NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jul 7, 2008 | 03:57 PM
  #1801
J RO 9's Avatar
how do i reset the check engine light?
i want to do it so i can pass an inspection and get the problem fixed after. i need to pass an inspection on or before friday
Old Jul 7, 2008 | 06:20 PM
  #1802
internetautomar's Avatar
mod or sell?
just get it scanned and cleared.
though I'd bet it will pop up again right away.
Old Jul 7, 2008 | 07:31 PM
  #1803
JP_McCann's Avatar
ok so my aunt and uncle have a maxima and the antenna mast broke off after a trip to the car wash. i have searched about how to remove the mast and everything, but i am having trouble removing the old mast. how do i remove the last piece of the antenna. it is the little short piece that is on the bottem with the black plastic piece on it. I got the black piece off but can't get that last little section off it seem like it is getting stuck on something. any help would be great.
JP
Old Jul 7, 2008 | 07:33 PM
  #1804
black_maxed95's Avatar
You can reset it by turning the screw on it with a screw driver...its in the stickies...
BUT
It wont help you pass inspection. The reader will detect the ECU was reset and is still in learning mode...they will fail you and have you come back.
Old Jul 7, 2008 | 07:35 PM
  #1805
JP
You need to take the whole motor out. It is held on by some 10mm bolts from inside the trunk. Once you have the motor out you will need to take it apart to fix the antennae.
Did you buy a replacement antennae from ebay? Just curious, when I fixed mine I bought the antennae from ebay for like $8.
Old Jul 7, 2008 | 07:54 PM
  #1806
JP_McCann's Avatar
dealer. so how do i remove the whole motor. is everything easy to get to from the jack area. maybe i'll head down to the dealer for some pictures and things.
JP
Old Jul 7, 2008 | 08:02 PM
  #1807
Ya its very easy to take out. Just peel back the lining a little bit, take out the jack and lug wrench. Take out the 3 (i think 3) bolts and the whole motor will come out the hole where the jack was. You will have to unplug it and take off a hose but all easy. I hope this isnt the reason the car is at the dealership...
Old Jul 7, 2008 | 08:27 PM
  #1808
JP_McCann's Avatar
car is not at the dealer only got the part from the dealer. are there any clamps holding the hose in the bottem on or does it just pull off push on deal?
JP
Old Jul 7, 2008 | 08:56 PM
  #1809
oh ok, the hose just pulls off.
Old Jul 8, 2008 | 12:14 PM
  #1810
realst8's Avatar
Does anyone know if I can check my timing chain timing without removing the timing chain cover? I am trying to tell if my timing chain jumped a sprocket or not. I was running about 70 down the road when all of a sudden it lost about 70% of power. When I pulled over it died then the radiator blew. I had just replaced the water pump about 200 miles ago and everything seemed fine after the replacement. Now I have compression of no more than 55 lbs in any cylinder. Any help?
Old Jul 8, 2008 | 12:36 PM
  #1811
J RO 9's Avatar
BUT
Yeah, I won't bother. I'm just going to cave in and take it to the dealer. A new vent control valve parts+labor is 227.01
Old Jul 8, 2008 | 12:47 PM
  #1812
RobertP's Avatar
Heres my newbie question
Alright so Im now the owner of a 99 Nissan Max SE automatic. I bought it in somewhat decent condition. The only damage of note is a broken automatic antenna that keeps making noise when I turn on the radio (Ive read the above posts, and plan on doing the same thing) and alot of car cancer. Little spots on the top of the car, little on the side and a big one under the spoiler.
So my question is pretty much your opinions. I want to know what I can do to her for some first maintenance. So far I have the spark plugs, oil filter, air filter lined up, and Im going to give the engine a good cleaning.
What other parts are easy to do that I could replace to up her life/performance?
Old Jul 8, 2008 | 02:35 PM
  #1813
Yankel.v's Avatar
I have a problem with my car. My ride is 99 SE Limited edition fully loaded with manual transmission First after I cleaned TB and IACV my gas pedal started sticking and it is quite uncomfortable and annoying to force it every time after I was rolling from a hill or waited for a green light.
