for example: http://forums.maxima.org/5th-generat...-pictures.html
Old Dec 4, 2010 | 01:01 PM
  #6547
Luis99maxi's Avatar
THANK YOU THIS REALLY HELPS.
Old Dec 4, 2010 | 05:39 PM
  #6548
zat328310's Avatar
help
so about a week ago i put a new idler pulley on my 95 maxima after it fell off while driving tonight while i was driving my radio started to flash i started losing power no accelaration dim headlights i tired to turn my overdrive off then that light started to flash then the car died and had no power at all checked and the belt didnt fall off the pulley i just replaced and i never got a battery indicator light telling me anything was wrong with my battery thanks for all the help in advance
Old Dec 4, 2010 | 06:27 PM
  #6549
RA021526's Avatar
First of all, for ease of reading, please use punctuation.
I suspect your belt was not properly tightened. That will stop the alternator from providing output. If you're not sure how tight it should be, you can get a deflection gauge at a tool store for about $20 probably. The specs are in the FSM.
Old Dec 5, 2010 | 06:20 AM
  #6550
Any ideas??
Any ideas?? Kind of stumped here.
Old Dec 5, 2010 | 06:53 AM
  #6551
jholley's Avatar
Give your air intake parts a good cleaning:
http://forums.maxima.org/4th-generat...g-dummies.html
A need to hit the gas pedal to get a start can also idicate lack-of-air.
Old Dec 5, 2010 | 11:29 AM
  #6552
Rebelution's Avatar
Hey guys I'm looking at buying a 99 Maxima and I need some advice. It's a bright red limited edition with a 5 speed. The guy wants 2500 for it and he's not budging on the price. I took it for a test drive and everything seems fine. The interior is immaculate and the exterior is in good shape. The only problem is it has 230k miles. I was just wondering if you all could tell me some things to look out for. My dad used to have a 2000 Maxima and it would go through ignition coils left and right but other than that it was a great car. I know Chevy trucks inside and out but I don't know the first thing about these cars. Thanks for any advice.
To clarify what I'm asking, what are some common problems on these cars, what should I look look for when I'm checking it out, is 2500 a rip off, is it even worth buying with 230k on the clock? Any help is much appreciated.
Old Dec 5, 2010 | 12:43 PM
  #6553
Great link, thank you.
Thank you for the link. I am going to have to wait for a warmer day to tackle all of that though.
Old Dec 6, 2010 | 02:47 PM
  #6554
RA021526's Avatar
230k is nothing. There are lots of people on the forum with much more. Red is pretty rare. The price doesn't sound too bad either. Just make sure the body is in decent condition.
Moog are decent. You will definitely need an alignment afterwords. When you're taking off the outer tie rod, count the threads so when you replace the outer tie rod (screw it back on to the inner tie rod) you're pretty close to being aligned. Definitely get it aligned right after though. If you're going to be replacing the inners, check the outers and the control arm ball joint and bushings and check your suspension. If you have to replace them, might as well do it now and only pay for a single alignment.
Old Dec 6, 2010 | 04:14 PM
  #6555
kstauss's Avatar
1999 evap error codes
had error code for bad ks - replaced ks and code cleared
also had code p0446 - replaced vapor can vent valve code did not clear and added code p0443.
I've checked the purge valve solenoid with 12v and it does fire but doesn't seem to be doing anything while the engine is running.
What am I missing here?
Old Dec 6, 2010 | 04:23 PM
  #6556
kstauss's Avatar
the can vent valve is mounted right in front of the charcoal canister. The canister has a hole in it that the valve pushes into. The other side of the valve has the power connector and another hose port which should be routed out to behind the car.
Old Dec 6, 2010 | 07:58 PM
  #6557
Phx_Max's Avatar
hey guys still a noob here, i recently changed out the water pump on my 95 maxima. i think i might have moved the crank before installing the new pump, it runs fine but it feels alot slower... could i have thrown off the timing? if so how can i go about adjusting it again. i havent found ne thing on the timing chains
Old Dec 7, 2010 | 02:02 PM
  #6558
bigh1t's Avatar
99 maintainence 'upgrades'
I have a '99 SE with 174K on it, mostly used for trips and my wife's running around. She's tired of it and I get to play a little bit. I am not real experienced or have a lot of space to work with but is there a list of 'starter' mods or maintainance steps I can use? (I've seen references to using a 300Z fuel filter for ex.)
The forum has a huge amount of information and I may have missed this if it exists. Thank you.
Old Dec 7, 2010 | 03:39 PM
  #6559
kingw323's Avatar
Noisy tensioner Pully?
I had my alternator replaced yesterday and they said I needed to replace my idler/tensioner pully. When I started it up i did hear a sort of medium/high pitched metallic noise coming from that area, but it seemed to go away. Fearing that the pully would seize up, I replaced it today with a new one from autozone. Now it's even louder. I hate autozone, but they were the only store with the pully in stock. Does this sound like I bought a bad pully or is something else going on? I never noticed the sound before they replaced my alt, but I am not 100% sure.
Old Dec 7, 2010 | 05:16 PM
  #6560
raddoggy74's Avatar
sweet thanks 95franklin for the help. i will let you know the outcome.
