GI:A32 JDM Cefiro Dual Piston Caliper w/ JDM Nissan Brake Pads
Old Jun 11, 2007 | 10:35 PM
SYCEFIRO's Avatar
I had sold few of these and just want to put it out there and let ya'll know.
These are used in JDM Skyline R32, Silvia S13, Laurel and Cefiro A31, A32. I do not think this applies to A33 though..
Advantage:
Better Brake Response (2 Piston JDM Cefiro Front brake Caliper)
Cheaper upgrade - Can fit in Stock 15, 16" Wheels (Cheaper; so you don't need to upgrade your wheels, cheaper tires).
If you want a BIGGER Rotor, I can source a adaptor bracket later on.
Please see the photos for your reference:
Old Jun 11, 2007 | 10:36 PM
SYCEFIRO's Avatar
more photos:
Please feel free to ask me any question you might have.
Working hard for both A32 Maxima/I30
Regards,
SY
sycefiro@yahoo.com
Old Jun 11, 2007 | 10:40 PM
gtr_rider's Avatar
192.168.1.1
Hey quick question Sy, would these use the factory brake pads? Also conversion brake lines are not necessary correct?
Old Jun 11, 2007 | 10:43 PM
MyownNismo's Avatar
Future Camaro SS owner
how much are they. If the price is right I might try to see if the work on a A33.
Old Jun 11, 2007 | 10:51 PM
SYCEFIRO's Avatar
Can you please post this for me on your website? New Product for A32
Right, regular stock brake lines are okay. I'd recommand to go with Goodridge SS Brake lines.
I am working on getting these along with SS brake lines..(but JDM SS lines are very expensive). Working on 'em right now.
No, they use the JDM Nissan Brake Pads... which will be included with this Dual Piston Caliper Kit.
You can use your A32 Stock size Rotor (OEM or aftermarket).
I was told that these will EVEN work with 15" Steel Wheels (GXE wheels with wheel covers)
Like I said.. if you are going bigger Rotors, it's possible. I am working on getting the adaptor brackets right now....
But you will need BIGGER wheels to make sure you have the caliper clearance.
Buying these Caliper Kits (including Pads) along, they are about U$499+ S/H (my other customers paid about U$550 shipped Int'l Priority SH)..
These are FRONT's only.
I was reading that A33 has thicker rotors than A32, unless you want to use A32 Rotors... this is NOT recommanded... If you are doing an upgrade for A33, you might wanna consider going 6th Front Brake conversion.. BIGGER ROTORS, and 6th Gen Calipers.. but you will of course need BIGGER wheels to accomodate these
Hope this helps!
SY
sycefiro@yahoo.com
Old Jun 11, 2007 | 11:03 PM
gtr_rider's Avatar
192.168.1.1
Are these JDM brake pads readily available, because it would be terrible to have to only go through one source to get brake pads.
Old Jun 11, 2007 | 11:12 PM
SYCEFIRO's Avatar
Yes, they will be in stock and be readily available
i.e.
Each Set of Caliper kits sold. I will stock 1 set available..
I personally use this for the past few years (finally decided to share my secret.. j/k)... So I usually have 1-2 sets of these brake pads available
SY
sycefiro@yahoo.com
Old Jun 12, 2007 | 02:04 AM
JtzMax's Avatar
Whatchyou say?
I really wanna pair! But, I have spent all my $$ for now on other things
Where did you get the Nismo lip? Any chance you'll share that secret? lol j/k
Old Jun 12, 2007 | 04:04 PM
Maxtank's Avatar
Just in time for my brake upgrade...are these officially on sale yet?
Old Jun 12, 2007 | 04:17 PM
Kevlo911's Avatar
Kevlo for President
Differ bolt size for A33
Old Jun 12, 2007 | 09:47 PM
krismax's Avatar
Father of the 00 VI
these look to be cast iron but are they aluminum? and also can we get a weight of one without the pads .thanks
Old Jun 12, 2007 | 10:10 PM
interested
Old Jun 13, 2007 | 05:19 PM
Zack342's Avatar
Do you have any pictures of the top view of the caliper? What is the piston Diameter?
Old Jun 19, 2007 | 11:57 PM
Ceffy Moe's Avatar
hey i was wondering what db would the brake pads for a 2.0 1 pot cefiro?
i was guessing db1232
Old Jun 20, 2007 | 05:21 PM
SYCEFIRO's Avatar
Here is the weight for the caliper w/o pads:
4.6KG = 10.12 lb
I may also be able to provide bracket/adapters (as an option) to work with the following rotors (other than stock size)
303mm rotors =11.9 inch rotors
328mm rotors =12.9 inch rotors
If you go with larger rotors, then you would require to have Bigger wheels with correct off set to clear.
I will request for the photo of the top view of the caliper as well as pix without the pads. I'll let you know the piston Diameter later tonite.
I don't have the part numbers but the 2.0 one-pot is essentially the same as USDM Maxima 95-99 Front Brake
Old Jun 21, 2007 | 03:33 PM
SYCEFIRO's Avatar
I didn't get the piston diameter yet will find out soon... and apologize for the horrible pix below (few salted winter in NJ..really destroy the look of beautiful Cefiro caliper.. haha.. need to repaint it).
This is after many years of salt/winter/rust... haha.. I know it looks horrible, but the performance is still excellent!
SY
Old Jun 21, 2007 | 09:48 PM
MrDicks95SE's Avatar
Offset Is Everything.
thats some nasty rusty deterioration going on there.
bump for a cool product.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
