ECU replacement or reprogrammed
Old Aug 19, 2007 | 06:55 PM
Pilot8680's Avatar
Does the ECU for 1995 Maxima need to be replaced or reprogrammed? If so, at what point and what are the symptons of ECU failure.
I'm askn because right now I need to tap the ECU while turning the ignition in order for my car to start. I need someone that knows well with the 1995 Maxima ECU and the codes that lives in NYC and Long Island, preferably in Queens. Need some serious help!!!
Old Aug 19, 2007 | 06:58 PM
99BlackMaxMS's Avatar
First step is to check the ECU for codes and fix those....could be loose wiring if there are no codes present, but still youre lacking enough information for anyone to help you out.
Old Aug 19, 2007 | 07:30 PM
Pilot8680's Avatar
My mechanic told me he found 10 codes and had resetted it. He doesn't know if the computer are just putting out the codes or there's really any problems.
Old Aug 19, 2007 | 07:37 PM
HomerMAC's Avatar
Donating i30 Owner
loose wiring..? probably .. make sure of that first before doing anything
Old Aug 19, 2007 | 07:44 PM
Pilot8680's Avatar
is it possible that the ECU is faulty? Ever heard of ECU failure?
Old Aug 19, 2007 | 07:47 PM
Kevlo911's Avatar
Kevlo for President
Very few ecu failures, we usually have the harness tearing, look in the stickies for the TSB for the egi harness tear
Old Aug 19, 2007 | 07:51 PM
Pilot8680's Avatar
"look in the stickies for the TSB for the egi harness tear" - Can you elaborate that, doesnt really know what that means
Old Aug 19, 2007 | 07:55 PM
Kevlo911's Avatar
Kevlo for President
On the main 4th gen page you see:
Sticky: MAINTAINANCE and MECHANICAL Information- Don't Post Questions Here! (Multi-page thread 1 2)
phenryiv1
That is a sticky and most of use refer to all of them as the stickies, they have tons of useful info. A tsb is a technical service bulletin which is what nissan gives the dealers to fix common problems.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
cruce91
Sep 20, 2015 10:23 AM
intimidator
Sep 5, 2015 07:23 PM
ef9
Aug 27, 2015 10:17 AM
