Yellow Foglights???
Old Aug 5, 2001 | 09:51 AM
97GreenMax's Avatar
I want a change in my front end lights, so I was wondering if anyone knows any way to make the foglights yellow?
Old Aug 5, 2001 | 10:57 AM
Sonic's Avatar
Bulb condoms? Someone at the midnight meet in Queens had them. Now I forgot who it was, but I do remember hearing about getting them at a motorcycle shop.
Old Aug 5, 2001 | 10:59 AM
Kevlo911's Avatar
Kevlo for President
or amber bulbs
Old Aug 5, 2001 | 11:15 AM
clee130's Avatar
psing23 had the yellow fogs.
Just look how yellow these babies are:
Old Aug 5, 2001 | 12:19 PM
97GreenMax's Avatar
I have heard of spray painting the bulbs...would that work?
Old Aug 5, 2001 | 02:38 PM
clee130's Avatar
Not really. Spraying it will give you that color... but it will reduce your light output. And also, the paint will fade after a while.
Old Aug 5, 2001 | 03:13 PM
Aaron's Avatar
Langley AFB Sux
Ange....if you want yellow fogs...
All you need to do is order some Hella Yellowstars. They are H-3 foglight bulbs....85 watt i think. I have them and they are nice. Think i paid 21 bucks for the pair....
susquehana motorsports or something...
Aaron
Old Aug 5, 2001 | 04:06 PM
97GreenMax's Avatar
Hey Aaron, where did you get those bulbs from, or where could I get some from??
Old Aug 5, 2001 | 04:51 PM
Aaron's Avatar
Langley AFB Sux
Ange and 97GreenMax try here ------->
Try this place
http://catalog.com/susq/
This is where i got mine
Aaron
Old Aug 5, 2001 | 05:24 PM
Mishmosh's Avatar
Hella
Any truth to the reports that the Hella Yellowstars are prone to premature burnouts?
How long have you had them?
I'd like to get some yellow fogs and can't quite decide between Hella or Philips.
Old Aug 5, 2001 | 07:03 PM
Aaron's Avatar
Langley AFB Sux
Thats BS........
I've had mine in for about a year and a half......and i run them with headlights at dark........so they are quite used....still going strong......no fading.....etc
Aaron
Old Aug 6, 2001 | 11:37 AM
Albertt's Avatar
Or you can get your foglamp H3 in yellow from here >>
http://www.autooptiks.com
Look for the Philips WeatherVision/AllWeather bulbs.
Old Aug 6, 2001 | 04:24 PM
Mishmosh's Avatar
Re: Or you can get your foglamp H3 in yellow from here >>
For select Philips bulbs, check this place out. Seems to have great prices AND FREE SHIPPING (no minimum)!!!
Not sure where they are located but they ship worldwide. Just ordered so can't comment on reliability nor fulfilment timeliness.
http://www.autolamps-online.com/halogen/index.htm
Ordered 3 H3 Philips Allweather bulbs (one for spare).
Old Aug 6, 2001 | 10:52 PM
190hpKiLLA's Avatar
Granny Driven
Hella Yellow H3 85w?
I dont know what to do. 3 days ago I orderd the regular wattage foggys. I put them in and its nothing like the lexus GS400 yellow goggys. So would 85w be brighter then 55w and would it burn the wiring. Thanks.
Old Aug 7, 2001 | 06:06 AM
Albertt's Avatar
Re: Hella Yellow H3 85w?
I wouldn't go for the 85W bulbs. Some of the guys here have experienced overheated and eventually cracked lenses due to the high wattage bulbs. The reason why Lexus foglamps apprear so yellow is that they use a yellow tint on the reflector surface of the lamp...not a yellow bulb.
Old Aug 7, 2001 | 08:51 AM
Nine7Max's Avatar
hmm
how different are the IS300/GS400 fogs from the 97-99 maxima's? Maybe, if not to big, we could somehow custom fit them in place of ours.
Old Aug 7, 2001 | 09:04 AM
Aaron's Avatar
Langley AFB Sux
Re: Re: Hella Yellow H3 85w?
Like i said.......i have been running the 85 watt hella yellowstars for almost a year and a half.......no overheating.....no cracked light housings.....
Old Aug 7, 2001 | 09:45 AM
Albertt's Avatar
Aaron: Ok...we heard you...85W bulbs, no cracked lenses...you've been lucky. nm
nm
Old Aug 7, 2001 | 10:27 AM
Jon91SE's Avatar
Pusssseeeehhhh
If you want that lexus yellow, you need to buy a nice set of "projector" fogs,there different cause they use a convex dichroic lens that will create that sharp concentrated beam pattern and will look just as nice if not nicer then the GS or IS if you buy form a quality company like Catz or PIAA
plus they use thick glass and a strong metal housing.....
Old Aug 7, 2001 | 10:35 AM
NISMO808's Avatar
maybe you can open up the foglight assembly like u can with the tail lamps and then tint the reflector urself with metallic yellow spray paint.
Old Aug 7, 2001 | 02:33 PM
fast97maxse's Avatar
I got the Hella Yellowstars from Susquehanna Motor Sports.
Happy with results.
I was running with them on alla time with no problem.
Then I started to read posts about the possibility of a cracked lens.
So now I only use them at night when it's foggy out...
Old Aug 7, 2001 | 03:32 PM
97GreenMax's Avatar
Where could I buy the Hella Yellowstars from?
Old Aug 7, 2001 | 05:43 PM
BillN
PIAA H3 Yellow
I have had the PIAA ion yellow foglights for about a year and a half. I love them. I think that they are pretty close to the look you want plus they are very bright. The only problem I have is that the driver side seems a little brighter than the passenger side
Old Aug 7, 2001 | 05:46 PM
190hpKiLLA's Avatar
Granny Driven
look on first page for links.
Old Aug 7, 2001 | 06:09 PM
cmcknite's Avatar
Dont get the 85W bulbs! I cracked my right fog light when it was cold last winter. Water spashed on them from a puddle and crack!!!! Get the 55W bulbs. They might not be as bright, but better that than a new fog light assembly.
Oh, and I used mine for 6 months before one of them ever blew.
Old Aug 7, 2001 | 07:41 PM
black019's Avatar
so im guessing that the 110w yellow stars would be a bad idea to get
Old Aug 7, 2001 | 08:24 PM
190hpKiLLA's Avatar
Granny Driven
You think?
Heat0212
Oct 24, 2020 12:36 AM
Fbana41
Aug 29, 2016 12:18 PM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
