Bose!
Old Jul 11, 2001 | 03:42 PM
bet97se's Avatar
My bose in dash cd player is acting up. When it is hot it doesnt want to give me my cd back. I have to turn off my radio and leave it off till it cools down. I have a 2-12 jbl with a 400watt jbl amp connected to the stock sytem can that be it?
Old Jul 11, 2001 | 03:52 PM
thezcarguy's Avatar
I have a 97 se also. I dont think that the subs you have would have anything to do with the problem your having. From time to time my Bose unit dose the same thing. What you can do to get it out is insert another CD "OVER" the cd already in the player... this frees up the stuck cd and it comes right out.( at least mine dose) Hope this helps.
Old Jul 11, 2001 | 04:00 PM
bet97se's Avatar
Are u sure that will work cause I am not trying to get 2 cd's stuck in there.
Old Jul 11, 2001 | 04:25 PM
jay_x's Avatar
I don't know about sticking another cd in there. I only have this problem if I use cd-r's. The headunit has a built in amp that causes most of the trouble.
Old Jul 11, 2001 | 04:27 PM
bet97se's Avatar
It only happens when i put in my butleg cds
Old Jul 11, 2001 | 05:12 PM
pawn's Avatar
I know the Reason
BOSE SUCKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 12, 2001 | 06:19 AM
bet97se's Avatar
Re: I know the Reason
Hell yeah I have a poped speaker and I am scared to take it to nissan cause of my system my car is still under warranty.
Old Jul 12, 2001 | 07:23 AM
gtr_rider's Avatar
192.168.1.1
Re: Re: I know the Reason
it cost about $400 dollars to buy a whole new speaker, i have amps sitting around at my house, cost would be around $250 ea.
Old Jul 12, 2001 | 07:25 AM
bet97se's Avatar
I think that speaker is staying like that till I find a crashed max at a junkyard.
Old Jul 12, 2001 | 07:26 AM
bet97se's Avatar
Hey I am a fanatic.
Old Jul 12, 2001 | 09:29 AM
BSwithTF's Avatar
BOSE isn't built for extreme volume levels. They build their systems for smooth, full bodied sound. There's not a lot of systems out there (stock) that sound as great as the BOSE.
Old Jul 12, 2001 | 09:35 AM
BSwithTF's Avatar
Old Jul 12, 2001 | 09:46 AM
bet97se's Avatar
BOSE sounds great but after a while of listening to the music at the max it start to sound like ****.
Old Jul 12, 2001 | 11:31 AM
humaras's Avatar
cdrw
speaking of CDs. I was wondering if any of you guys have taken MP3 files and stretched them out to WAV files and if it would work on the Bose.
I have purchased some bootleg cds before and when I tried to play them on the BOSE, I would get the "ERR" message--meaning it wouldn't work.
any similar experiences, I wonder?
Old Jul 12, 2001 | 11:52 AM
thezcarguy's Avatar
I guess i wassnt clear in my first post... Tell me this, when you hit the eject button on the radio can you hear the motor trying to eject the CD? If you can, insert about 1/3 to 1/2 of another cd over the stuck one. In my case the stuck cd will slide out under the one im holding in my hand. I dont know if it will work for you but what do you have to lose?
Old Jul 12, 2001 | 12:04 PM
bet97se's Avatar
Yeah it sounds like it is taking out the CD and it comes out but very little to little for me to even pull it. I just went out side and tried and it WORKED. Hey thanks I was getting tired of the same CD.
Old Jul 12, 2001 | 07:21 PM
KiLIAkLoWn's Avatar
Re: cdrw
Don't use CDRW's use CDR's they are for your cd player. All of my Napster/morpheous Cds work. Don't get cheap CDR's either. Some of those don't work for some reason.
Old Jul 12, 2001 | 08:17 PM
WaarrEagle's Avatar
Re: cdrw
So far every CD-R I have burned worked in the Max except for one that came free as a sample from some auction I won on e-Bay. I have used TDK, Maxell, Memorex, even the HP that came with my burner. Try some of those and see what happens. I have yet to find one that works in Chrysler products. If anyone has one, please let me know.
Old Jul 12, 2001 | 08:36 PM
humaras's Avatar
difference?
two questions for you guys:
1. what is the difference between a CDR and a CDRW? I have a CD burner on my computer--and I have copied music CD's straight off and they work on the CD player in our cars.
2. the second question is what is the procedure that you guys generally use (and have had good success with) in making MP3s into audio files and burning them.
anyone have a moment to share with me their recipe? what type of format does the files have to be in to be burned on the cds to insure that they work?
thanks
Old Jul 13, 2001 | 12:42 PM
thezcarguy's Avatar
Good... im glad it worked for you. I bet a few of you thought i lost my mind huh? Anyway, its all good. It feels good to have helped for once and not just getting helped by the board.
Old Jul 14, 2001 | 02:00 AM
IIOO7II's Avatar
Re: difference?
thanks
CDR's are only recordable once and can be read by almost and cd device, CDRW's are re-writable and can only be read by CDRW compatable devices like some newer discman, you can download free programs from WWW.zdnet.com that'll switch mp3's to wav's or if you get the newer version of adaptec ez cd creator it'll switch em automatically while it records which by far is the easiest
Old Jul 15, 2001 | 09:57 AM
humaras's Avatar
thanks
thanks for the explanation. In my case, I have the CDRs since the CDs can not be reused.
Old Jul 18, 2001 | 07:26 AM
bet97se's Avatar
I AM ****ED!!!! My bose system is gone. My back speakers burnt out on me. I payed some IDIOTS $175 to install a system in my car and these C??K SUCKERS Messed my **** up. I have to listen to my front speakers only cause my wires in the back were touching and it burnt the computer on the bose. Now my system doesnt work cause I had it split from my bose line.... If any body can help please let me know.
Old Jul 18, 2001 | 08:15 AM
thezcarguy's Avatar
DAMN!! dont know what else to tell you other than its a good time to look into aftermarket audio stuff.
Old Jul 18, 2001 | 09:28 AM
dvpatel99se's Avatar
Get those monkeys to fix the system. It is very very expensive to fix that stuff because it is Bose Proprietary. If they messed it up they are the ones to fix it aren't they?
Old Jul 18, 2001 | 09:35 AM
bet97se's Avatar
The problem is that I got this installed like 3-4 months ago. But I was planing on putting some aftermarket system in there but not right now. I am saving up for nitrous and a new clutch.
Old Jul 18, 2001 | 10:07 AM
I guess Ebay or Junkyard is the way to go then huh?
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
