Replacing antenna mast
Old Jul 24, 2007 | 01:29 PM
SunMax's Avatar
I bought a new antenna mast through eBay, but I couldn't figure out how to remove the old one. I can't remove the metal cap that hold the mast in place. Is it a snap-on cap? or screw-type cap?
How did you remove it?
Also, when replacing the new one, does the "teeth" of the new mast face toward the back of the car or front? The old one was already came out (previous owner forgot to lower it in a drive-through car wash), so I don't have any references.
Thanks.
Old Jul 24, 2007 | 01:53 PM
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showpost.ph...73&postcount=3
Old Jul 24, 2007 | 01:55 PM
SVI30's Avatar
If portion of the old whip is still in the antenna housing, you will have to open the house to get the tail out.
The metal cap has two small notches on the inside diameter. Use a pair of needle nose or "C" clip pliers to remove the cap. Most often it will come off by hand of a pair of regular pliers.
PH98I30
29
Feb 10, 2025 12:03 PM
captchaos
Mar 15, 2016 12:18 PM
dvcamp
Sep 18, 2015 10:17 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxima30
Sep 7, 2015 06:13 PM
