NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jan 23, 2012 | 12:19 AM
  #8201
2brosgixxer's Avatar
Originally Posted by deloa84
Hey hows it going guys? I am relatively new to the org site. I am currently working on my 99 maxima doing a 3.5 swap. I am about 85-90% done. I still need to do all the wiring Other than that everything seems to be going well...
Got a couple of questions, first...
I need a Pathfinder throttle body. Is anyone selling one I can use? I am having a hard time finding one at local junk yards in AZ. If not, ima go to ebay...
Second...
Is there a way to hook up the EVAP system? I went through a number pages on this and I am still rather baffled . Some ppl left it out some ppl bypassed... I pretty sure il need it to pass emission here in AZ. Any recommendations?
Finally...
I am pretty sure my friend has it down on how to do the EGR connections but any ideas or threads where I can find more info.. Im still a bit confused on this matter..
Also... how do I view the stikies?
Stickies: http://forums.maxima.org/4th-generat...a-1995-1999-6/
To find the stickies, just go to the bottom of this page to the drop down that says forum jump, click on whatever generation you want then right at the top of the page will be all the stickies associAted with that gen. But here's the 4th gen link to get you started.
Guy that may be selling pathfinder throttle body: http://forums.maxima.org/4th-generat...le-feeler.html
Old Jan 23, 2012 | 01:31 PM
  #8202
donniemo's Avatar
was just wondering if anyone has any ideas on what i need to do.
Originally Posted by donniemo
hopefully i say this clearly the first time around =/ having a hard time figuring it out myself.
The problem i am currently having is:
When my gas tank gets lower and lower, my car tends to have a harder time picking up speed. I've never been in a car with a slipping transmission, but i think that the symptoms it gives are close to of that.
The RMPs would jump and drop 500 of where it should be, and picking up speeds gets painfully slow.
at a full tank, all is fine. at 3/4ths tank is when it starts acting up, and 1/2 of a tank i can hardly drive it 15-30 minutes. and the problem has been getting worse and worse. it use to be at 1/3th of a tank is when it would start acting up.
I haven't gotten it this low in a long time, but at 1/4 of a tank it would stall when i took turns (not driving crazy) The car sat for 3-4 years because my parents would not fix it, so they gave it to me when i got license.
The original owners did not take care of it, and my parents took some care of it, but not enough.
I've been using maxima org for trouble shoot and fix all my problems so far, but cant seem to find this one.
ALSO, As my gas tank gets emtier, my MPG drops. at a full tank i average 18-19 at 3/4 i start to average 13-14... any ideas?
The problem is just now starting to happen just before 3/4 of a tank.
did wait a few days before reposting. I have searched google. if i am not clear on anything i can try to clear up. I can also make a video of what it's doing on a full tank as well as when it gets lower.
Thanks for any help given,
Donnie
Old Jan 24, 2012 | 10:38 AM
  #8203
cashoit's Avatar
Donnie
sounds like fuel pump to me
Old Jan 24, 2012 | 10:56 AM
  #8204
cashoit's Avatar
Originally Posted by 99maxwell
i just bought my 99 maxima se auto less than a month ago. im new to nissans so i didnt know if this was normal or not. OK so here is my concern.. sometimes when i start the car it goes up to 2000 rpm when first started then drops to a lower idle. but sometimes i notice after it does that it goes rite back up to like 2000 rpm. sometimes the needle even goes a tinny bit over it the 2000 rpm mark but not much. and it does it for like a decent amout of time around or sometimes more than 5 mins. then when i go to drive it i put it in gear and it like drives itself and shifts itself from first to second if im not stepping on the brake to slow it down. it sometimes even goes over 20 mph if i just let it coast.. i live in new england and its cold but this doesnt happen all the time! mostly i can start the car in like 10 degrees and it will be fine and smooth idling and driving but sometimes this situation happens...and its confusing me because even after driving for a little bit and the car is warmed up and i shut the car off to go into the bank or gas station or something then come back out and start it up this happens. so any help would be appreciated thank you!
normal nissan behavior. all of my maximas have done the same. U can clean the TB and IACV see if the idle smooths out but i wouldnt worry too muych
Old Jan 24, 2012 | 07:56 PM
  #8205
deloa84's Avatar
Thanks 2brosgixxer... I do appreciate it...
Old Jan 24, 2012 | 08:25 PM
  #8206
Tabooza's Avatar
Need Help!!
