NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Mar 11, 2009 | 11:46 PM
  #2921
pmohr's Avatar
No more Maximas...
Originally Posted by jtfm
how do i tell if i got a locking differentral tranny or non-locking on my 5spd tranny that went out?
Are you from Canada or the US? Original trans in the car, or has it been replaced? Do you have either of the axles out?
Old Mar 12, 2009 | 10:09 AM
  #2922
jtfm's Avatar
Minnesota, both axels are in, i have no clue if its original cuz i just bought this car.
Old Mar 12, 2009 | 11:16 AM
  #2923
pmohr's Avatar
No more Maximas...
Without being able to look at an axle, looking through the diff, knowing if it's the original trans, or being operational, no real way to say.
Can you read the VIN tag on the trans? I can run that and see, but there's a very slim chance it's a VLSD trans (not available on the USDM 4th gen Maxima).
Old Mar 12, 2009 | 09:19 PM
  #2924
watson's Avatar
So i just bought this RS Type Coilover Conversion Kit from a guy in my town for 30$, they are brand new never used. I dont know what else I need so i can do the drop. I have some pictures showing these. First off, what else is needed if anything, and second are these even any good or worth it?
there is a link to the pictures.
http://s646.photobucket.com/albums/uu185/watson545/
Old Mar 13, 2009 | 07:12 AM
  #2925
Daffy99's Avatar
I was thinking of changing my clutch and I wanted to know which clutch would you guys recommend? I was thinking Exedy but off ebay and I dont know if its the samething. I am putting headers, y pipe, cattback exhaust, and changed my short ram intake (if it matters).
P.S My pockets are kind of tight. Im looking for something reasonable but good quality
Old Mar 13, 2009 | 07:18 AM
  #2926
pmohr's Avatar
No more Maximas...
Just go with a 5th gen clutch. OEM parts and will hold more than enough power for you.
Old Mar 13, 2009 | 07:31 AM
  #2927
Daffy99's Avatar
O ok thanks. I have one more question, my gears arent long at all. 1st gear could barely give me more 20-25mph. I am about to get a tune up which i havent got in a while. I was thinking after I change my clutch I should be good. Is there something else I should do?
Old Mar 13, 2009 | 07:36 AM
  #2928
pmohr's Avatar
No more Maximas...
Is the clutch slipping?
Other than that, the clutch would have absolutely nothing to do with gear ratio or top speed in each gear; that's purely a combination of redline, gear ratio, final drive, and tire size..
Old Mar 13, 2009 | 07:47 AM
  #2929
kingw323's Avatar
Thermostat and radiator flush
I am replacing my thermostat this weekend. I'm planning on giving the radiator a good flushing as well. Is it necessary to drain the coolant from the enigine? I've read on here where the engine drain plugs are a pain to get to.
Old Mar 13, 2009 | 07:53 AM
  #2930
pmohr's Avatar
No more Maximas...
No need to drain the engine, really. Just flush it out as well if you'd like.
Old Mar 13, 2009 | 08:43 AM
  #2931
kingw323's Avatar
After draining the radiator, will much coolant drain out of the engine when i remove the thermostat? Thanks!
Old Mar 13, 2009 | 08:59 AM
  #2932
Adalad's Avatar
97 SE won't start
I have a 97 SE with 115k. It has had trouble occasionally starting in the past, taking several seconds to finally catch. It runs fine once it is going. I went to start it this past Monday and it cranks fine but just won't start.
I pulled the fuel filter and turned the key to the "on" position and got gas coming out so I figure the pump is working (but haven't checked the pressure). I went ahead and changed the filter while I was there. I then poured some gas into intake manifold with no results. I checked fuses and relays and they seem fine. Then I checked for spark and there was none.
So, what could cause the spark issue? I'm assuming that the timing chain is OK. I haven't checked the codes yet, but the check engine light never came on. I'll check the OBD codes this weekend. Any suggestions?
Old Mar 13, 2009 | 09:02 AM
  #2933
watson's Avatar
anyone going to help with my question?
Old Mar 13, 2009 | 10:41 AM
  #2934
BENGALSNATI85's Avatar
1998 MAXIMA TRANS
Hello to all! I recently purchased a 1998 with 105k miles on it. After driving it for a few weeks I noticed that it is shifting somewhat hard into 2nd and 3rd gear. It seems to get a little better as it warms up. I was thinking about getting the fluid flushed but upon checking it, it appears to be in excellent shape. Also, if I drive it like a "granny", give it gas very slowly, it seems to shift normally. Someone told me to change the fuel filter and another told me to clean the intake manifold(I think). Can ANYONE offer some insight to help me diagnose this problem?
Old Mar 13, 2009 | 11:48 AM
  #2935
pmohr's Avatar
No more Maximas...
