Clutch sensor starting issues
Old May 29, 2007 | 05:55 AM
Digitized's Avatar
Hello, I have a 5spd Maxima and from time to time, when I clutch in to start the car, there is no response ( no starter noise, nada, only lights turning on the dash)...
I jiggle the key thinking it's the Ignition Switch, but it's not..
I press/release the clutch a few times and eventually, it starts..
I was wondering, is there a clutch sensor that needs to be replaced or should I look elsewhere for this problem?
Old May 29, 2007 | 08:50 AM
oldngivout's Avatar
Willing to learn
It is actually a switch, not a sensor. It is located under the dash near the clutch pedal. It must be depressed by the clutch in order to allow the starter to work.
Old May 29, 2007 | 09:35 AM
Digitized's Avatar
o.k.. and how much is this so called switch if it needs to be replaced?
Old May 29, 2007 | 12:50 PM
Digitized's Avatar
someone?
Old May 29, 2007 | 01:24 PM
oldngivout's Avatar
Willing to learn
It is not much, a few bucks or so. But you must test it to see if that is indeed your problem. The switch should be tested with an ohmmeter for function. It is a simple two conductor switch, it is either on on off depending on whether is is depressed or not.
Old May 29, 2007 | 10:18 PM
Digitized's Avatar
well so far, so good, no problem with it..
but I will take a look to see where the switch is.. and assess the situation..
thanks again for your help!
Old May 29, 2007 | 10:44 PM
FantasyGod's Avatar
Please be sure that you are pushing the pedal all the way down to the floor. I know too many people that complain about similar symptoms because they don't push their clutch in all the way. And yes, in this case the sensor is working properly.
Old May 30, 2007 | 02:19 AM
paemt6220's Avatar
Just for your info, Make sure you try holding the clutch and turning the key several times. I have the same problem but it isn't the clutch switch. I think my problem is the ground on the starter.
Chad
Old May 30, 2007 | 06:50 AM
Digitized's Avatar
ehehe no worries there, been driving manual cars for 10 yrs
Old May 30, 2007 | 06:51 AM
Digitized's Avatar
Chad
Hmm, that is possible for me then.. I recently replaced my starter ( 1 month ago) but this problem only starter occuring 1 week ago..
yay! something to do when I have a free moment!
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
bc992164
Aug 26, 2015 12:19 PM
maxinout93
Aug 20, 2015 02:17 AM
vanebecker
Aug 17, 2015 08:24 PM
