need help to reset remote keypad for my Maxiam
Old Aug 1, 2001 | 04:54 PM
unixsvr4's Avatar
Any one I need help to reset my keypad for keyless entry for my 97 Maxima SE, any help would be really appricated
Old Aug 1, 2001 | 05:08 PM
Sonic's Avatar
Taken directly from MaxFAQS( http://web2.airmail.net/scutchen/max_faq/):
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Old Aug 1, 2001 | 05:17 PM
unixsvr4's Avatar
yes but where do u get these new codes to enter, without new codes it doesn't work I already tried few times, thanks so much any way
Old Aug 1, 2001 | 05:29 PM
Sonic's Avatar
The codes come from the remote. If you did this correctly and it still didn't work, then change the battery in the remote.
Old Aug 1, 2001 | 05:32 PM
unixsvr4's Avatar
where from the remote can u please be little more specific. from inside or out side the remote
Old Aug 1, 2001 | 05:41 PM
Sonic's Avatar
Look at step 4 above:
Old Aug 1, 2001 | 05:45 PM
unixsvr4's Avatar
how do you enter the new code, is it numbers or letters and
where do u enter with the remote or what, sorry I am really confused.
Old Aug 1, 2001 | 05:59 PM
Sonic's Avatar
HIT THE LOCK BUTTON.
That's all there is to it. Really.
Old Aug 1, 2001 | 06:07 PM
speedy-t's Avatar
Dude, don't think of it as entering a code with numbers or whatever. Just think it as you are linking your remote to the computer. When you get to step 4, you are doing just that when you hit the "blue" lock button on the remote. I you have two or more remotes, you need to do those at the same time before getting out of the car.
Old Aug 1, 2001 | 06:14 PM
unixsvr4's Avatar
ok! I am gonna try this, thanks all of u guys for help
Old Aug 2, 2001 | 06:36 AM
speedy-t's Avatar
So did it work?
Old Aug 2, 2001 | 06:44 AM
unixsvr4's Avatar
got it
Yes! it did work thanks so much you guys!!! it's working now
gigabyte
Jan 6, 2017 06:05 PM
220k+ A32
Sep 22, 2015 03:08 PM
flu2000
Sep 14, 2015 12:34 PM
markevans999
Sep 10, 2015 04:29 PM
videomano
Sep 8, 2015 03:28 PM