A fair amount, but not all of it.
When it's hesitating to start, are you sticking the key in and immediately trying to crank it? Is that what you do all the time?
Have you noticed any specific conditions under which it hesitates? Reproducible at all?
Change out the trans fluid to a nice synthetic. Not flush, just a drain and fill.
When it's shifting hard, how much are you getting on it? At what RPM is it shifting, 'normal driving' (~2500-4000), or more 'spirited' (4500+)?
Old Mar 13, 2009 | 11:53 AM
  #2936
Hey, thanks for your response! To answer your question tho, it shifts at the appropriate time I believe, its just a little hard. I'm not driving it rough or anything(pushing it). I drive with a little sense, not a speed racer kinda guy! I'm just wondering if it could be fuel related? It seems like if youre easy(really easy) on the gas it shifts fine, and when you drive it normally it shifts hard. If you drive it say 20 miles, itseems to start to shift normally tho. I only live 12 miles away from work, and basically drive this car to work, it shifts hard the whole ride! Any insight would be much appreciated!
Old Mar 13, 2009 | 12:19 PM
  #2937
pmohr's Avatar
No more Maximas...
For a temperature related shifting problem, first thing I'd personally check is TPS adjustment. It will change with temperature, and the TPS can greatly affect how the auto acts.
http://www.vqpower.com/v2/articles.php?article_id=95
Old Mar 13, 2009 | 01:01 PM
  #2938
Adalad's Avatar
I just put the key in and turn it. I don't pause or anything. The hesitation in starting seems to occur more often when it is warm outside.
Old Mar 13, 2009 | 01:08 PM
  #2939
pmohr's Avatar
No more Maximas...
Try just pausing in ignition for a second or two, let the fuel system prime. It could very well just be bleeding down overnight sometimes, leading to a harder start.
Old Mar 13, 2009 | 01:49 PM
  #2940
What about the throttle body itself? Do you suppose if it was cleaned this would be the cause? Someone told me it I cleaned the throttle body and changed the fuel filter that this may correct it. And with the TPS, are you suggesting getting a new one, or adjusting it somehow?
Old Mar 13, 2009 | 02:56 PM
  #2941
kingw323's Avatar
Should I be concerned with the coolant draining down on the the alternator?
Old Mar 13, 2009 | 04:45 PM
  #2942
pmohr's Avatar
No more Maximas...
Not really, IMO. By the time you've finished up refilling the radiator and cooling system, it'll be about dried up.
Old Mar 13, 2009 | 04:47 PM
  #2943
pmohr's Avatar
No more Maximas...
It's a remote possibility, and a good idea to clean the IACV and TB if you haven't in a while.
Just check the TPS for now, if it's off I'd adjust it, if it can't be adjusted properly then replace it.
Old Mar 13, 2009 | 06:30 PM
  #2944
Could be the ECTS
Old Mar 13, 2009 | 08:44 PM
  #2945
SKOLJACK's Avatar
Originally Posted by gen4maxima536
there might be some info in the stickies about this but i dont remember.
all you have to do to the bumper is cut out those little plastic pieces. i used a hack saw blade. and once the fogs are in you can't see the cut areas.
your car might be pre wired for fogs, just look behind the hole where they go and there should be some wire bundled up, it has a gray connector on it. some GXEs may not be pre wired if they don't have one of the package options.
you'll also need a relay and the headlight stock that has the fog controls on it. look for someone that is parting out an SE and they should have both things you need there.
assuming you have the proper wiring and then get the fog lights, mounting brackets, control stalk, and relay, you just bold up the mounts, put in the lights and plug them in, plug in the relay, then replace the stalk (just have to remove the steering wheel surround.). and your done
Is that the same procedure for a 95-96 GXE? Just cut out the fog lamp location in the bumper or do you need an SE bumper?
Old Mar 13, 2009 | 10:50 PM
  #2946
Kilo15's Avatar
I'm buying new ignition coils, but was wondering if I should get a specific kind, and if so what should I be paying? Ive looked in search and saw Mitsubishi/hanshins were good? Heres some I'm looking at.
Old Mar 14, 2009 | 11:28 AM
  #2947
pmohr's Avatar
No more Maximas...
Yes, same on any of the cars that don't have fogs. Just cut away, but be careful or it'll look like crap.
Old Mar 14, 2009 | 11:56 AM
  #2948
Adalad's Avatar
I did try waiting and no result. I just finished checking the codes and had 2 codes flash: 1) Knock Sensor and 2) Camshaft Position Sensor
Could this be a timing chain issue? If so how do I check? If not, do you have any other ideas?
Old Mar 14, 2009 | 12:01 PM
  #2949
Adalad's Avatar
Could be the ECTS
I haven't had any indications of the ECTS. How would I verify this?
