NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Dec 23, 2007 | 09:24 AM
  #1241
Somekid517's Avatar
The placement is obviously important or elce its not going to fit corectly...its not the size im worried about its where the 3 inch hole goes...Thats the reason they have those templates.
Old Dec 23, 2007 | 10:18 AM
  #1242
ScottS's Avatar
Winter Tires
I also looked at the Hankook ones. They look great and are studdable. They were my first choice. I ended up going with a Pirreli Winter Carving as they rated very high and I got a steal of a price on them.
I have used Toyo Observe G02 for years. I was very happy with them. Used them playing around ice racing with my Chrysler Laser a couple of times when they were new.
I was surprised with the amount of good reviews on the Continental's during my research.
The Blizzak, not sure if it is still the case, but at one point the 'special' rubber was only half way through the thread depth. So one you wore the tire down, it was not so hot any more.
Originally Posted by CasinoRoyale
Anyone have any experience with these snow tires?
One better than the other, or are they all pretty much on par with each other? I live in NJ.
Hankook
http://www.1010tires.com/tire.asp?ti...inter+i%2APike
Toyo
http://www.1010tires.com/tire.asp?ti...serve+Garit+KX
Continental
http://www.1010tires.com/tire.asp?ti...king+Contact+3
Bridgestone
http://www.tirerack.com/tires/tires....zak%20REVO%201
Old Dec 23, 2007 | 05:00 PM
  #1243
icaghost's Avatar
Misc Engine/Transmission Problems
My 97 GXE just hit 150k and it's developed a couple problems - I'm wondering if any of them are possibly related, and if anyone who is past 150k themselves had a similar experience.
I have engine codes P0150 (O2 sensor circuit, bank 2 sensor 1) and P0110 (Intake air temperature sensor) and the following problems:
- When I start the car, it idles at about 1.2-1.4k rpm instead of the normal ~700 (this goes away when I put it into gear)
- When I accelerate, something produces a low hum when the engine gets to exactly 2500rpm (especially in low gear) but goes away at about 2.6-2.7k
- Transmission jerks/slips sometimes, especially from 1st to 2nd (its an auto)
I just did another oil change and I had my mechanic add more transmission fluid, but nothing changed. I also replaced the battery back in October, which I'm thinking might have something to do with the idle. Also, I'm wondering if I should do something about the codes since from the code thread I understood that at least one of the problems is only related to emissions and not actual performance. Thanks for any advice in advance.
Old Dec 24, 2007 | 09:22 AM
  #1244
Nrw's Avatar
Nrw
Hi I was wondering if anyone new the part number or size of the filter needed for a CAI. I bought one off of a friend and it needs a filter. Any help is appreciated.
Edit: I forgot to add this is for a K&N filter
Old Dec 24, 2007 | 11:56 AM
  #1245
NmexMAX's Avatar
dot dot dot ...
Measure the OD of the ‘tube’ where the filter would be and go on K&N's website and search for that size and you’ll be where you need to be.
Old Dec 24, 2007 | 12:06 PM
  #1246
Nrw's Avatar
Nrw
so the height doesnt matter? thats where I was lost.
Old Dec 24, 2007 | 09:56 PM
  #1247
Cdg2125's Avatar
ok again..measure it and cut the hole. Put the intake on as best you can (the long pipe won't fit right cause there is no hole but you basically need to put it on and draw the circle where the tube lines up.
Old Dec 25, 2007 | 10:13 AM
  #1248
angel_elle3300's Avatar
Go Broncos!
OK I have a problem with my 1997 Maxima, and I was hoping someone may know whats wrong with it.
It won't start - sometimes - I don't believe its the starter because I just replaced that a few years back. Thinking it maybe the battery I replaced that, that wasn't it. The alternator was replaced more recently than the starter. The car will start after it has been sitting at least 2-4 hours from the time it was shut off. Sometimes on short trips to the store or the gas station it will start back up - but sounds like it may be struggling a bit. Also sometimes when it has been sitting about 2 hours and I try to start it, it will only start if I crank it really slowly from accessories to start. And that only works once!
There is also this problem with the heater, and I've taken it to several different places and they don't know whats wrong with it. They think I am nuts. And I am starting to think these two problems may have something to do with each other. Ok so the heater will only get hot when the car is sitting in one spot. Once I am in motion it starts to cool, and the gage gradually drops back down to below cold. I've asked them to replace the thermostat and flush the radiator, which they did but didn't remedy the problem.
Are these two seperate problems or can they be connected? Does anyone know whats wrong, because I miss my car! Please help me if you can!
Merry Christmas!
Old Dec 25, 2007 | 06:06 PM
  #1249
maxud's Avatar
Did I buy the right Axle?
I have 95 Maxima SE (Leather,ABS,Sunroof,Bose). At last oil change I noticed that the CV boots are ripped on both front axles. After extensive reading on this forum, I decided to buy new Axles from Advanced Auto Parts. I noticed that the Limited Slip Differential is an option you have to choose buying a replacement axle. I found a site online that had me look up ID number and looking at a specific position you can tell if it has LSD or not. It appeared that my car does not have LSD. Today I removed both axles and saw that my Driver side (Left Axle) has something Like a big bump right in the middle of it. The replacement Axle does not. Can somebody please educate me on how to find out if my car has LSD or not?