Hey what does it mean when engine oil goes into one(#4) of my spark plug cylinders and what should I do or replace thx for any help
Old Jan 25, 2012 | 10:21 AM
  #8207
DennisMik's Avatar
If the oil is in the tube where you put the spark plug socket in order to remove the spark plug, it means that you need to replace the valve cover gasket and the seal for the spark plug tube.
If the oil is getting into the cylinder as you stated, then either the cylinder head gasket is blown or the cylinder head or engine block is cracked. If this is happening, the car is burning oil and making a smoke screen.
Old Jan 25, 2012 | 10:24 AM
  #8208
cashoit's Avatar
it means u need to replace your spark plug tube seals.
The tube seals are part of the valve cover replacement kit. replace the valve cover gasket, Throttle body gasktet and any other gasket required to get to the valve cover gasket.
Do a SEARCH. There is a how to on the org for replacing the valve cover gasket.
Old Jan 25, 2012 | 04:01 PM
  #8209
Tabooza's Avatar
Thx Dennis, and there is no smoke screen or smoke coming out it just has oil in the #4 tube, I called it cylinder cause its circled shape. So I'm guessing I need to replace the valve cover gasket and the seals, what about O-rings?
Old Jan 25, 2012 | 04:04 PM
  #8210
Tabooza's Avatar
Hey cashoit, do you think u can tell me how to search on the org (guessing this forum) or do u mean I have to go one by one looking for this subject on here thx
Old Jan 26, 2012 | 08:32 AM
  #8211
Phromethius's Avatar
Top of the thread, Search This Thread tool or the search bar right under you login screen. It will pull up all posts with your search phrase. Might have to try a few times to narrow down your wording. But it does work
Old Jan 26, 2012 | 09:34 AM
  #8212
DennisMik's Avatar
I am not sure of what o-rings you are referring to. All you need is the valve cover gasket and the spark plug tube seals.
http://www.courtesyparts.com/13276-s...ml?cPath=1783&
Old Jan 27, 2012 | 01:57 PM
  #8213
99maxwell's Avatar
alright well i was going to take your advice and just let it be but then yesterday my check engine light came on. so i brought it to my machanic and he plugged it in and said it is probably the
"knock sensor" and the "egr valve" he told me to get the parts and he would put it in for me so i went to autozone to get an idea of how much this would cost me and all i know is it is $125 for the knock sensor and i spaced and forgot to ask them to look how much it would be for the egr valve. i would just do this job myselp but im not all that mechanically inclined. how much would this cost me to do threw i normal mechanic? and does anybody know how much it is for the egr valve? also is this what would cause my problem i originally posted? please help! thanks for the help in advanced.
Old Jan 27, 2012 | 03:20 PM
  #8214
Tabooza's Avatar
Hey org. what can be causing my car from not turning on with out me flooring the gas pedal so it doesn't die on me any help well be good thx
Old Jan 27, 2012 | 04:54 PM
  #8215
jynx31k's Avatar
Im having issues with an inconsistent start on my 1998 maxima GLE. I went to autozone and the printout gave me two codes, P0325 which is for the knock sensor and P0340 which is for the CAM sensor.
The car will crank and crank but wont catch sometimes. Other times it starts right up and run without a hitch.
Could a bad CAM sensor cause the knock sensor code?
Old Jan 27, 2012 | 05:00 PM
  #8216
pmohr's Avatar
No more Maximas...
First, the codes don't mean those parts are bad, they just tell you that something may not be right with that part or circuit. They are far from a diagnosis in and of themselves (short of P0600 or similar).
For how much the EGR valve is, why don't you just check parts store websites with your zipcode? Actually, what was the code, insufficient EGR flow?
For the knock sensor, don't spend $125 locally, just order a cheap one from eBay, no real difference. $100 savings there. The KS has nothing to do with your problem.
As for you original problem, I wouldn't be suspecting the EGR valve, more of a potentially sticky IACV plunger, or possibly a switch keeping the PS/AC idle-up solenoids intermittently energized.
Does it not start without being WOT? That's clear flood mode, where the injectors are disabled on startup.
Do you have to be WOT for it to even idle? If so, you have some serious issues.
Throwing any codes? Did this just start happening randomly, or was it an existing problem that just got worse? Did you do anything, have anything done, or did anything happen to the car immediately prior to this becoming a problem?
