E Brake light???
Old Aug 16, 2007 | 06:32 AM
jvckustumz's Avatar
E Brake light???
My emergency brake light is on and i don't know why, i floored my car about a month ago racing my gf's 06 mustang and all the sudden my ebrake light popped on, car is still running fine, has anyone still had this problem?
Old Aug 16, 2007 | 06:56 AM
NmexMAX's Avatar
dot dot dot ...
First check to see if the ebrake is engaged. Then check your brake fluid. If it's getting low, you probably need new brake pads.
Old Aug 16, 2007 | 07:31 AM
xsnowpig's Avatar
mine is on 24/7 also. mine started last winter after a wet day then a freezing night. i took the switch apart under the center console and that fixed it for like a day. back on now. still getting 28mpg so i dont think the brakes are dragging.
Old Aug 16, 2007 | 07:33 AM
NmexMAX's Avatar
dot dot dot ...
Maybe your brake fluid is low.
Old Aug 16, 2007 | 10:03 AM
jvckustumz's Avatar
mine has new brake pads all the way around but i didn't think the fluid would cause it to come on i'll go put some in it and see what happens
Old Aug 16, 2007 | 11:50 AM
jvckustumz's Avatar
wow my brake fluid was almost dry lol but my brake light still didn't go off, maybe when i drive it alittle bit it will, we will see i guess
Old Aug 16, 2007 | 11:52 AM
NmexMAX's Avatar
dot dot dot ...
So I'm assuming you added fluid, correct? And yes, it will cause the light to come on, as I stated earlier .
Old Aug 16, 2007 | 11:57 AM
jvckustumz's Avatar
thats just nuts it has a sensor, i learn something new about my max everyday lol, i just hope it will turn it off and yes filled er' up yo
Old Aug 20, 2007 | 10:15 AM
Maximeyez's Avatar
Yes our cars have 2 sensors attached to the brake system. The first one senses if your break fluid preasure is low and this can be due to either low fluid or a leak in the line which would result in low fluid levels and decreased fluid preasure. The second sensor is connected to the calipers. If the calipers are going past the safe point indicating that your pads are extremly low and need replacing, then your brake light will come on. This information is coming from the head service writer of Nissan of Mount Kisco NY. He is also a Maxima owner.
Old Aug 20, 2007 | 02:55 PM
NmexMAX's Avatar
dot dot dot ...
That indicator just squeals like/scrapes like sin whenever the pads are past the indicator. There is no electronic sensor there as many times I've replaced worn pads with no brake light whatsoever.
I don't care if he created the Maxima from fresh rice, that's incorrect.
Old Aug 20, 2007 | 07:00 PM
Keatz's Avatar
Your brake fluid is probably low, give that a check.
Old Aug 20, 2007 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
Old Aug 20, 2007 | 09:22 PM
got_max's Avatar
Wants a real car
Mine is doing the exact same thing, however, Its true, the light goes on when brake fluid goes low, the fact the it came on when you floored it is the sensor thought it was low. it got tricked. If you slam on the brakes. it will make it thinks its full
now, the second issue that ended up occuring for me it the actuall ebrake sensor was loose and when I accelerate the sensor would trip. when i hit the brakes it turns off.
*i doubt thats your problem, just letting you know for a fix in a 1/1000 chance in this happening to both of us
Old Aug 20, 2007 | 09:37 PM
EnervinE's Avatar
i has college
Incorrect, as mentioned earlier... there are no wires coming from the calipers.
Old Aug 21, 2007 | 01:53 PM
Maximeyez's Avatar
Hey NmexMax, quit your ***** crying. I am just relaying what I was told. Take it or leave it !!!! By the way, have you ever rebuilt your master cyl. and checked to see if there are any sensors in there? Have you ever checked your brake fluid resevoir to see if there are any sensors in there? Well if not then shut the hell up! As an orger you should know that Nissan has put some useless stupid *hit in these cars. So don't be surprised if what this guy says might actually be true, unless you have personally taken apart your ENTIRE brake system and know for a fact that it is BS.
Old Aug 21, 2007 | 02:00 PM
NmexMAX's Avatar
dot dot dot ...
I never said there weren't any sensors in the MC. My point was and still is exactly what I quoted, so before you assume that I quoted your entire response, go back and see what I ACTUALLY quoted before calling me out.
