17x7, +18 offset...stick out?
Old Apr 22, 2007 | 09:16 PM
4x4Max's Avatar
I plan on buying used Work VS in 17x7 with a +18 offset. The tires that i will be putting on these wheels are 225/45/17. My question is how far will these stick out, if any at all? I do realize that most people have an offset of +35 to +40, but their wheels are 8+ inches wide, these are 7 inches wide. It should look pretty perfect on the back but i'm worried about the front. Anybody know, better yet, any pictures of similar offset and width on a max?
Also, my car is NOT slammed, i have 2.5-3 finger gap right now, so its ok if they're in line with fenders, they won't get near touching them with stiff-azz ksports.
Old Apr 22, 2007 | 10:32 PM
supazn
should be fine
Old Apr 23, 2007 | 06:11 AM
1FSTMAX's Avatar
Originally Posted by supazn
should be fine
How do you figure?
a 17x8 30mm offset wheel already sticks out the front fender on a maxima, i can't imagine how a 18mm off set would look. oh and kiss good bye to your wheel bearings..
Old Apr 23, 2007 | 08:04 AM
ewuzh's Avatar
I think it will be flush with a 215 or 225 tire. And I thought there's extra stress on the wheel bearings only when using spacers because it relocates the mounting point of the wheel?
Old Apr 23, 2007 | 08:17 AM
95bluse's Avatar
Originally Posted by 1FSTMAX
How do you figure?
Agree..I have 17x7.5 +35 offset, and it's perfect in front (almost in line withe fender. The rears are not tucked n much at all. I'll try to get some pics when I put them back on, now that the weather is better.
+18 will be too much, and may stress your bearings as stated.
Old Apr 23, 2007 | 09:03 AM
supazn
How do you figure?
a 17x7 wheel means there will be about 1/2inch less on both sides of the wheel.
30mm - 18mm = 12mm ~ 1.2cm
.5in ~ 1.27cm
ultimately it will depend on tire width
Old Apr 23, 2007 | 09:08 AM
Fr33way™'s Avatar
Wild for Width
Why even get Works so skinny?
Old Apr 23, 2007 | 09:23 AM
1FSTMAX's Avatar
because they're "works"?
Old Apr 23, 2007 | 10:14 AM
4x4Max's Avatar
Good replies, thanks. Reason as to why i want these instead of wide ones is because i'm getting a relatively good price on them, i can use my current tires, they look nice, and i don't really need wide wheels for anything, they would just slow me down.
According to the offset calculator, these will stick out only 4mm more than a 8 inch wide with +35...ewuzh, that would be EXACTLY the same as your 17x8 wheels with the 31mm offset that you have up front, and 17x9 with 44mm in back which i consider a PERFECT fit. Glad i clicked on your cardomain, these should look great. I guess we'll see if the deal goes through. Any other replies/suggestions are welcome!
Old Apr 23, 2007 | 12:57 PM
euromaxima's Avatar
30 offset here with 19x9
Old Apr 23, 2007 | 01:20 PM
ewuzh's Avatar
I have 10mm spacers in the rear so it is effectively a +34 offset. +44 was a little sunken in for me.
Old Apr 23, 2007 | 06:28 PM
XJinCT's Avatar
<3's the all motor section
how do you figure?
Old Apr 27, 2007 | 04:06 PM
Doriftomodachi's Avatar
It should stick out a little less than an inch. Not a big deal. And your wheel bearings should be fine.
y2kse
Mar 20, 2002 02:54 PM
jnovember
Mar 15, 2002 05:15 PM
Sway1331
Feb 21, 2002 10:05 PM
98sterlingmist
Dec 11, 2001 04:47 PM
j_bryan
Oct 19, 2001 08:09 AM
