Ses 1008
Old Jun 27, 2007 | 09:36 AM
mansurxk's Avatar
Ses 1008
I did an engine swap in my 97 max with another 97 engine, same production dates, May 97.
yes i have searched other threads, but i know they changed the part number on these years.
after the swap, i've been getting a 1008 code. the evap canister purge volume control valve. I purchased a valve from another member on the org (they also had a 97) so i assumed it would be fine. anyway. swapped valves, still getting code 1008, P1445.
http://www.courtesyparts.com/betasit....php?keywords=[14920]+\(a32b&cPath=1783_1784_1814_1817
there are 3 valves listed. is it possible that the first valve was already bad, and the 2nd valve wasn't the proper piece?
I'm still trying to pass NJ inspection, and just wondering how to remedy this code.
Old Jun 27, 2007 | 10:58 AM
Kevlo911's Avatar
Kevlo for President
Why not swap over old parts from the old engine? Call the dealer, give them your vin and get the proper part number.
Old Jun 27, 2007 | 11:18 AM
d3v0's Avatar
why swap another 97 engine? if anything i would've gone bigger and better, more powerful, u shoulda done a 3.5 swap
Old Jun 27, 2007 | 01:14 PM
mansurxk's Avatar
jackarse mechanic scrapped my engine after i explicitly told him to hold onto it. Causing me massive issues now.
does the valve match the engine, or match the VIN. i swapped ECU and engine to match as close as possible. do i give the new engine's VIN, or the old one?
i get a clicking noise from my PVCSV (volume control solenoid valve), but it sounds as if its stuck. like a click-click click click click click. is that normal?
Old Jun 28, 2007 | 05:46 AM
mansurxk's Avatar
is the valve supposed to open smoothly when you turn the ignition, or clack clack clack clack?
Old Jun 28, 2007 | 07:52 AM
Kevlo911's Avatar
Kevlo for President
Everything should be smooth.
Old Jun 28, 2007 | 09:40 AM
mansurxk's Avatar
thanks. so it should just vibrate and should hear it engage.
Old Jun 30, 2007 | 10:39 AM
mansurxk's Avatar
didn't work, installed the new Purge volume control valve and still get a CEL with 1008.
any ideas?
spencerwh1
Jun 30, 2016 05:44 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
Ra1max
Jan 10, 2002 08:00 PM