That part being that there is a said sensor in the caliper area. There is not, aside from the one that I mentioned, but it is not an electronic sensor that would rely any type of data(v/resistance signal) to the dash/ECU in order to trip a dash light. It’s merely a mechanical indicator.
Old Aug 21, 2007 | 09:27 PM
MDeezy's Avatar
I gotta pull my center console apart my brake light wont come on (when I pull the hand brake).
all these dagnabit sensors...
and on the low pads sensing sensor.
Old Aug 22, 2007 | 06:00 AM
NmexMAX's Avatar
dot dot dot ...
Mechanical or electronic?
Old Aug 22, 2007 | 06:08 AM
MaxFanatik's Avatar
ya smae **** iwth me i floor it light on i hit the brakes lite off lol.....
Old Aug 22, 2007 | 06:20 AM
jvckustumz's Avatar
ya the fluid fixes it!!! lol
Old Aug 22, 2007 | 06:21 AM
jvckustumz's Avatar
Old Aug 23, 2007 | 04:52 AM
MDeezy's Avatar
havent checked it out yet. I went over a bump coming out of burger king, and I apply the brake but I believe while the two front wheels were off the ground for a second, came down car slid a little bit and the brake light illuminated.... went away, blinked... did this a few times and went away. Now I only see the brake light for a second when starting up the car and thats it. If I pull up the hand brake no light. I think it might be a fuse, going to examine this weekend.
Old Aug 28, 2007 | 10:01 PM
nguyen925's Avatar
could be that you have air in your brake lines? just a suggestion..
Old Aug 29, 2007 | 10:55 AM
MDeezy's Avatar
i found my problem. going to fix it tonight and post pics, its odd what happened....
Old Aug 29, 2007 | 11:24 AM
ROCKART's Avatar
wants an I35
i had a similar problem but it had nothing to do with fluid.
it was some sort of electrical issue, the ebrake bay somehow wasnt touching something it was supposed to be touching, even though it was all the way down.
anyway it was a 10 minute fix.
Old Oct 10, 2007 | 08:13 AM
Xtr3m3X's Avatar
Reppin' the 216
So... what if the light is on and the pads are ok and the fluid is topped off? Mine suddenly came on yesterday just driving normal back home from class. I looked at the pads and the fluid, and both seem to be where they need to be. Any suggestions now? It is true that I slammed on the brakes in the morning on my way to class because of some old fart in front me tried causing an accident...
Old Oct 10, 2007 | 08:17 PM
PhatBastard's Avatar
NmexMAX is correct, there is NO sensor of ANY kind on the calipers of a 4th gen Max. I don't know about the other generations.
There CAN be a wear INDICATOR on the pads themselves which causes the irritating squeel when the pads are starting to wear.
Old Oct 10, 2007 | 10:06 PM
andrei3333's Avatar
Same thing here, where is this sensor?
i pulled my console before and never noticed it
Old Oct 31, 2007 | 11:31 AM
ddurandd's Avatar
My brake light came on after a cold night outside of the garage. At first I thought it was the e-brake switch, but it turned out that the brake fluid was low. (It was still just above the "MIN" level though.) I took it to a shop to get my brakes looked at because I had not had them inspected in a while. They said the front pads were about gone.
My mechanic also said that typically you should not need to add brake fluid to your system (unless there is a leak of course). The light will come when your pads are worn enough to let the caliper piston extend far enough to lower the brake fluid level to the point of turning on the brake light. This was news to me as I had always been in the mind set of "topping" off fluids during routine maintenance. I like having this as a way to remind me to get the brakes checked if I fail to visually inspect them.
Old Oct 31, 2007 | 11:59 AM
redlobster's Avatar
my guess as well
Old Jul 17, 2010 | 08:51 AM
skypilots's Avatar
I have the same problem. I had the light go on because of low fluid then the lite will not go off after i filled it. I do have a bad brake line.
Old Jul 17, 2010 | 01:51 PM
JonZ 98 BlackMax's Avatar
I had this problem before and i changed my Pads and rotors and went away so probably pads and or brake fluid
Old Jul 17, 2010 | 01:54 PM
NmexMAX's Avatar
dot dot dot ...
Jesus, really? This thread is like 3 years old.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
A32goldylocks
Sep 2, 2015 06:39 AM