Old Jan 27, 2012 | 05:01 PM
  #8217
pmohr's Avatar
No more Maximas...
Chances are the KS code has been there for a while, it won't trip the CEL.
Yes, a bad CPS can cause starting issues. Without being able to scope the sensor, you're pretty much limited to checking the wiring between it and the ECU, and if fine replacing the CPS.
Old Jan 27, 2012 | 10:50 PM
  #8218
comingup's Avatar
Do you have any leaks in your exhaust? That could be triggering the code for the EGR valve.
Old Jan 28, 2012 | 12:47 AM
  #8219
Laevateinn's Avatar
I'm not sure if a CAM sensor malfunction can trigger a knock sensor code. Although they're both related to timing and both circuit codes. Check the resistance for their connectors if their in spec. Check the wires for fraying as well. Maybe the CMP and KS wires meet somewhere and they were damaged by something physical.
What's the code? There's a possibility that the problem is not the part itself.
Old Jan 28, 2012 | 11:31 AM
  #8220
99maxwell's Avatar
there are no leaks from what i see and hear the exhaust seems solid.
Old Jan 28, 2012 | 11:34 AM
  #8221
99maxwell's Avatar
[quote=pmohr;8343830]First, the codes don't mean those parts are bad, they just tell you that something may not be right with that part or circuit. They are far from a diagnosis in and of themselves (short of P0600 or similar).
i went back and got the codes that came up today. i got P0400 and the other one is P0325. also i found out that the egr valve was pretty much the same price as the KS. so if i were to order the KS off ebay should i order the egr valve off ebay as well? why is my parts store charging me $100 more for something i can order off ebay for $25 bucks? also i now understand that the codes don't mean the parts are bad, like i said im not all that mechanically inclined haha..is there any way i could check if there is something wrong with the part or circut? could an IACV problem come up with either of these 2 codes i have?
Old Jan 28, 2012 | 05:06 PM
  #8222
moeraider's Avatar
I just changed the plugs in my 95 maxima because I thought there may be a problem with them or coil packs. I found by removing the electrical plug from each one that the back middle cyclinder was not working. I changed the coil packs and still nothing on the middle cyclinder with another working coil pack. It seems I am not getting any fire to that particular cyclinder. What should my next step be?
Old Jan 28, 2012 | 05:16 PM
  #8223
pmohr's Avatar
No more Maximas...
P0400 is no EGR flow, which is more than likely just carboned up EGR tubes.
I only suggest the KS off of eBay because of forum experience with it. Most of the time, a price too good to be true actually is.
Unless you can do anything yourself, you'll have to bring the car in for service somewhere, preferably somewhere that doesn't throw parts at the car because 'that's what the code says'.
You need to figure out why that cylinder isn't firing. Check for fuel, check for spark, check compression.
Old Jan 28, 2012 | 07:36 PM
  #8224
moeraider's Avatar
How do I check for fuel,spark,or compression? Is there a way to check the wire that plugs into the coil pack? It seems to go into a harness and then all those wires plug into something beside the intake maybe?
Old Jan 28, 2012 | 08:37 PM
  #8225
pmohr's Avatar
No more Maximas...
It sounds like it would be best for you to take it to a shop for a prior diag.
Old Jan 28, 2012 | 08:44 PM
  #8226
moeraider's Avatar
After checking closely the wire that plugs into the coil pack on the middle back cylinder seems to go in the harness and over to the idle air control valve. This code P0505 came up on the computer. Is there any way to check/clean the idle air control valve to see if this is causing the issues of missing? My car seems to idle low when stopped and seems to surge or miss while stopped. I just want to find out if there is a way to check any of this without just replacing parts.
Old Jan 28, 2012 | 08:51 PM
  #8227
pmohr's Avatar
No more Maximas...
No, the wires that are specific to the coil don't go to the IACV, why would they?
A faulty IACV would not cause a single cylinder misfire.
Yes, there are ways to check everything, but as I've said, it looks like it'll be best if you take to a shop for a proper diag.
Old Jan 29, 2012 | 01:29 AM
  #8228
chexmex11's Avatar
I have a 96 Nissan Maxima V6 3.0L and I am wanting to replace the spark plugs. I have been having idling problems and because those plugs that are installed now have not been replaced in a VERY long time.