Below is the picture of old and new axles:
http://members.***.net/m.kosover/leftaxle.jpg
Another question: when you replaced your axles, did you replace inner and outter seals? I am trying to figure out how to get the inner seals out. While driver side is accessable, the passenger side is nearly impossible to get at?! Is there a particular technique that works better for it?
The outter seals are inside the wheel hub. Advanced Auto sold me outter seals instead of inner. Should I replace those as well?
thanks in advance,
Max
Old Dec 25, 2007 | 06:51 PM
  #1250
gen4maxima536's Avatar
thanks in advance,
Max
that big bump is a dampener of sorts, i wouldn't worry about not having it.
usually when you replace an axle you are suppose to replace the seals in the transmission housing. you only really need to replace the wheel seals if you are putting in new bearings or they appear to be leaking.
the seals for the hub are the same inner and outer (ie interchangeable)
Old Dec 25, 2007 | 09:22 PM
  #1251
JDMvq30de's Avatar
Hey guys i have a 99 maxima and i was wondering how do you disconnect the ac? I've always had hondas and just cut the belt. But this car uses a drivebelt. do I just need a different drivebelt? whats the part number? and last question: do i need to do anything special when i replace it? Thank you in advance
Old Dec 25, 2007 | 10:40 PM
  #1252
http://forums.maxima.org/showthread.php?t=546912
Old Dec 26, 2007 | 09:10 AM
  #1253
firemedic3426's Avatar
Startin' Out
Electrical problem any Ideas????
On a 95 maxima the battery discharges if not cranked in a few days. The battery and alternator have been replaced. I cannot think what would cause this. Also chilton's does not have any info on this topic. Any response would be greatly appreciated. Thanks in advance.
Old Dec 26, 2007 | 03:34 PM
  #1254
sirmixalot42691's Avatar
Where are the oxygen sensor connectors in a 1996 Maxima? Thanks
Old Dec 27, 2007 | 01:08 AM
  #1255
the picture has been posted numerous times, but one is in the cat, then one right after the manifolds in the y pipe where it is still vertical coming down from the manifolds.
Old Dec 27, 2007 | 01:32 PM
  #1256
blackflag's Avatar
fuel filter
i think its about time to change my fuel filter. i heard that you can use a 300zx filter. now is that the 300zx TT or just a plain 300zx? would i need to do any modding to fit the new larger fuel filter into my car?
Old Dec 27, 2007 | 01:51 PM
  #1257
maximized98's Avatar
Addicted to the Org
It is a little bigger than ours, but it will fit fine. I cannot think right now on the filter itself. I would go with a regular 300zx. Not sure if there is even a difference in the tt versus the regular.
Old Dec 27, 2007 | 02:30 PM
  #1258
blackflag's Avatar
thank you, so its just the z32 300zx fuel filter. haha, just to make sure.
Old Dec 28, 2007 | 11:01 PM
  #1259
blqrider's Avatar
WHICH LOOKS BETTER?
Smoked taillights(white and red lightly smoked) or "redded out tails on a 96 maxima?
Black with black leather interior.
Old Dec 29, 2007 | 01:53 PM
  #1260
FishyMan's Avatar
My back seat right side, power lock isn't working. Does anybody know why?
All the rest is fine though.
Old Dec 29, 2007 | 05:49 PM
  #1261
maxud's Avatar
As it turns out the idiots at Advanced Auto Parts sold me the axle for Automatic transmission. It was pure luck that I figured it out after the fact. When I finally got the right part, it had the same bump in the middle of the axle. I still have no clue what it is, but one thing is certain. Left axle on 95 Maxima MT should have it.
thanks,
Max
Old Dec 30, 2007 | 02:06 AM
  #1262
thanks,
Max
all the OE ones should have it on there, but remans are probably hit or miss.
Old Dec 30, 2007 | 07:56 AM
  #1263
black_maxed95's Avatar
it could be the window switch on that door. if that goes bad the lock wont operate either. check if the window works. if the window doesnt work either you will need to replace the switch
Old Dec 30, 2007 | 09:32 AM
  #1264
KRRZ350's Avatar
Yup, and they are the same between N/A & TT
Old Dec 30, 2007 | 06:20 PM
  #1265
FishyMan's Avatar
the door does open. and the window works fine. just that POWER lock. like when i control it wont work. i thought it was a fuse or electrical proble.
Old Dec 30, 2007 | 08:35 PM
  #1266
johnnyboy's Avatar
I own a auto 4th gen ,when i put the car in reverse there is a big thud any idea what this could be?
Old Dec 30, 2007 | 08:39 PM
  #1267
ROCKART's Avatar
wants an I35
engine mounts (the tranny mount) or it could just be a failing transmission. anyway thats a pretty serious thing. i would get it checked out asap.
