Help I'm Screwed!!
Old Jun 8, 2007 | 02:35 PM
Mr Willis's Avatar
Help I'm Screwed!!
My sunroof is partially open now (about 4 inches or so) and i can't close it. When i push forward it does NOTHING, i can't even hear the motor but it goes back just fine. GGGGGGGRRRRRRRRRRRRR!!!!!
Any advice would be appreciated.
Old Jun 8, 2007 | 02:44 PM
tonyrunna's Avatar
this happened to me this week also. left my car parked with the sunroof vented and when it came time to close it for the night it would close i believe due to the rain that got in and wet up the switches. took the switches out and shook em out. let it dry for a few and worked as it should
Old Jun 8, 2007 | 02:46 PM
slinky87's Avatar
check fuse/relay if that wont work push up and away from you and it will shut
Old Jun 8, 2007 | 02:48 PM
Mr Willis's Avatar
<sigh> can it be a fuse? it still goes backwards???Where are the relays?
Old Jun 8, 2007 | 02:56 PM
Mr Willis's Avatar
up and away didnt work. Not even close.
Old Jun 8, 2007 | 03:13 PM
TunerMaxima3000's Avatar
pull the panel the holds the switches and your lights off and cross the wire from the 'open' side of the switch to the 'close' side just to get it closed, then pull the switch and check it out/ or check it first before you jump the wire. if its gonna rain i'd jump it right away and deal with it later, at least it'll be closed.
Old Jun 8, 2007 | 03:31 PM
Mr Willis's Avatar
How the hell do i cross those wires and y do u think it's the switch?
http://www.t-mobilepictures.com/phot...om92ehp59hurdu
This picture is better. i highlighted the wires.
http://i46.photobucket.com/albums/f1...f826673a78.jpg
Old Jun 8, 2007 | 03:56 PM
green is closed, yellow is open, you can remove the solder (heat it with a propane torch on the green side, remove the wire, heat the yellow side, remove the wire, and put the green on the yellow side it may work, just an idea, it should work if the problem is the switch I believe. im not 100% sure on this but you can always re solder it if it doesnt work
just tryin to give an idea but check ALL your fuses first.
Old Jun 8, 2007 | 04:09 PM
Mr Willis's Avatar
Well, i got it closed. I opened the switch and cleaned the contacts because i saw some black spots on it (the contact) and i was able to shut it. I can only SHUT IT by hand but it will OPEN with the switch.???
Thanks 4 the replies. There is definately something wrong with the track. i guess i'll just leave it closed for now.
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
jchronis2552
Sep 23, 2015 04:57 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
thenewguyy
Sep 12, 2015 11:12 AM
