Problems when adjusting clutch.....help!
Old May 9, 2007 | 09:29 AM
ManualMaxima's Avatar
5th Gen till she dies!
I finally got down and tried to adjust my release point lower cause my clutch was way to high for my liking. i did as the write up said and turned the clutch shaft clockwise to push it in some more.
Now the clutch release point is so high it is slipping. Also then the car idles for about 5 min the clutch changes release points( i guess it adjusts itslef) and it puts the release point even high and the pedal become extreamly stiff. Can anyone give some pointers on what to do?
i bled the clutch cause i put in a new line, could it just need more bleeding?
Old May 9, 2007 | 05:04 PM
dgeesaman's Avatar
Maintenance Monster
I think you need to continue bleeding. In fact make sure there isn't a bleeder at each end of the clutch line.
Dave
Old May 9, 2007 | 11:51 PM
there is the 2 the upper and lower and that is it...i tried it tonight with my friend and the clutch got 100% better....i jst have to see how it act the next couple days cause the clutch as i said has a habit of adjusting itself way to far out.
Old May 10, 2007 | 09:24 PM
the_3d_man's Avatar
Yeah that clutch adjustment nut, does not take a lot. half a turn is all it takes.
Old May 10, 2007 | 10:21 PM
i have tried adjusting it and that does nothing.....it is alot better after i bled it some more, but it still is not where i want it to be....i will try adjusting it some more.....but compared to what it was liek this is golden
Old May 29, 2007 | 09:00 PM
RIPTIDER's Avatar
I might have a similiar problem. I recently changed my flywheel(Fidanza), fifth gen clutch, pressure plate and clutch bearing. I clutch pedal is higher than before.
I have noticed smooth engagement in first and second gear but it slips slightly in third, fourth and fifth. If slips only slightly when I just let the clutch out quickly but slips more when I press the acclerator at the same time. Clucth pedal feels a little soft but I don't think that I need to bleed it.
Do I need to adjust the clutch pedal? Is this the cause or could it be something else?
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
ajahearn
Sep 19, 2015 03:03 PM
tardrex
Sep 11, 2015 07:35 PM
slowlifer
Sep 8, 2015 05:53 AM