Old Dec 31, 2007 | 01:20 PM
  #1268
98SEATMAX's Avatar
98SEATMAX
I'm a newbie - have a 98 SE with auto trans - I'd appreciate some pointers from the gurus here about nissan tuners and specialist mechanics in the SF Bay Area
Old Dec 31, 2007 | 01:25 PM
  #1269
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/forumdisplay.php?f=13
Old Jan 5, 2008 | 05:02 PM
  #1270
Go Broncos!
I hope this is ok!
Not sure on the rules about reposting, But I didn't get any kinda reply last time and I was hoping for something even an "I have no clue" I just need to know that I am not going crazy! So here is the post I posted about 2 wks ago.
Old Jan 5, 2008 | 06:59 PM
  #1271
sparkplug5225's Avatar
DEProgram keyless remote on 96 max
Here is my situation. I read and used the sticky on how to program a keyless remote for the maxima.. MY problem is I have to maximas and now the keyless remote is working both cars at the same time. I need to deprogram one of the maximas..Is there some sequence I can do to do this..
Old Jan 5, 2008 | 07:23 PM
  #1272
Zcyrus1's Avatar
Possibly Exhaust Problem
First off, just wanted to say hey to everybody on here, Just getting into the Nissan scene from Honda. So anyway here's my question. Im thinking of buying a 1995 Maxima with 151,000. The interior and exterior are mint and beautiful. The Clutch is brand new and the car runs great........... Except the guy says theres a hole in the flex pipe and the car is just a little loud, not to bad at all, now when I was driving it the car seemed great except it felt ALMOST like it was misfiring. Now this is really only my second 6 cylinder and I know when a 4 cylinder is misfiring. It's not even that bad and I could just be worried over nothing, but could a hole in the flexpipe cause it to slightly vibrate like a misfire? Also I think a front motor mount is bad. Thanks Guys!
Old Jan 5, 2008 | 10:57 PM
  #1273
on the car you dont want say remote #1 on, follow the first part of the instructions of putting the key in and out, that will clear all remotes from that car. then just follow the instructions to re add the one you actually want (#2 per say) to use on that car.
Old Jan 7, 2008 | 01:49 PM
  #1274
m00njal's Avatar
So, where can I donate now to get forum search access? The links on the first post of this forums now go to another thread (issue with forum upgrade I guess?)
Also, using google search, I tried to find something about fixing the seatbelt tightening mechanism, but nothing came up? Is there a guide or some general knowledge for fixing a seatbelt that suddenly doesn't retract anymore ? Thanks
Old Jan 7, 2008 | 04:23 PM
  #1275
here's more of free searching:
http://forums.maxima.org/showthread.php?t=282780
and straight up donations here:
https://maxima.org/index.php?pageid=Donations
Old Jan 7, 2008 | 09:36 PM
  #1276
tschaap's Avatar
98 Maxima starting questions
I have a 98 Maxima with 123K on it. about a month or so ago it started doing the following:
when you first start it, would turn over fine and fire on the first or second revolution, but would stall after 2-4 seconds this will repeat 2-3 times before it will stay running. Most time you have to give it some gas to keep it running. after that it will start fine until it sets overnight or if it is cold and it sits for a couple of hours.
i suspect that there might be issues with the fuel system, but would welcome any help.
One last question, i'm getting alot of road noise from the car which seems to be originating from the rear wheel bearings. has anybody had this problem.
Old Jan 7, 2008 | 10:06 PM
  #1277
eta_vu's Avatar
Fuel injector
Originally Posted by eta_vu
Hey everyone,
I was driving down the highway earlier today and the horrid check engine light began blinking...so I pulled over to check to see if I could see anything noticeable. Well, i noticed the engine was shaking a lot more than usual...
Drove home and did a check engine diagnostic.
This is what I came up with:
0608 - Cylinder 1 misfire
0304 - Knock sensor
So...now I just need some advice on what to do. And for the knock sensor, does anyone know where I can get cheap sensors? Thanks
So the problem wasn't a bad coil or bad spark plugs but a dead fuel injector! All other injectors tested at 12 ohms while cylinder 1 injector didn't test at any ohms at all. Took apart the IM to get to it and it's removed, waiting on the part right now to get shipped in so I can install it. I took pictures as I did this job. Let me know if anyone needs them to help locate things because the pictures on the write-up are just terrible but text instructions are good!
Thanks maxima.org, couldn't have done this job without you all!
Old Jan 7, 2008 | 10:49 PM
  #1278
#1berettaman91gtz's Avatar
I'm looking for some ss headers & after market cat back exhaust for my 95 maxima. if anyone has either for sale let me know your price .
Old Jan 8, 2008 | 12:20 AM
  #1279
look in the 4th gen FS section
Old Jan 8, 2008 | 01:28 AM
  #1280
I have looked in the fourth gen for sale section for about two weeks now and there hasn't been anything listed there. there could be someone on this forum with what I'm looking for and would see this tread but it would be easier if I could list a wtb in the fs section but this is the only place I can post. so I posted here.