Another question is when I am using engine brake, let say on speed 50MPH I put it on 3rd releasing clutch smoothly , RPM jump to 3000 or more, am I burning my clutch by doing this or not?
Old Jul 8, 2008 | 02:36 PM
  #1814
Yankel.v's Avatar
By the way how do I subscribe to a thread, I can't find this link?
Old Jul 8, 2008 | 03:34 PM
  #1815
NmexMAX's Avatar
dot dot dot ...
Pulldown the "Thread Tools" Menu, it's the 3rd option.
Old Jul 8, 2008 | 04:03 PM
  #1816
fastEddie's Avatar
What size of insert is needed for the inner tie rod tool? I see the Lisle tool and others come with multiple size inserts.
Old Jul 14, 2008 | 08:42 AM
  #1817
Yankel.v's Avatar
I have a slight vibration during idle steering wheel synchronously with transmission stick Transmission stick shakes with bigger amplitude. What could it be?
Old Jul 16, 2008 | 03:03 PM
  #1818
NmexMAX's Avatar
dot dot dot ...
Might need a TB cleaning or PCV valve.
Old Jul 16, 2008 | 09:05 PM
  #1819
Yankel.v's Avatar
[quote]
I have a slight vibration during idle steering wheel synchronously with transmission stick Transmission stick shakes with bigger amplitude. What could it be?[quote]
I did both and even more. I cleaned TB and IACV, changed PCV valve and cleaned MAF. It became much better I slightly feel it in the steering wheel, but stronger in the stick. I am thinking could it be the engine pillows?
By the way after cleaning TB my gas pedal started sticking whenever I roll on neutral or wait for green light. I don't know what to do with it.
Another thing about vibration after 70Mph. I took the car to mechanic to check out the alignment, but he said I need tire rotation. After that I think it became even worse. I am thinking going back and telling him what I am thinking about him. I don't think it's the balance, cause I did it when I put my new tires in winter. Anyways I'll check the alignment first. Can you guys suggest anything else?
Old Jul 16, 2008 | 09:27 PM
  #1820
jpolster2005's Avatar
I am about at the end of my rope with my maxima, which is a 1995. I inhereted it from my fiance, and its body is all banged up from her living in chicago. I plan on fixing that as soon as I can get it running right. its exhaust is loud. I dont care about that though. What i care about is when i floor it, it doesnt take off quick like i know 190hp should. its very slow. Its RPMs will go all the way up to six and it will shift very hard. i have replaced the knock sensor, all 6 injectors, all 6 plugs, all 6 coil packs. it still runs like ****. please help me. I want this thing to run good. I want it to be able to squeal the tires. for crying out loud the AC makes the engine die sometimes.
Old Jul 16, 2008 | 09:35 PM
  #1821
Considering everything you've done, maybe you have a bad MAF? Usually a bad KS is the culprit for loss of power, but you already took care of that.
Are you using factory spec NGK plugs? Factory coilpacks (non-knock off ebay ones)??
As for the AC making the car die sometimes, have you had your alternator and battery checked lately?
Old Jul 16, 2008 | 11:57 PM
  #1822
Other possible culprits are the following:
Incorrect ignition timing
Incorrectly gapped spark plugs
Problem with fuel inj. system ie fuel pump is dying
Clogged air filter
Fuel filter clogged or impurities in the fuel system
Low or even cylinder compression
Old Jul 17, 2008 | 12:33 AM
  #1823
There is a code for MAF, but I was under the impression that was just a sensor. Can something like a computer or sensor have that great of an effect on how the car runs? If so, then how can i test the MAF to see if it is good or not. I got a mention from a friend to try cleaning the throttle body with seafoam. What is a throttle body and where is it? Im new to working on cars, but i can catch on quickly. Also i looked under poor beat up maxine (what i named it) and found an exhaust leak right after the exhaust manifold. would that contribute to a gross loss of power? all my coilpacks were bought from autozone. very very expensive, cost me about 70 dollars a coil pack. plugs are nkg. Is this car OBD 2? Can i use a AutoZone scanner on this thing?
Old Jul 17, 2008 | 12:44 AM
  #1824
There you go. The MAF is a very important part of the system and how your car performs.....it's more than just an insignificant sensor. And yes, a computer or sensor greatly affects how a car runs! The computer aka ECU aka ECM is getting information from all the sensors around the car and then sending the appropriate signal to the various components of the car so everything works like it should.
