any good instructions for mesh grille???
Old 07-18-2001, 08:13 PM
fatmike's Avatar
I was just wondering if anyone had some good instructions on making a mesh grille. I could probably make one myself but i dont want to screw it up and make the max all ghetto looking
fatmike is offline
Old 07-18-2001, 08:22 PM
Vyrus's Avatar
RE: Mesh Grill...
Well, I made my mesh grill and I think it looks pretty good. Let me tell you, its really hard not to scrape the paint, so don't worry if you do. Be prepared to gash your hands badly. You can't wear gloves because then you can't cut it properly. Hint: If you screw up a little, do it on the other side so it looks symmetrical. The hardest one will be the lowest bumper insert - the upper bumper insert will only take you like 5 minutes. Don't worry if you really screw up, the sheets are only $2 anyways. Just tryin to help .
Vyrus is offline
Old 07-18-2001, 11:23 PM
Sunrise
just buy that rain gutter mesh from Home Depot, it costs like $3. Measure the hole in the lower part of your bumper ( the one with the lines). Then cut out like 3" more than you need on each side. Take off your lower splash guards and shove the cut mesh piece into the hole. Use zip ties. I have a black car, so I used black zip ties...gheto...true....cheap? hell yes.
curve the mesh in between the body and the foam bumper thing then zip tie the thing to the body on a couple of the tubes.
hope that kind of helps...i would have written a better write up but my head is not correctly attached at this moment.
Old 07-19-2001, 08:17 AM
fatmike's Avatar
thanks i think i am going to attemt this today so I'll let you know how it turns out
fatmike is offline
Old 07-19-2001, 07:50 PM
Max96LSU's Avatar
Did it An hour ago
I went to Home Depot and bought some Gutter Guard today. I started off with the top grill with Nissan Hamburger. I took the entire grill off the car anf then put the mesh over it and cut it to fit. I tied it down with some black tie downs since my car is black. I think it almost looks OEM/ proffesional. I even put the Hamburger on top of the mesh so that you dont see the black backing from the original grill. It only took me 45 min -1 hour to do. I plan on doing the bottom valence somtime tomorrwo.. I'll post some pics when I have time.
BTW this is by far the EASIEST and CHEAPEST mod to do. Only 5-7 bones, plus a pair of wire shears/.
Max96LSU is offline
The Frye
09-02-2021 11:03 AM
MaxLife17
06-27-2019 01:37 PM
cruce91
09-20-2015 10:23 AM
dvcamp
09-18-2015 10:17 AM
MaxLife17
09-08-2015 02:36 PM
Quick Reply: any good instructions for mesh grille???
