My trunk light won't turn off!!
Old Sep 3, 2007 | 07:53 PM
Slickismax's Avatar
Just like the title says. I has to swap my rear clip, and now my trunk light won't turn off. I must have missed a sensor somewhere, but I don't know where. Can anyone help? It's a '96 GXE if it makes a difference.
Old Sep 3, 2007 | 11:28 PM
pmohr's Avatar
No more Maximas...
How do you know it doesn't turn off if it's only on when the trunk is open? Do you see it through the arm rest passthrough or through the rear shelf vents?
Old Sep 4, 2007 | 12:06 AM
matty's Avatar
Had this problem like 3 years ago and just wound up pulling the bulb out and forgetting about it. I would like to find a fix though.
I saw the light through the arm rest one night.
-matt
Old Sep 4, 2007 | 08:51 AM
Slickismax's Avatar
Yeah, it would be hard to tell if the light was staying on, but I don't have my back window or my rear shelf in place, so I can see the top of the light when the trunk lid is closed.
Old Sep 4, 2007 | 09:19 AM
andrei3333's Avatar
Had the same problem just when i bought the car. alarm kept going off randomly cause the car thought the trunk was open but it wasnt
solved it like this: to confirm, make sure the light bulb in the trunk is operational. then close the trunk and go into the back of the car, open the arm reast in the back seat and look inside, if the light is on then its the same problem as i had.
open the trunk and in the latch (the one in the trunk door itself, not the lower bumper. pull back the carpeting and you will see the trunk release module. there is a clip with two wires coming out, unclip that and take out the two 10 mm bolts (i think) take the latch out of the car and inspect for broken connections.
i replaced mine for a brand new one from the dealer, cost like 30 dollars or so but if u r patient u can go to a junkyard and look for a latch there.
let me know how this goes
Old Sep 4, 2007 | 09:21 AM
XJinCT's Avatar
<3's the all motor section
replace the whole light assembly...if its anything like my jeep...the hood light...it would turn on/off as you tilted it. i have no idea how the hell that worked, but i know thats how it operated.
but the maxima is stationary...remove \the bulb or look into it.
tsi6001
Oct 3, 2022 10:23 PM
Btheman80
May 1, 2018 04:03 PM
vingodine
45
May 21, 2016 12:46 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
BobMax
Aug 15, 2015 12:35 PM