Skip seafoaming your Max. Do a quick search and and you'll see tons of threads on this subject. Some swear it makes a difference, so swear it's useless.
An exhaust leak would not cause a gross loss of power, but a bad MAF would.
Sounds like you have quality spark plugs and coilpacks. Hopefully the spark plugs are gapped correctly.
Old Jul 17, 2008 | 12:45 AM
  #1825
Since your Max is a 95, it's OBD I.
Old Jul 17, 2008 | 01:11 AM
  #1826
Maxima_Joe's Avatar
4th Gen Parts King
Old Jul 17, 2008 | 01:17 AM
  #1827
Originally Posted by fanaticrockford
I stand corrected. I forgot Nissan switched over early. Thanks.
Old Jul 17, 2008 | 06:24 AM
  #1828
NmexMAX's Avatar
dot dot dot ...
But you're forgiven since you're a '99 buff.
Old Jul 17, 2008 | 09:35 AM
  #1829
98blackse's Avatar
98 SE Overheating
Hey Guys,
I have a 98 SE that is overheating at idle. As long as I am cruising at highway speeds, it is fine because there is enough air coming through to keep the temp normal. I noticed yesterday that neither of my radiator fans are running and the a/c is blowing out hot air. I have replaced the relays and fuses to the fans and still nothing. Do you guys think I have a thermostat problem or are my fan motors shot? I'm trying to avoid an expensive trip to the dealership because I only plan on having the car until the end of the year at the longest. I appreciate any info you guys could pass my way. Thanks.
Old Jul 17, 2008 | 10:00 AM
  #1830
NmexMAX's Avatar
dot dot dot ...
Fan motors if they're not working even after you've replaced relays and such.
Old Jul 17, 2008 | 10:03 AM
  #1831
DTrem08's Avatar
Where is the MAP/BARO SW Solenoid/Valve on a 99 Maxima?
Old Jul 17, 2008 | 11:46 AM
  #1832
98blackse's Avatar
I have been told by a friend that it could be the thermostat or the temperature sending unit. I just want a quick fix for this car because I'm getting an 09 Maxima as soon as they come out later this year!
Old Jul 17, 2008 | 11:53 AM
  #1833
enik23's Avatar
My KS sensor is broken therefore my car is running in safe mode and gets no more then 14 MPG. I am replacing the sensor myself in a few days. but here are my questions.
if i replace it will the check engine light go off automatically.?
And how do i get my car off this gass guzzling " safe mode " i read about?
Old Jul 17, 2008 | 11:58 AM
  #1834
khantalha+'s Avatar
replace ur knock sensor and have someone with the scanner clear it out is the best way to go...
Old Jul 17, 2008 | 12:01 PM
  #1835
khantalha+'s Avatar
Originally Posted by 98blackse
Hey Guys,
try unplugging the coolant temperature sensor to see if the fans come on while the car is running... if they do then that sensors shot...and be careful
  #1836
NmexMAX's Avatar
dot dot dot ...
Ok, so that is a valid thought, I'm not discrediting it...BUT, if your fans aren't working w/ the AC on, that is a CLEAR indicator. Also, try the ECT plug as stated above, but again, AC = no fans on = fans FTL.
Couple that with the fact that t-stats typically fail the other way, (too cold).
By the way, the 09 Maxima has been out for several weeks now
http://forums.maxima.org/7th-generation-maxima-2009-78/
Old Jul 17, 2008 | 12:20 PM
  #1837
98blackse's Avatar
Thanks for the info. And I realize they are already out and actually worded that wrong. I will not be actually BUYING one until later this year.
Old Jul 17, 2008 | 12:41 PM
  #1838
enik23's Avatar
i have a bad knock sensor after i replace it is there anyway i can reset the check engine light myself so i dont have to pay 70 bucks for a shop to do it for me?
Old Jul 17, 2008 | 02:54 PM
  #1839
enik23's Avatar
Old Jul 17, 2008 | 03:04 PM
  #1840
enik23's Avatar
why cant i make a thread bt i can only post here?
