Removing Fog Light Glare Shield (how-to)
Before I hear any
, I will just state that I did this on my car for night driving on curvy/rural roads and not to be a
and blind people.
*This was done on my '98, 95/96 guys may be different.
1.) remove plastic bolt cover
2.) remove two bolts securing foglight
3.) hold the fog as to not drop it and unclip connector to the harness
4.) remove fog light from car
5.) unscrew cap to gain access to the bulb/holder assembly
6.) unclip ground (black) wire and remove bulb
7.) remove retaining clip (that held the bulb) so as to not damage it
8.) gently pry the "lips" of the area where the bulb was clipped in (do not bend the ground location)
9.) slowly work each side and "jiggle" to check for improvement
10.) the glare shield and this assembly will come out as one
11.) remove glare shield from assembly
12.) press assembly back into the housing
13.) connect ground wire
14.) gently re-bend the "lips"
15.) re-install retaining clip
16.) re-install bulb
17.) screw the cap back on
18.) re-install on car, done.
Hope this helps anyone who may have wanted cut open their fogs instead.
![Tear](https://maxima.org/forums/images/smilies/tear.gif)
![Tard](https://maxima.org/forums/images/smilies/tard.gif)
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
Maxima30
09-07-2015 06:13 PM