Old Mar 14, 2009 | 12:13 PM
  #2950
pmohr's Avatar
No more Maximas...
That's not a timing chain issue.
Test and replace the CPS if necessary, that's most likely the problem (the codes help a lot).
Old Mar 14, 2009 | 03:20 PM
  #2951
FullMetalJakit's Avatar
I'm back with my rear suspension "thump, knock, clunk" aka the most annoying noise in the world. Anyway I jacked her up today and everything seemed to be in order, so i decided to tap around with a rubber mallet. I hit the torsion beam and bam, there's my noise. So what next?? Forgive me as I know little about suspension. Also, unrelated I got a code for my rear o2 sensor that I just replaced < 6 months ago. I'm going to test the connection, but my question there is whether it's kosher to try to clean it with TB cleaner or not. Thanks in advance.
Old Mar 14, 2009 | 05:19 PM
  #2952
Kuhn_man's Avatar
Check the simple things first, make sure the lugnuts are torqued down properly. If they're loose, it can cause the symptoms you describe, and it won't be long before the wheel comes off.
After that, you really just need to get under there and take a look. A noise could really be anything.
try your suspenshion, take off the fabric on the inside of the trunk and the small rubber cap...bounce the car a bit and see if the strut is solid on the car or if it moves a bit...try that i had the same problem cept on the front
Old Mar 14, 2009 | 05:23 PM
  #2953
Kuhn_man's Avatar
sorry dude i dont know much about this one otherwise i would help, try bumping the question
Old Mar 14, 2009 | 07:35 PM
  #2954
The lugs deff are not loose, and the shocks seem to be fine (did a bounce test and no oil is leaking, cracks etc...). After tapping the torsion beam the noise was reproduced.
Old Mar 15, 2009 | 07:08 AM
  #2955
watson's Avatar
So i just got my car back from the shop last night, they did the whole lower front rad support and my clutch. I get in the car and start it and notice none of my guages are working. So they tell me to come back on monday and they will get it fixed. Later as im driving that night i noticed fluids dripping from my car, I thought it was just oil from the oil spray to rustproof the new lower rad support. Little later on in the evening i notice my power steering is starting to whine and getting harder to turn the steering wheel. I didnt think anthing of it. So it was than dark out and i was driving, my lights start flickering and than they just go out, my car is also trying to bog down but after a give it a little more gas it starts going again. Luckily when this all happened I was just pulling in to my work area. I than noticed i had no power steering at all and all my lights were not working. I than decided that I should bring the car home since it is only about 3km away. Im driving it really carefully and I have no headlights or dashlights at this point. Almost get to my street and my car bogs down and dies. I later found out that my power steering was leaking and I had no power steering, I am now wondering if driving without the power steering messed up my engine or anything else on my car.
Old Mar 15, 2009 | 07:24 AM
  #2956
pmohr's Avatar
No more Maximas...
Running the PS fluid dry won't cause the engine to die or bog down, that's a seperate issue. That could very well damage the PS pump, though.
Have you refilled the system and checked where it's leaking from? Most likely it's the cooler/bypass tube (depending on model) in front of the condenser.
Anyway, just bring it back to them, hopefully they should cover everything.
Old Mar 15, 2009 | 07:26 AM
  #2957
watson's Avatar
Well it was leaking near the lower front rad support, or on to it cause it was all dripping off the rad support, it was the front passenger side of the rad support. I thought that it would be the alternator seeing as i couldnt start my car up after it died, so i brought some friends to come push it and i tried starting it and it started right up again, lights turned on than flickerd out again and the power steering still didnt work, you could tell the engine was bogging down. By law does the mechanic have to fix this all seeing how there was nothing wrong with the car except a knock sensor code when i gave it to him?
Old Mar 15, 2009 | 07:31 AM
  #2958
pmohr's Avatar
No more Maximas...
Well if the PS pump locked up, it could try to bring the engine down with it, but almost guaranteed that the belt would just slip on the pulley, considering the size of it.
I don't know about by law, but any good shop would. Of course they could very well claim that you caused more damage by driving it empty (which you likely did).
Old Mar 15, 2009 | 07:33 AM
  #2959
watson's Avatar
I did drive it empty because they didnt end up hooking it back up the right way, so technically thats not my fault, and i live in canada so maybe the laws are different about mechanics. But should i fill up the power steering before i cruise it all the way to the shop?
Old Mar 15, 2009 | 07:39 AM
  #2960
pmohr's Avatar
No more Maximas...
Unless you want to cause more damage, yes. Though driving around with electrical problems as you're having could be dangerous, as it could affect more than just the headlight and gauge functionality. Could always try calling them and see if they'll tow it over there on their dime.
