Problem....
Old Sep 6, 2007 | 09:24 PM
Tmcgradyfann1's Avatar
close but no cigar
Problem....
so when my car is warm and im driving and i come to a stop the rpm's come to a really low dip almost liek the car is about to stall out around 300 rpm's. Thats not the only problem when i turn on the lights the rpms die down a little and even when i use the power windows or sunroof the rpm's dip down a little... anybody know what it could be? i searched couldnt find anything
Old Sep 6, 2007 | 09:29 PM
andrei3333's Avatar
the lights thing could be a bad ground
Old Sep 6, 2007 | 09:33 PM
abomb1987's Avatar
could be your fuel filter
i had the same problems like you did, it was my tps, replaced it from a junk yard,
easy and simple fix
Old Sep 6, 2007 | 09:34 PM
shyheim07's Avatar
alternator?? or sumthin isn't right in your EVAP system
close but no cigar
my battery and alternator were just replaced less then 300 miles ago
Old Sep 6, 2007 | 09:37 PM
close but no cigar
i may not have the belt tensioner adjusted correctly the tension on the belt wouldnt have anything to do with it?
Old Sep 6, 2007 | 09:39 PM
shyheim07's Avatar
easy and simple fix
to the fuel filter
I know when my Idle was having issues i had a code for a EVAP systems control valve or sumthing of that nature. anyways, after I changed mt PCV valve, it went away and everything set itself back to normal. my idle actually jumped up and down so i dunno. just giving ya some ideas...
Old Sep 6, 2007 | 09:40 PM
shyheim07's Avatar
talkin' bout that screw on the alt right? that's another possible cause, saw it on here somewhere
Old Sep 6, 2007 | 09:42 PM
abomb1987's Avatar
if your tensioner was off, your car would be squealing
Old Sep 6, 2007 | 09:43 PM
close but no cigar
well yea it did that for a while then i tightened that but just to where it didnt squeal... talk about the most annoying thing
Old Sep 6, 2007 | 09:46 PM
abomb1987's Avatar
especially in the morning
picklepepper23
May 21, 2015 09:05 AM
Spectre77
Jun 1, 2014 07:18 PM
bpw3000
Mar 8, 2013 10:11 AM
shabnyc
Mar 22, 2011 07:31 PM
ZeRo MaX
Apr 30, 2005 07:09 PM