I want to know what are the best spark plugs for my car. I searched online and almost bought the Bosch Platinum +4. I then found on other sites saying that this was a bad idea and that I should stick with the standard NGK's.
I mostly use my car in town, but occasionally I take long trips highway trips.
My Question: Which spark plugs are the best for my car.
Old Jan 29, 2012 | 07:49 AM
  #8229
pmohr's Avatar
No more Maximas...
As you've heard, Bosch is a bad idea. Just go with the OE plug, NGK PFR5G-11. You could also use NGK coppers if the platinums are too costly, they just don't last as long.
Old Jan 29, 2012 | 06:50 PM
  #8230
99maxwell's Avatar
[quote=pmohr;8344712]P0400 is no EGR flow, which is more than likely just carboned up EGR tubes.
alright thats good to know thankyou. is code P0325 for the KS? and is there any way i could check if it needs to be replaced or not before i just buy a new one?
Old Jan 29, 2012 | 06:53 PM
  #8231
pmohr's Avatar
No more Maximas...
Yes, P0325 is the KS.
Code: P0325 | Description: Knock Sensor
Diagnostic information is provided in the FSM, starting on EC-300.
Old Jan 29, 2012 | 07:37 PM
  #8232
99maxwell's Avatar
alright sweetdeal, well i just looked up a forum on how to replace a KS and it doesn't look that hard just a pain in the butt to squeeze in that area so i might give it a shot. are there any forums about egr valves and how to clean the the egr tubes that you know of by any chance? btw, thank you for the help i really appreciate it.
Old Jan 29, 2012 | 11:07 PM
  #8233
Laevateinn's Avatar
Most of the time, it's the KS but check the harnesses first.
Old Jan 29, 2012 | 11:16 PM
  #8234
Go here......
http://forums.maxima.org/4th-generat...on-maxima.html
This will be your best friend. It has how to's for the EGR and KS replacement. I just did my KS the other day, I found the best way to get in there is remove your air intake box and tubes then stand at the driver side fender and reach your left hand in there to loosen/tighten the bolt once you get it loosened with a 12mm wratchet. But, visit the link I gave you, it will answer A LOT of your questions you may have.
Old Jan 30, 2012 | 04:47 PM
  #8235
blindelement's Avatar
ac compressor
hi can some1 help me i have a 96 maxima and my ac compressor is makeing a bad squealing sound so i do not fell like wasting the money on 1 so i was just going to take it off and buy a smaller belt to put on that way i do not have the ac compressor any to make the sound go away and to lose weight i do not care if i have ac i drive with the windows down anyway is that ok to do dos it matter if it is there r not
Old Jan 30, 2012 | 04:49 PM
  #8236
pmohr's Avatar
No more Maximas...
Yes, that will work. Search, the belt size has been given a dozen times in this thread alone, not to mention all across the 4th and 5th gen forums.
Old Jan 30, 2012 | 04:52 PM
  #8237
coilovers
cool ty hi and i just ordered nex coilovers for my maxima do u know if thay r any good and where can i find the belt size in the fourms r do u know it
Old Jan 30, 2012 | 04:55 PM
  #8238
pmohr's Avatar
No more Maximas...
Never heard of them.
And for the belt size, did you even read my last post? If not, read it. If you did read it, you obviously didn't read all of it; read it again.
Old Jan 30, 2012 | 05:31 PM
  #8239
blinker
ok sry ty and i need to see if some1 can help me with this to my maxima is a 96 and my blinker fuse well not stop blowing it well blow as soon as i turn on my blikers can any1 help me with that
Old Jan 30, 2012 | 05:40 PM
  #8240
pmohr's Avatar
No more Maximas...
It might do you well to use proper spelling and actual words instead of numbers or ridiculous abbreviations; the more difficult it is to understand you, the less people will care to read and try to help.
By 'blinkers' do you mean the turn signals, or the hazards? I'll assume turn signals, and again assume 'blinker fuse' meaning the 7.5a 'turn' fuse in the interior fuse box.
Does this only happen when you use the left turn signal, or the right turn signal? What about the hazards?
Did this just start happening suddenly, or was it an occasional thing that started getting worse? Did you do anything, have anything done, or did anything happen to the car immediately prior to this starting to occur?
Have you checked all of the turn signal bulbs, sockets, and exposed harness for signs of corrosion or chafing? Have you tried unplugging all of the bulbs to see if it would still blow the fuse?
