Installing NOS Fuel Pressure Switch
Ok, there are two ways to install the fuel pressure switch for a NOS EFI Dry Kit. It says you can either install in on the fuel rail test port or on the outlet port of the fuel filter (if it has a banjo type fitting). I looked today and since the Maxima is a later year fuel injected vehicle, it does not have the fuel rail test port. And the fuel filter does not have the banjo type fittings. So where did you all with NOS install it at? Thanks for your help. I have been working for a few hours on this project and so far so good. Thanks again.
ok here's what you do, get some EFI 5/16" Fuel line, a brass 5/16" tee fitting, 5 micro hose clamps, and a tee with three 1/8npt ports and a 1/8npt to 5/16 hose adapter, run the tee right above the fuel filter to the second tee with the FPSS and your FP sender that you should have bought. i've done it three times, takes an hour tops. 30 minutes today.
Originally posted by Ramius83
Can I install it below the fuel filter? I have began work on this already and have planned for it to be "hidden" under the fuel filter. Thanks again guys.
MaximaDrvr
08-19-2015 08:20 PM
