Help with CV Axel!!!!!
Old Aug 6, 2007 | 12:14 PM
Ruthless's Avatar
Alright, I got grease all over my chrome.
Ah, when I hit any lil bump in the road my front right tire area makes like a grinding / squeeking noise.
Raised my car, notice the CV boot is busted open and there is grease everywhere.
My buddy thought i might need a new Bearing aswell.
I FORSURE need a new CV axel. Where should I go to get these? Is there better ones? cheapers ones? or just Nissan ones????
My MAXIMA money pit.......
Old Aug 6, 2007 | 12:56 PM
Peebs187's Avatar
www.raxles.com for the best you can buy.
Old Aug 6, 2007 | 01:57 PM
pmohr's Avatar
No more Maximas...
Quality, but expensive. Also arguably no better for reliability or strength than a regular replacement axle from a parts store, threads aplenty on that.
AZ/AA/O'Reilly's/whateverautopartsstore are usually around $60 + core. Or you could go to the dealer for $500... Raxles are what, $129?
Old Aug 6, 2007 | 01:58 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
reman from napa, autozone, kragen, ect.
Old Aug 6, 2007 | 01:59 PM
WhiteA32's Avatar
This is a good summary!!!
Old Aug 6, 2007 | 07:30 PM
Paintguy84's Avatar
I would just go with napa.
Old Aug 6, 2007 | 07:35 PM
Ruthless's Avatar
thanks alot.
I assume its worth while to do both sides.... The car now has 240,000Km on it.
Old Aug 7, 2007 | 11:23 AM
ObsidianIce69's Avatar
if only one side is busted don't bother with the other. I personally say go with raxles, but the fact that the napa/autozone/etc is so cheap and has a lifetime warranty ( i think) it can't hurt. I went with autozone before on my 91 and had the axles didn't last very long, the boots were torn within months.
Old Aug 7, 2007 | 01:03 PM
madnut's Avatar
I don't recommend replacing the boot its costs almost the same amount as a new axle and is a huge pain to do... iv done it myself will never try it again
Old Aug 9, 2007 | 08:45 AM
Ruthless's Avatar
i replaced both sides because i am ballin like that. I looked at the driver side afterwords and there was "tearing" going down on the boot. So, I figured it was a matter of time...
either way 300 extra bucks to avoid the garage for an extra month.. lol
Old Aug 9, 2007 | 09:56 AM
WhiteA32's Avatar
Which brand did you go with?
Old Aug 9, 2007 | 10:39 AM
Ruthless's Avatar
uhhh.. Got them from Napa... They fit my car... ahh, the box was mostly grey with blue on them... Im pretty sure i got refabbed ones... Price after core return was like ~300 for both???
Old Aug 9, 2007 | 11:13 AM
albo's Avatar
i dont want to open another tread. so since this is related to what i need to do .. im looking on line and under the part i see this ...
and i have a question.. whats this suppose to mean
CV Half-Shaft Assy: Front Left; Automatic Transmission; Except ABS; Without Limited Slip Differential
i dont get or understand what they mean by
is there a difference between it having or not having Limited Slip Differential
thnks b4 hand
Old Aug 9, 2007 | 12:12 PM
Ruthless's Avatar
YES. You will get the wrong part.
from what i learnt (could be wrong)
I had to get a CV axel that met these requirements.
limited slip dif (you have this if you have the TCS (pretty sure of that answer) )
ABS= if you have ABS (I do)
AUTOMATIC (I also have auto)
you need to know the answer to those 3 questions before you order your parts.
Old Aug 9, 2007 | 01:28 PM
albo's Avatar
and how can i find out this info? sugestions?
Old Aug 9, 2007 | 01:32 PM
Vlasic's Avatar
Ruthless, there should be a core charge. You can go trade in your old axles and get a refund, in the end they should come out to about $60-$80 per axle.
Albo, you do not have a limited slip dif, Canadian 4th gens have it, but US 4th gens do not. The difference between an ABS and a non ABS axle is just a timing ring at the end. If you have ABS, you need an ABS axle, there is a timing ring on the end for the ABS sensor.. Also, all passenger side axles are the same, doesnt matter if its auto or not, driver side axles are different so make sure you get the right driver side axle that fits your trans.
Old Aug 10, 2007 | 09:38 AM
Ruthless's Avatar
Yea, I got the Core return $100 CAN per axel.
And i Do have a limit slip dif.... Hence.. Ruthless Canadian. You are very correct about the passenger side.
Old Aug 10, 2007 | 10:42 AM
Vlasic's Avatar
yeah I was directing that towards Albo saying that he doesnt have LSD and wont have to worry about it.
Old Aug 10, 2007 | 11:48 AM
albo's Avatar
I now this might sound stupid. but whats the easiest way to know if a car has abs?...
im pretty sure i do . but want to make sure before i order all this stuff and not have to deal with all the returning dilema... and what not.
Old Aug 10, 2007 | 12:00 PM
Vlasic's Avatar
when you turn on your car does an ABS light come on?
Or just look in your engine bay near the brake master cylinder and see if there is the square ABS module there. Looks like a square silver block with hydrolic lines going to it.
Old Aug 10, 2007 | 01:25 PM
Ruthless's Avatar
I always thought this acronyme (spelling) had a different meaning. "LSD" Well, it did when i was growning up.
ahaha
user 11122324
42
Jul 18, 2022 03:35 PM
matty
Dec 15, 2002 10:40 PM
ladeesman
Nov 7, 2002 04:52 PM
mduggan
Aug 20, 2002 08:27 PM
